Lower ball joint issues
Discussion in '1st Gen Tundras (2000-2006)' started by davey757, Apr 27, 2025 at 11:50 AM.
  1. Apr 27, 2025 at 11:50 AM
    davey757
    davey757 [OP] New Member
    Installing new ball joints on 02 - easy to do ? Any good videos DIY ?
  2. Apr 27, 2025 at 12:53 PM
    tvpierce
    tvpierce Formerly New Member
    Maine
  3. Apr 27, 2025 at 1:22 PM
    davey757
  4. Apr 27, 2025 at 3:22 PM
    Not hard at all. Just don't be an idiot, always use OEM lower ball joints. Lest you may end up in the long list of other fools who ignored this advice: https://www.tundras.com/threads/first-gen-lower-ball-joint-lbj-failures.141860/
    Hardest part of the job is separating the tie rod from the LBJ, and separating the LBJ from the LCA. I used a pickle fork and a pitman arm puller and had zero issues.
    Make sure you use fresh hardware.
    And the "always use OEM lower ball joints" is NOT a suggestion. This is probably the biggest fuck-up Toyota made in their front end designs, putting the LBJ under stress. Aftermarket manufacturers don't give a shit about you, and assemble theirs like any other joint, using plastic internals, nylon retainers, etc. It's not a joke. There's always 1 in 100 people who genuinely got lucky, and had no issues with aftermarket but they're few and far in between. It's better not to risk it, your life, and your truck, neither are worth that risk.
    G_unit3000, ATBAV8, bmf4069 and 2 others like this.
  5. Apr 27, 2025 at 8:35 PM
    davey757
    Yes OEM always
    G_unit3000 and shifty` like this.
  6. Apr 28, 2025 at 3:50 AM
    txk131
    txk131 New Member
    2024 Tundra SR5 - 2001 Sequoia SR5
    https://parts.ourismantoyotaofrichmond.com/
    I got my ball joints from here. Is this a trusted source of genuine Toyota ball joints? It claims to be and as far as i can tell the ball joints themselves seem authentic. Just wondering if anyone has had any issues from this site?
    G_unit3000 likes this.
  7. Apr 28, 2025 at 4:58 AM
    Yes, that's one of a couple of dealerships who are very well known to this forum. Formerly known as McGeorge Toyota.
    txk131[QUOTED] and G_unit3000 like this.
