Y'all Wash Your Engines?
Discussion in 'Detailing' started by Matt2015Tundra, Jan 26, 2025.
  1. Jan 26, 2025 at 8:29 AM
    Matt2015Tundra
    Matt2015Tundra [OP] New Member
    2023 1794 CrewMax
    Perhaps it's a silly question, but do you guys and gals occasionally spray off your engine?
    I live in the country 7 miles from the nearest pavement. My engine compartment gets very dusty. I've always sprayed the engines off on previous trucks without problems, but I'm hesitant on my Gen 3 because of the insane amount of electronics.
    Am I worrying about nothing? Any tips or advice is welcomed.
  2. Jan 26, 2025 at 8:37 AM
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    2022 SR5 TRD Sport Crewmax White
    I do it normally like any other car. Just avoid spraying directly onto the ECM or fuse box.
  3. Jan 26, 2025 at 8:44 AM
    Matt2015Tundra
    2023 1794 CrewMax
    Thanks. If you don't mind, exactly where is the ECM located? I'm being lazy and don't feel like searching.
  4. Jan 26, 2025 at 8:46 AM
    Cruiserpilot
    Cruiserpilot New Member
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    I spray all my engines. I have a Gen2 5.7. Take the plastic shroud off. Don't spray hard onto any of the
    plastic boxes that protect stuff.
  5. Jan 26, 2025 at 8:48 AM
    Frank_TRD23
    Frank_TRD23 New Member
    Frank
    2023 Tundra TRD Mag grey
    1.5 Wescott lift 20" wheels on 37s Stillen Trucontroller
    Should be like any car. Spray don't pressure wash. Working on construction site, leaves my bay a bit dirty also. Been so tempted to buy one of the aftermarket hood with the hood vents(I know that sounds terrible to some) and worry about the rain.
    What do some use a a cleaner for the bay?
  6. Jan 26, 2025 at 9:52 AM
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    I like to use Koch Chemie Green Star in a Foam cannon.
  7. Jan 26, 2025 at 10:15 AM
    Matt2015Tundra
    2023 1794 CrewMax
    Thank you. I'll avoid spraying that area. I'm not hoping to eat off my engine, just want to knock the dust off, occasionally.
  8. Feb 9, 2025 at 5:45 AM
    dondino
    dondino New Member
    don
    2007 Tunda Crewmax
    Once a year, using Simple Green, a garden hose and a couple of brushes. It looks good for a couple of months afterwards.......detailing season here in NW Pa. is only 3 months off.
    ACDC2ZZTop likes this.
  9. Feb 19, 2025 at 4:50 AM
    T-Guy69
    T-Guy69 New Member
    Long Island
    Black 2020 Tundra SR5
    When I wash the car and rims, I sometimes open the hood and wash the engine bay with the same car wash. I have been known to spray some parts with Griot's Garage 3 in 1 Ceramic Wax.
  10. Feb 19, 2025 at 7:10 PM
    Steplift20
    Steplift20 New Member
    2018 Tundra
    I do not, I do wipe it down with a rag but don’t spray water on it
    I would like to but if it screws up something my wife would yell at me and say
    You should never hose or clean your engine. Now look your truck is not starting. You dumb @$$
  11. Feb 19, 2025 at 7:19 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Guy I know takes like a gallon of purple power and soaks the engine and then climbs in there with the pressure washer on full blast and goes to town and says he's never had an issue, I have trouble following that methodology so I leave the pressure washer on the "idle power" and rinse it down.
  12. Feb 20, 2025 at 5:46 AM
    Steplift20
    2018 Tundra
    I used purple power on my boat hull to remove black streaks and washed the deck with it
    I bought it at Walmart just to try it but the best degreaser I ever used so far is awesome from the dollar tree
    I get the quart for $1.25 with ou5 5he spray top . I use my own bottle. So for quarts makes a gallon $5.00 a gallon. It’s the best so far. But if I was going to wash my engine I would use joy liquid soap
  13. Feb 20, 2025 at 5:47 AM
    Steplift20
    2018 Tundra
    Hey takievo is that a hybrid?
  14. Apr 27, 2025 at 7:49 AM
    75tranzam
    75tranzam New Member
    Midlothian, Va
    2024 Midnight Black 1794 Limited Edition #751
    I use ArmorAll foaming tire cleaner on the engine and engine compartment then I just rinse it off. Leaves a nice shine on plastic bits and hoses. I don’t use a pressure washer, just the hose so that I don’t force any water into the electronics.
    ATV25 likes this.
  15. Apr 27, 2025 at 7:56 AM
    EmergencyMaximum
    EmergencyMaximum New Member
    What about all those connectors with wires going into them? I am super worried that if I wash mine, next day it'll do click click and not start anymore. So much sensors lugged in everywhere!
  16. Apr 27, 2025 at 8:25 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    I never voluntary add any water to electric circuits.
    Put floor fan at the side on max, blow dust off with compressed air.
