Need info on go rhino d6 extreme running boards
Discussion in '2.5 Gen Tundras (2014-2021)' started by Nasty2sss, Apr 27, 2025 at 9:11 AM.
  1. Apr 27, 2025 at 9:11 AM
    Nasty2sss
    Nasty2sss [OP] New Member
    Phil
    2016 sunsetbronze limited Tundra
    Leveling kit
    Im trying to install new running boards on my 2016 tundra double cab. After installation the boards are tilted up so the doors don't open.I installed these on my 2022 tundra and they were a perfect fit .Is it possible they sent me the wrong brackets? Any help would be appreciated.
  2. Apr 27, 2025 at 11:55 AM
    2014 Black tundra
    2014 Black tundra New Member
    2014 tundra sr5
    Call Go Rhino. It sounds like you got the wrong brackets or maybe the whole package is the wrong part number.
  3. Apr 27, 2025 at 1:58 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    By design. Can't ding the doors if you can't open them.
  4. Apr 27, 2025 at 2:57 PM
    Dukhnt
    Dukhnt New Member
    Totally off topic, but I really like the look of these. I'm assuming since you have put them on 2 different Tundras, you like them and are satisfied with the quality???
    Any preference over standard or wide?
    Thanks, and good luck!
  5. Apr 27, 2025 at 3:33 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Did you try loosening the bolts in the board mount and see if they would angle down?
    There is a lot of play in that bracket.
    Mine had a slight tilt down.
    BTW they are for sale in the marketplace forum.:thumbsup:
    [​IMG][​IMG]
    cartage1 likes this.
  6. Apr 27, 2025 at 4:16 PM
    Nasty2sss
    Phil
    Leveling kit
    Mine don't look like yours.Mine are angled on both ends.Yours are square in the front."m pretty sure they sent me a set for a crewman.I guess I'll find out tomorrow. I also have a 2022 tundra that I put the same running boards on and they fit perfect.With the set for the 2016 they tilted so much the doors won't open.
  7. Apr 27, 2025 at 9:50 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    Maybe they gave you the wrong brackets or steps..
    Here are mine off the truck if it helps..
    I just noticed mine are D1 steps, yours are D6.
    But the brackets look a little longer than yours..:confused:
    They sent me the same brackets they sent you for my DC.
  8. Apr 28, 2025 at 1:15 PM
    Nasty2sss
    Phil
    Leveling kit
    well all I know is the running boards are tilted up so high the doors won't open.I emailed real truck where I bought them but haven't heard back yet.Is it possible someone labeled the bracket box wrong.This is the first time something like this has happened.I installed running boards on all my trucks for 20 years.
    1lowlife[QUOTED] likes this.
  9. Apr 28, 2025 at 1:18 PM
    Nasty2sss
    Phil
    Leveling kit
    I think mine are standard.they have been on the other truck for 2 1/2 years and still look good, thats why I bought them for my 2016.The 2022 does stay in the garage tho
    Dukhnt[QUOTED] likes this.
  10. Apr 30, 2025 at 2:17 PM
    Nasty2sss
    Phil
    Leveling kit
    After 3 days of going back and forth with real truck customer service, they made me bolt the boards back on to brackets and take pictures, because I guess they thought I bolted them on wrong. Don't really know how you can screw that up.They finally came to the conclusion that the brackets that were sent to me are for a Tacoma.So they are going to ship out new brackets, but they are on back order and will take up to 4 weeks to get them.The customer service was very good as far as communicateing with me,I just hope this solves my problem.The box the brackets came in was clearly marked for a Tundra.I guess who ever pack it put the wrong brackets i
    1lowlife likes this.
  11. Apr 30, 2025 at 3:02 PM
    2014 Black tundra
    2014 tundra sr5
    It could’ve been an honest mistake. But I worked at a wheelbarrow company. (Which moved operations over seas. Yup, China. I hope the bastards go belly up.)I was mostly in the packing department. Yes, wrong parts do get packed. We really had to watch the new/ temps people. Some just didn’t care if they put the wrong parts in. Or if they missed boxes. But, it’s good to hear they’re making it right.
    Nasty2sss[QUOTED][OP] likes this.
