  1. Apr 26, 2025 at 12:07 PM
    WhitewaterTundra
    WhitewaterTundra New Member
    2003 Tundra Access 4x4
    My ‘03 AC got some freshies this week…started with a power stop brake caliper/rotor upgrade plus some new hoses. Huge difference in braking power, and got rid of warped-caliper wobbles.
    swapped fog light bulbs to LED, color match the headlights now and hopefully will help light up the dark rural roads I drive. Serious thinking about some ditch lights.
    Swapped into some new shoes yesterday…BFG KO3’s and they’re lovely, ride is smoother than the aging falken’s I was running from PO.
    Also figured out my spare is still original, manufactured in ‘02, and flat as can be. Unfortunately the tire shop couldn’t lower it due to seized cable, I soaked the unit from every angle with PB…gonna give it another day or two and try to get the spare tire down so I can replace it.
    Anyone dealt with a seized spare before have any tips for me?
    bmf4069, BroHon, Hutcheson and 2 others like this.
  2. Apr 26, 2025 at 1:27 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    If it truly is seized, you’ll be replacing it anyway as I did a few years ago. Just start cutting the spring away with an angle grinder being careful as the tire will eventually drop. Then going from up top you can remove the unit from the crossmember and install a new one. I have a Dorman unit on mine now.
    Also… we like pics! Pics or it didn’t happen :rofl:
    :worthless:
    oscardog86, bmf4069, BroHon and 4 others like this.
  3. Apr 26, 2025 at 3:03 PM
    WhitewaterTundra
    Haha ok ok.
    Here’s the only pic I took during brake job, I should have done some before/after pics, those old calipers were nasty looking, and the rotor had the most substantial lip on the edge I’ve ever seen. I did have to trim the dust shield a tad to fit the caliper, maybe 3/4” wedge on both sides (you can see one of the clipped pieces on the ground next to the drips of brake fluid).
    I know, things are a bit rusty in the background…spring weather is here and I’m going to start spending afternoons with a 6 pack and cleaning things up under there a little at a time.
  4. Apr 26, 2025 at 3:05 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    I made some progress on my bed swap. Engine hoist makes it so easy. Halfway there. Gonna clean up the frame while the bed is off and probably treat it. And clean the back of the cab.
    I swear the previous owner must have parked his truck at the bottom of a quarry or a riverbed. The amount of rocks and dirt I’ve cleaned out of the frame is insane!
    I’m gonna see if I can get the house in my garage and do the new bed with that cuz it’ll be much easier than with the 4 ratchet straps.
    Pics so far.
  5. Apr 26, 2025 at 3:15 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    That'll clean up just fine for an 06 and doesn't appear to need too much treatment.
    Hi06silver and G_unit3000 like this.
  6. Apr 26, 2025 at 3:42 PM
    WhitewaterTundra
    That’s a hot tip. I just went out and cut it all out, I’m leaving Wednesday on a road trip so my spare might have to live in the bed unless I can source a new hoist locally…the hunt it on.
    Surprisingly enough the cross member isn’t rusty much, I’ll clean it up a little bit and hit it with some paint tomorrow. image.jpg image.jpg
  7. Apr 26, 2025 at 4:44 PM
    I think I’ve got a spare if you want it
  8. Apr 26, 2025 at 4:59 PM
    Neo
    Neo New Member
    Alabama
    My brother's loan of his 02 AC came with the condition that it be available for seasonal and as-needed hauling jobs. Today, we used it to haul 2 loads of compost for his garden. Lined the bed with a tarp to minimize cleanup afterwards. The truck definitely rides better with a load, but three scoops from a front end loader really compressed those leaf springs.
  9. Apr 26, 2025 at 7:29 PM
    Hi06silver
    Hi06silver Fat. Thumbs.
    2006 DC 4x4 Waltrip
    :sadviolin::sadviolin:
    RIP. PHM.
  10. Apr 26, 2025 at 7:40 PM
    Hi06silver
    2006 DC 4x4 Waltrip
    Changed the oil, rotated and cleaned the shit outta wheels so I could put a coating on them in hopes of keeping brake of the inner wells. Man that's time consuming to clean.
    Also while changing oil noticed a leak. Sprayed it down with brake clean in hopes of chasing it down.
    Does it look like it could be coming from the figure 8 gasket? The hose that comes from.back.of oil/filter unit has a drip on the downside curve of it...I'll check tomorrow after some drive to see if anything is obviously more wet than other areas.
    bmf4069, BroHon and G_unit3000 like this.
  11. Apr 27, 2025 at 4:17 AM
    wtrbrdm
    wtrbrdm New Member
    Ben
    Eastern VA
    2006 Tundra DC Limited
    Yea I chucked them. All I have left are some SS3 and SS2 lenses.
    G_unit3000[QUOTED] likes this.
  12. Apr 27, 2025 at 7:34 AM
    Hi06silver
    2006 DC 4x4 Waltrip
    Not that you didn't see it but check those transition areas from box to frame. Looks like ya got some delamination on passenger side.
    Kimosabe[QUOTED] likes this.
  13. Apr 27, 2025 at 7:47 AM
    Hi06silver
    2006 DC 4x4 Waltrip
    I think I may have a hoist laying around. Been rolling with no.spare for a while. Planned on a full sized and matching wheel and didn't have the heart to put it under there. Not even sure it'll fit with the bigger tire anyway
  14. Apr 27, 2025 at 8:44 AM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    I went to Big Bear yesterday because I couldn’t make it to Sedona. It was sunny at first, but then it started snowing really hard and we got about 3 inches of snow with crazy winds. I wasn’t ready for it, and neither was anyone else, but it was still a lot of fun!
    Muddy trail
    Before the storm
  15. Apr 27, 2025 at 9:41 AM
    WhitewaterTundra
    I found a Dorman locally and I’m headed to pick it up this morning. I appreciate the offers but I’m trying to get this done today before my road trip!
    The ‘03 with fresh KO3’s. The PO put on 2” wheel spacers, I am going to take them off and run some 1”, maybe no spacers. I definitely don’t like the 2” spacers because the tires stick out past the flaps and the slightest road grime flips all over my truck.
  16. Apr 27, 2025 at 9:59 AM
    Nice cap!
  17. Apr 27, 2025 at 10:47 AM
    Had a great time at T2S with a bunch of the best gen crew. Truck didn’t seem to like the elevation and was running kinda weird under load, but once we got out of the mountains it seemed to be fine
    IMG_7916.jpg Master Tetris IMG_7917.jpg IMG_0663.jpgSan Francisco peaks got fresh snow the week before, so most stuff around camp was still messy and soupy
    IMG_7920.jpg IMG_7923.jpg Enjoying some fresh fish IMG_0752.jpg IMG_0761.jpg Took some convincing but the boys had fun “driving” IMG_0766.jpg cheesin IMG_0774.jpg IMG_7926.jpg IMG_0810.jpg IMG_0815.jpgPTFO IMG_7931.jpg got home and went to the neighbors house for a baby shower
  18. Apr 27, 2025 at 1:36 PM
    Openbaffle
    Openbaffle New Member
    Added a 1" block to the back. Sitting nice and level now. New U-Bolts installed.
  19. Apr 27, 2025 at 1:45 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    Got the new bed on without any drama. There’s a little spacer or something shaped like plug of some sort that goes in the back between the bed and frame. It kept falling out or moving and keeping the bed from sitting fully on the frame so I left it out. Love having the bed and bedliner in.
  20. Apr 27, 2025 at 1:48 PM
    Composite? Doesn’t look like pressure treated.
  21. Apr 27, 2025 at 3:36 PM
    wrenchvelo
    wrenchvelo New Member
    2000 Tundra TRD 4wd
    Ivan Stewart 2002 SEMA show, leather interior. Hellwig Anti Sway bar.
    Tested my anti-squat mods. When any significant weight was in the bed (aprox..<400 lbs), the truck would noticeably squat down on the back axle. Short trips it's manageable, but at night the headlights would shine significantly higher. I installed a Hellwig add a Leaf and a Larger bump stop on the axle. It worked well. Previously the truck would squat with one bike and gear loaded. I tested it with two bikes loaded on a trip out to the desert.
  22. Apr 27, 2025 at 3:38 PM
    Mr Badwrench
    Mr Badwrench New Member
    I had a really positive experience at Harbor Freight today. For what they lack in quality, they make up for in customer service. As much as I swipe at their products, they are the Walmart of tools. Absolutely no resistance or questions when exchanging broken equipment.
  23. Apr 27, 2025 at 5:06 PM
    grzzlr
    grzzlr New Member
    2002 AC V8 TRD 2x
    Finally replaced the blown out shocks/struts with bilstein 5100's. The install was a surprisingly easy and it feels waaay better now. Considering an add-a-leaf to level the back out and increase tension.
  24. Apr 27, 2025 at 5:44 PM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    How many miles on coils?
  25. Apr 27, 2025 at 5:48 PM
    Neo
    Neo New Member
    Alabama
    Husky custom all weather floor mats for the front of the 02 AC finally arrived. (These were necessary after I shampooed the carpets!) Got them installed. They definitely provide more coverage than the Weathertech generic fit mats. They could be an inch or so wider, but I like how the tread pattern breaks exactly where the mat tilts up near the firewall.
    Husky is apparently the only vendor who makes anything specifically for the rear of the 02 AC. These are floor liners, not mats, and they're made in two pieces. As mentioned on the Husky website, I did have to trim the driver side to accommodate the power seat. The driver side liner includes the portion that goes over the hump. The passenger side liner is a separate piece. These run all the way to the door jambs!
    Based on the stock photo on the Husky site, I thought they would ride up and cover the storage compartments. Obviously not. So, I used the generic Weathertech rear mats to provide a little protection there.
  26. Apr 27, 2025 at 5:52 PM
    grzzlr
    grzzlr New Member
    2002 AC V8 TRD 2x
    130k :)
    Filthyphil[QUOTED] likes this.
  27. Apr 27, 2025 at 7:49 PM
    Hi06silver
    2006 DC 4x4 Waltrip
    Where did ya buy the block from? A lot of what I've found on the Google machine searching for blocks have been what looks to be composite material.
    Kimosabe likes this.
  28. Apr 27, 2025 at 8:13 PM
    Nicklovin
    Nicklovin Yap Yap
    Huntington Beach, CA
    00’ 4.7 AC 4x4 - GFC
    Late to the blower party but I got 2 blower motors done today, tundra’s and a rav4
    Neither were that bad, thinking someone replaced the rav4 blower since the plastic isn’t faded at all
  29. Apr 27, 2025 at 9:10 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    Not to hate too much on the blocks, but it looks like your leafs could use a refresh. Is there a reason you opted of blocks over new springs?
    Great looking truck by the way.
    shifty` likes this.
  30. Apr 28, 2025 at 12:48 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    We missed you :wave:
    bmf4069 likes this.
