Best Shallow Sub
Discussion in 'Audio & Video' started by Snert, Dec 9, 2024.
  1. Apr 16, 2025 at 2:49 PM
    #211
    Iamsecond
    Iamsecond New Member
    Kevin
    2019 Limited Tundra
    that might be true if the box only has one chamber for both subs but my box has 2. One sealed chamber for each sub. But that is a good thought and might affect things as you have stated.
  2. Apr 16, 2025 at 4:04 PM
    #212
    caboj
    caboj New Member
    CA
    2018 Tundra CM TRD OR
    In that case they are definitely independent. Is it forward or rear facing?
  3. Apr 16, 2025 at 4:05 PM
    #213
    Iamsecond
    Kevin
    2019 Limited Tundra
    Forward. Cant do rear facing subs in the crew max
  4. Apr 17, 2025 at 5:39 AM
    #214
    Boneskull420
    Boneskull420 New Member
    Tn
    2018 tundra crewmax magnetic gray trd offroad
    Ironman 4x4 foamcell pro 3.5in lift Complete custom stereo with 2 12's under rear seat S&B/stillen Frankenstein cold air intake True dual exhaust with Carven Tr mufflers Rough country hood bulge led strip Running board led's
    I could be wrong but isn't the JL stealthbox rear facing?
    Snert[OP] and caboj like this.
  5. Apr 17, 2025 at 9:08 AM
    #215
    caboj
    caboj New Member
    CA
    Yes, the JL box is rear facing.
    Boneskull420[QUOTED] likes this.
  6. Apr 17, 2025 at 9:11 AM
    #216
    Snert
    Snert [OP] New Member
    2021 SR5
    The stealthbox has a pair of 10TW3's rear firing for 2014-2021. I made my list of cuts the other night besides the top and a couple smaller pieces as I need to figure out exact dimensions as I start putting it together, but I should be able to get it done by the end of this weekend. My box build is rear firing 1cf behind the rear passenger seat for a single Wavtech thinPRO 12". I've got some rewiring to do among other things so I may not be able to test it this weekend, but I've got a umik and eventually plan to test it and post the results.
  7. Apr 17, 2025 at 9:16 AM
    #217
    Snert
    2021 SR5
    @Iamsecond I also have half a sheet of 3/4" MDF from a previous project and eventually planned to build a front firing box to compare the two. In theory rear firing should have better corner loading, and a pair of subs should have more output than a single, but that's all just hypotheticals and I'm curious enough to eventually want to compare front vs rear firing. I've also got enough baltic birch leftover I could probably make the front firing box out of it which'd be a direct comparison, and then I'd keep whichever sounds better and sell the other to another member :)
    EffectiveZed, caboj and Boneskull420 like this.
  8. Apr 21, 2025 at 6:12 PM
    #218
    Snert
    2021 SR5
    Didn’t finish this weekend because I totally spaced that it was Easter weekend, but made some good progress. 48” wide, 13.5” tall ends up being about 1cf which modeled the thinPRO 12 pretty close to .707 Qtc
    Hoping to have it done this week/end and to get it in the truck to do some testing/listening but I’ve also gotta do some reworking of my amp rack so everything can fit above the box behind the seats.
  9. Apr 24, 2025 at 5:11 PM
    #219
    Boneskull420
    Tn
    Looking good!:popcorn:
  10. Apr 24, 2025 at 5:25 PM
    #220
    EffectiveZed
    EffectiveZed New Member
    Nice work, Snert!
    I'm eager to hear your impressions on the sub. The specs look fantastic, but I think you're the first person on the forums I lurk (DIYMA included) to give it a go.
    What did you use for fasteners? Are those the E-Z lock threaded inserts or something else?
    Snert[OP] likes this.
  11. Apr 25, 2025 at 5:10 AM
    #221
    Iamsecond
    Kevin
    2019 Limited Tundra
    Box looks good. My only thought is how will the sub perform firing backwards into the plastic cover that covers the back wall. I know it’s probably deadened but still. Will be interesting to see. look forward to the end result.
  12. Apr 27, 2025 at 1:49 PM
    #222
    Snert
    2021 SR5
    Yeah there aren't a ton of reviews out there but from the limited one's I'd seen/read it seems like a pretty solid sub. And yes they are EZ lock threaded inserts but they're the ones for soft wood. In retrospect I think I'd try something else or maybe the ones for hardwood as they cause some minor chips on the top ply of the birch.
    The rear wall of my truck doesn't have a plastic cover unless maybe you're referring to the rear window cover? If so that thing's metal and yeah I've got it deadened inside and out as well as the back wall of the cab/inside the window opening.
    I forgot we had special olympics for a family member this weekend so I didn't get a chance to make any progress this weekend yet, but I'm hoping tonight I can maybe work on it a little bit and get it lined with CLD and fibermat before putting on the last couple panels. Should be done by this week/next weekend without a doubt, needless to say progress has been slooowwwww haha
  13. Apr 27, 2025 at 2:18 PM
    #223
    Boneskull420
    Tn
    Just like bbq, low and slow to produce the best product! Nothing wrong with that, we will be eagerly waiting:popcorn:
    EffectiveZed likes this.
