Real center console fridge
Discussion in '2.5 Gen Tundras (2014-2021)' started by Gtboosted, Apr 29, 2025.
  1. Apr 29, 2025 at 9:01 AM
    Gtboosted
    Gtboosted [OP] New Member
    Los Angeles
    2020 CSM Tundra 1794
    Sup guys.
    I ordered a a real compressor fridge made by Dometic and meant to go in a gm 1500 center console. With a few minor mods it can work. The only problem I have is that I would need to make the hole for the fan where the passenger AC duct is. I have kids and they'll probably complain if I get rid of one side. It's already weak cooling back there as it is.
    The coolers are being clearanced at $100 so I'll keep it and may create a case for it so it can go in the rear floor. Also I may wait for a cheap center console to try to modify.
    Just posting it for anyone that may be insterested in doing something similar. Yes it's small but the center console usually becomes a landfill for me.
    In order to fit you need to remove two feet on the cooler. Also, the inside cover on the lid needs to be removed. I created a quick bracket for the latch and it worked but if I was to make it permanent I would do something nicer.
    I tested the cooler and in 5 mins the walls got icy.
    20250428_221457.jpg 20250428_221504.jpg 20250428_221743.jpg 20250428_185649.jpg 20250428_191337.jpg
  2. Apr 29, 2025 at 9:35 AM
    d33pt
    d33pt New Member
    Where can I get one for $100? That's a cool little fridge.
  3. Apr 29, 2025 at 9:39 AM
    Tundra Texan
    Tundra Texan New Member
    Todd
    2016 Tundra
    None at this point.
    Thats pretty slick!!
    I'm guessing you could just plug it in and set it on the back seat floorboard?
    I dont do enough long road trips to warrant losing my center console storage.
    Mater likes this.
  4. Apr 29, 2025 at 9:43 AM
    Gtboosted
    Los Angeles
  5. Apr 29, 2025 at 9:44 AM
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    I wonder if this one is bigger/smaller than the ford one as that’s on sale as well for $150. Might pick one up and put it on the floor between the rear seats so the kids can grab their own snacks
  6. Apr 29, 2025 at 9:48 AM
    Gtboosted
    Los Angeles
    That's what I will end up doing if I dont find a very cheap center console for tinkering.
    I removed the GM plug to test it on my battery. It's a simple 2 wire plug so a male "cigarette" plug can be wired into it to connect it to the rear outlet.
    Tundra Texan[QUOTED] likes this.
  7. Apr 29, 2025 at 9:50 AM
    Tundra Texan
    Todd
    2016 Tundra
    None at this point.
    Doesnt the Tundra come with a rear seat cig lighter plug?
    Never ridden in the back seat so I'm not certain.
  8. Apr 29, 2025 at 9:51 AM
    d33pt
    d33pt New Member
    Awesome. Picked one up for the hell of it. If anything, I can use it on my desk for cold drinks. Thanks for passing along the deal!
  9. Apr 29, 2025 at 9:51 AM
    Gtboosted
    Los Angeles
    The Ford one was also $100 until it sold out by Dometic. I think the $150 is a reseller.
    This one is smaller. But I specifically ordered this one to try to make it work in the console. Now that I see the AC duct will be an issue I maybe should have ordered the Ford one to set it on the floor.
  10. Apr 29, 2025 at 9:52 AM
    Gtboosted
    Los Angeles
    Yeah it does, that's why I said a male plug can be wired into the cooler so that it can connect to the rear cig female plug.
