General Supercharger Thread
  1. Apr 29, 2025 at 9:18 AM
    Abell207
    Abell207 New Member
    Anthony
    Maine
    2020 Army Green TRD PRO
    Any more valve bodies get delivered? Still waiting for mine and also a response from them asking for an eta.
  2. Apr 29, 2025 at 9:19 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Question for those with AFR gauges, when cruising off the gas do your AFRs consistently drop past the range on the gauge? Is there a speed threshold where this occurs?
    I noticed my gauge used to display "----" when cruising. I thought it used to occur at low speeds now it appears it only happens at higher speeds or steeper declines.
    What are y'all observing?
    ARES35 and Abell207 like this.
  3. Apr 29, 2025 at 9:22 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Is this with AEM or Innovate? My older AEM failsafe displays reading all the time. Goes to 18 when off acceleration on downhill or stopping.
    armyoffoo and Abell207 like this.
  4. Apr 29, 2025 at 9:22 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Normal, it's called deceleration fuel cut off. Kind of a engine-braking feature, but not sure what conditions it gets activated.
    reywcms, ARES35, Wynnded and 4 others like this.
  5. Apr 29, 2025 at 9:24 AM
    Abell207
    Abell207 New Member
    Anthony
    Maine
    Yup totally normal, as now your motor acts like a giant vacuum pump and shuts off the injectors while coasting.
  6. Apr 29, 2025 at 9:29 AM
    Saltyhero13
    yes but what is the min speed threshold. Mine seems to do it only at higher speeds.
  7. Apr 29, 2025 at 9:30 AM
    Saltyhero13
    Ok so I am probably misremembering it occurring at lower speeds.
  8. Apr 29, 2025 at 9:31 AM
    Saltyhero13
    TY. For some reason I recall it happening more often.
    HulkSmurf14 likes this.
  9. Apr 29, 2025 at 9:32 AM
    Abell207
    Abell207 New Member
    Anthony
    Maine
    I’m not sure at what speed but mine will do it only at higher speeds as well. Like 25+ mph. It’s whenever the converter unlocks and now the motor needs to stay running afr comes back.
  10. Apr 29, 2025 at 9:33 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Mine (PSB-1) always shows my AFR value no matter when/how I'm driving...always 14.4-14.8 when cruising and real low 12s at WOT...if coasting downhill, it'll read in the 20s until the skinny pedal is tapped...I'm at 5k elevation...
  11. Apr 29, 2025 at 9:41 AM
    WinterWarlock21
    WinterWarlock21 New Member
    South Jersey
    2016 Quicksand TRD Pro CrewMax
    https://gearproject.co/profile/SandShark21
    Still waiting on my end. Ordered 2/10 so probably last on the list but was hoping to see more of them arriving in this thread.
    Abell207[QUOTED] and HulkSmurf14 like this.
  12. Apr 29, 2025 at 9:44 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    ARES35 and HulkSmurf14 like this.
  13. Apr 29, 2025 at 10:27 AM
    Abell207
    Abell207 New Member
    Anthony
    Maine
    @armyoffoo did you ever get your interchiller installed?
  14. Apr 29, 2025 at 10:41 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    I’m planning on getting my VB installed asap to get the core sent back for those still waiting.
  15. Apr 29, 2025 at 10:51 AM
    bflooks
    bflooks New Member
    Metrowest MA
    Can you write a tag asking them to diagnose it? I'm going to do the same for mine, but I'm curious since we've been towing the same rig but I've had 5.29s and you've had factory.
    Oh! And to keep a tally for who is still waiting, my name is on that list.
    Silver17[QUOTED] likes this.
  16. Apr 29, 2025 at 10:52 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    No, I've been slacking on that as well, but I need to replace the AC condenser and compressor, so probably going to do it at the same time this summer.
    Abell207[QUOTED], HulkSmurf14 and Mdl like this.
  17. Apr 29, 2025 at 11:11 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Thanks! I have to recharge mine. I have a bottle and need to find some more of the "older" refrigerant.
    armyoffoo[QUOTED] likes this.
  18. Apr 29, 2025 at 11:22 AM
    HulkSmurf14
    2014 Tundra Limited
    I sent my core back April 14 and it was received April 16...I'd imagine the turn-around time on the cores is typically 2 weeks, but that's a wild guess...I'm not certain what they need to confirm or not to decide if it's a usable core or not...Mine appeared, to me at least, to look brand new and shiney still...the only difference being the plate between the two halves. I'll let everyone know when the returned core dollars are credited back...
  19. Apr 29, 2025 at 11:24 AM
    HulkSmurf14
    2014 Tundra Limited
    What are you thinking they are looking for (truly curious as I didn't think I could ask)? I assume they're just confirming there aren't any cracks so they can do their gold plate magic in-between the halves...I'm just thinking they aren't spending time on diagnosing cores to that degree...
    e30cabrio likes this.
  20. Apr 29, 2025 at 11:38 AM
    bflooks
    bflooks New Member
    Metrowest MA
    Based on their videos, it would be interesting to see if there is any leak down on the stock VBs. Looks like they have a custom mat they use to test each passage. I don't know if they would respond to notes being attached to it for the request and then have the results sent back to an email address, but it would be really interesting to see if there is meaningful difference between his and mine since we have the same towing demands.
  21. Apr 29, 2025 at 11:41 AM
    HulkSmurf14
    2014 Tundra Limited
    gotcha, that would be interesting...I would definitely consider trying to send a note in the package with an email address, etc to see if the Aussies will help...all cores are sent to Cruisers and I assume they send a pallet to WAT when they have enough to send off....
  22. Apr 29, 2025 at 11:48 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    The only valve bodies that can't be reused are one that have been already bored for the larger accumulators and don't hold a vacuum on the bored passages. Of course cracks or deformities would rule out being reused. The separator plates are new on ipt/level10. Just not sure of the make up/treatment on the WAT ones.
    ARES35, e30cabrio and HulkSmurf14 like this.
  23. Apr 29, 2025 at 12:37 PM
    LILTRD
    LILTRD New Member
    East Bay, California
    2013 Tundra RCSB
    Hidden Winch Lighting Suspension/Air bags Wheels/Tires Audio Center Console swap
    Congrats, getting jealous over here waiting on Whipple, so I reached out to them again after no response the first time.
    Here's there response for us whipple waiters;
    "We are currently working on getting the Tundra blowers out after we've upgraded these to the 3.0. I don't have an exact ETA, but it should be relatively soon."
  24. Apr 29, 2025 at 12:39 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Thanks for the update.
    I'll keep my "Dreaming for a Whipple Shipping Date" signature.
  25. Apr 29, 2025 at 1:01 PM
    ssmokedz
    Shelton CT
    Still waiting here as well. Ordered February 7th.
  26. Apr 29, 2025 at 1:03 PM
    Ryuu
    Ryuu Hwat!?
    Oz
    SouthEast, TX
    2017 TRD PRO Barcelona Red
    a few
    new belt showed up.
    smoke machine will be here tomorrow..
  27. Apr 29, 2025 at 1:17 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I think that the Fuel Decel Cutoff is at 1500rpms.
    Mdl, ARES35 and HulkSmurf14 like this.
  28. Apr 29, 2025 at 1:48 PM
    centex
    centex New Member
    My innovative goes to -23.8". Totally normal.
    bflooks, ARES35 and HulkSmurf14 like this.
  29. Apr 29, 2025 at 1:50 PM
    centex
    centex New Member
    I'm a hold up on mine. Haven't had 5 minutes to get under there and take the truck off the road. I may have to suck it up and spend the $900 for labor and fluid and pay someone to do it just do to time.
    bflooks and HulkSmurf14 like this.
  30. Apr 29, 2025 at 1:52 PM
    HulkSmurf14
    2014 Tundra Limited
    Ugh, it's worth a day to play on it yourself...I'm way cheaper than $900/day!
    Mdl likes this.
