Storing a hitch when not in use
Discussion in '3rd Gen Tundras (2022+)' started by Lundertunder, Apr 18, 2025.
  1. Apr 28, 2025 at 3:47 AM
    #61
    bighaubs
    bighaubs New Member
    2024 Lunar Rock Tundra SR5
    Me too. Put the receivers in my toolbox.
    BlackNBlu likes this.
  2. Apr 28, 2025 at 11:20 AM
    #62
    22whatwedo
    22whatwedo New Member
    The Open Road
    22 SR5 TRD OR Army Green
    I keep the WDH in the camper and carry a 3 size/way ball in one of the swing cases.
  3. Apr 28, 2025 at 2:29 PM
    #63
    airosey
    airosey 2009 CrewMax Limited 4x4
    Slightly modified 2009 CrewMax Limited 4x4
    09 Tundra CrewMax Limited TRD Supercharger with URD pulley Tuned by OrangeVirus tuning (OV Tune) TRD Big Brake Kit with SS lines and titanium backing plates StopTech rear sport axle pack (rotors, pads, and SS lines) 7” Pro Comp lift 3” Performance Products Body Lift Coachbuilder 1” coilover shims Coachbuilder +3 shackles Coachbuilder Tie-rod ends 22x14 -70 Fuel Lethal’s - 2 piece 38x15.5 Mickey Thompson Baja Boss M/T’s King Shocks with remote reservoirs front and rear Nitro 5.29 gears front and rear Auburn LSD SPC adjustable UCA’s BAM 8” exhaust Pro Comp Traction Bars Enve Grille Smittybilt M1 front bumper Rough Country 12k lbs winch Demon Hook shackles front and rear Baja Designs Squadron Sport Amber and clear fog lights ADD HoneyBadger Rear Bumper with Rigid SR-Q reverse lights Sequoia Headlight conversion Switch-Pros SP-9100 mounted in overhead console SD Off-road MT under-hood tray AEM boost and afr gauges Hypertech Speedometer calibrator Bed and rear bumper are Bulletlined American Flag Headliner Mammoth Guards patriot edition Alpha and Omega Fabrication Patriot Hood shield 3rd gen door panels and steering wheel ProSpeed Catchcan Hornblasters Outlaw train horns Tufskinz real carbon fiber overlays Tufskinz carbon fiber B panels vLEDs footwell lighting front and rear vLED puddle lamps Lighting Trendz flow series wheel rings 16 RGB rock lights Toyota Bedmat Bestop Power folding steps Undercover bed cover Undercover SwingCase 4 gallon Rotopax fuel can Here’s a rundown of the audio setup. -Active front stage using a JL Audio TwK88 DSP, Focal 165KRX2 component speakers, powered by a JL Audio HD900/5 -Passive rear setup with Focal 165KRX2 component speakers -2 JL Audio Stealthboxes (13TW5’s) powered by a JL Audio HD1200/1 -Sony XAV-9500ES float mount display with a PAC Radio Pro 4 -Odyssey battery -JL 0 gauge power and ground cables -AudioQuest X-2 speaker cables and Golden Gate RCA interconnects -Entire cab has been lined with Dynamat Extreme and 1/4 CCF Amps and dsp are mounted under the passenger seat with a SoundsGoodStereo mounting plate.
    Hang-a-hitch
  4. Apr 28, 2025 at 2:47 PM
    #64
    Dsptundra
    Austin TX Area
    2021 Silver Limited CM
    That’s slick.
    BlackNBlu and airosey[QUOTED] like this.
  5. Apr 28, 2025 at 3:00 PM
    #65
    I leave mine in the receiver. One time on the way to the airport for work early on a winter morning I spun out several times on the river bridge and ended up sliding backwards towards the concrete wall at about 10-15mph. The hitch contacted the wall saving the rear of my truck. Hit so hard it bent the hitch and the cab contacted the bed. Zero damage to the rear bumper or bed. Another time a lady rear ended me at a light. Punched a hole in the front of her car and left no damage on the truck. Team RamRod here.
  6. May 1, 2025 at 4:38 PM
    #66
    Rat Fink
    Rat Fink New Member
    Alabama
    25 Silver 1794
    Left mine in to get used to it being there. No more banged up shins. You're used to it being there so you automatically avoid it.
  7. May 1, 2025 at 7:15 PM
    #67
    SDT-Online
    SDT-Online New Member
    2024 Tundra Platinum (Red)
    You can turn it upside down to change the bruise on your shin.
  8. May 2, 2025 at 1:37 AM
    #68
    Bloomjtundra
    Bloomjtundra New Member
    Josh
    2011 Tundra DC 4x4
    Thanks for all the replies!
    Summary is:
    most leave the hitch in the receiver or at home. A few leave it behind the rear seat back area where the jack is stored. That’s what I’ll be doing.
    Tundrastruck91 likes this.
