AC Button Light Blinking-no cool when it’s doing so
Discussion in '1st Gen Tundras (2000-2006)' started by Inky, Apr 26, 2025.
  1. Apr 26, 2025 at 8:33 PM
    Inky
    Inky [OP] New Member
    2005 Tundra Limited AC & 2006 SR5 AC
    Hello Proud 1st Gen owners :) I recently pulled my stored (from winter) out & subject dilemma has occurred. Reading some of the forums here- sounds like it could possibly be a A/C relay.. I looked in the under hood fuse box and can’t identify a relay related to this. Have attached a pix of the underside of fuse box cover. Any input is Greatly Appreciated ! Kind Regards
  2. Apr 26, 2025 at 10:30 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Yes, relay would be my first stop...
    I believe on your Gen, you won't have a specific relay for just the AC and will need to check the Heater relay as it cover the AC as well...
    NewImprovedRon likes this.
  3. Apr 27, 2025 at 4:23 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Have you or anyone done some timing belt work recently ? Sometimes folks will forget to put or tighten the ground at AC compressor.
    As was mentioned, your Heater relay is a good place to start and as noted on your fuse cover, it will be the bottom one labeled HEATER
    shifty` and Tripleconpanna like this.
  4. Apr 27, 2025 at 7:52 AM
    This was the case with two or three cases I helped out with here in the past. I can dig up one of them with pics if it helps @Inky
    KNABORES likes this.
  5. Apr 27, 2025 at 7:45 PM
    CC80guy
    CC80guy New Member
    Larry
    Lehighton, PA
    Yeah, check the ground screw on top of the compressor and make sure it has good contact and is tight. I went nuts trying to fix mine until I noticed that screw was loose one day. Tightened it up and all better.
  6. Apr 29, 2025 at 4:12 PM
    Inky
    Yep ~ ground wire wasn’t screwed back down ! Had timing belt replaced last fall- before tucking it away for winter hibernation. The ol girl has 252k on odometer & going strong :) Really Appreciate all of your guys’s input!! Ill LOVE these 1st Gen’s 4ever
    Tripleconpanna, KNABORES and BubbaW like this.
