Damn, 6.2’s make gen3 recall seem minor
Discussion in '3rd Gen Tundras (2022+)' started by BoulderGT3, Apr 25, 2025 at 1:21 PM.
  1. Apr 26, 2025 at 5:17 PM
    WNY PAT
    WNY PAT New Member
    Western New York
    2017 Crewmax Limited (Mines) 2019 Crewmax SR5 (Work)
    Gotta assume the motor has a serious design flaw / design issue and something happened (or is likely to become public) that led the liability bean counters to recommend the stop sale. I’ve been looking at Sierras and would definitely buy the 3.0L Duramax over the 6.2. The 6.6 Duramax is well sorted out, but a pricy option.
    cartage1 likes this.
  2. Apr 26, 2025 at 5:22 PM
    WindChillYeti75
    WindChillYeti75 New Member
    2025 WCP Limited TRD Off Road iForce Max
    See I was looking at the 3.0 duramax too, but I’ve heard that short tripping them isn’t good and is a no no. My wife would be driving it mostly and she often makes short trips to grocery stores and runs errands and stuff for the kids. So I’m torn between the 5.3 / 6.2 or the expedition max.
  3. Apr 26, 2025 at 5:37 PM
    6.6 is practically the same as the 6.2 minus the DOD or AFM. The cams are interchangeable even. Different intake and exhaust profiles that favor more torque for the 6.6.
  4. Apr 26, 2025 at 5:37 PM
    WNY PAT
    WNY PAT New Member
    Western New York
    Yes, short trips aren’t the best for modern diesels from what I understand. I’ve been seeing some rumors that the Excursion might return with the Godzilla motor in the next couple of years, it who knows. A new Excursiom would be a compelling option for full size SUV buyers tho!
  5. Apr 26, 2025 at 5:39 PM
    WNY PAT
    WNY PAT New Member
    Western New York
    That damn AFM system, it was to blame for the oil consumption issue in my 2007 Sierra 5.3. Wonder if those systems are somehow the culprit here too.
  6. Apr 26, 2025 at 5:41 PM
    The regen cycle for the DPF is the problem. Requires a long enough drive to complete. It’s on a schedule. If you start a regen cycle and it doesn’t finish, it tries again next time. The absurdity of it is that it basically burns more fuel to heat up the DPF making the engine less efficient during cycles.
    WNY PAT[QUOTED] likes this.
  7. Apr 26, 2025 at 5:43 PM
    The AFM / DOD system is oil pressure driven, as is the VVT setup. So there’s a system of oil ports that use the oil pressure like a hydronic system to activate both systems. Paramount to use the DEXOS rated oil in order to perform as designed. The oil pump is also a variable pressure pump. It’s a cool piece of engineering that is undone by poorly manufactured / poor quality material parts.
  8. Apr 26, 2025 at 5:50 PM
    Mr Badwrench
    Mr Badwrench New Member
    EVERYTHING is garbage now. It's not just a couple or few, it is everything.
    And you have to pay $40,000 for the privilege to own your garbage, plus insurance and taxes on your garbage. Yeah, 40k, what can you even buy for 40k?
    Nothing new either, this has been going on for at least 10 years.
  9. Apr 26, 2025 at 5:53 PM
    $60k is the new $40k
  10. Apr 26, 2025 at 6:04 PM
    Mr Badwrench
    Yes. That's the problem.
  11. Apr 27, 2025 at 1:04 AM
    RLHULK
    RLHULK Too many gamma rays in all that BBQ smoke.
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    Going on 30k on the 2022 Silverado LT with the 5.3 I am currently in.
    No issues. The chip for the AFM/DFM is absent from the factory, so hopefully thats a plus, which I believe it is.
    So far its been a great vehicle. I dont haul or pull anything notable tho.
    Oh and the seat trim is still intact and solid, who would have thought.... LOL.
    OldGuy03, ColoradoTJ and Black Wolf like this.
  12. Apr 27, 2025 at 2:05 AM
    woods
    woods New Member
    2021 SR5 TRD Sport
    They are not included. It ends in 24. They said they fixed the problem in the tooling for the new ones.
  13. Apr 27, 2025 at 3:54 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    Question
    what caused the recall?
    Toyota finally fessed up and said debris
    What is the gm issue
    bearings just don’t fail
    OldGuy03 likes this.
  14. Apr 27, 2025 at 3:58 AM
    Blufin
    Blufin Seasoned member
    Bob
    23 Capstone
    Because enough people complained out the elephant in the room.
    Your asking about GM right?
    nobodyintexas likes this.
  15. Apr 27, 2025 at 4:16 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    No
    what mechanical issue caused the recall?
    is it bad bearings
    is it poor fitment
    is it UAW labor?
    I thought this was the lifters collapsing, but this is different
  16. Apr 27, 2025 at 5:49 AM
  17. Apr 27, 2025 at 5:58 AM
    2WD
    2WD New Member
    21 Army Green CM SR5 TRD Off Road
    I did not know they were so closely related. Yet I don;t think anyone is reporting this problem on the 6.6’s and they aren’t part of the recall.
  18. Apr 27, 2025 at 6:05 AM
    Fatone
    Fatone New Member
    2022 Tundra TRD Sport Premium
    Pretty much every GM major engine family has a skeleton in its closet. 5.3 (valve rattle), 3.6 (internal oil leak) 6.6L Duramax ( European fuel pump trashing engine), any turbo engine turbo failures, 6.2 problem listed here. GM has had so many bad engine gasket issues I have lost count
    Sure you get the antidotal mine ran 400k. But GM as an engine builder has a higher than average catastrophic failure or severe issue rate. So avoid them or transfer the risk with an extended warranty
    My experience is GMs response is linear with what you spent as well. Never buy a cheap GM vehicle they piled rebates in; they will never fix it
  19. Apr 27, 2025 at 10:04 AM
    WNY PAT
    WNY PAT New Member
    Western New York
    Jags
    The 6.6 Duramax / Allison is the best HD diesel powertrain right now by a long shot. Isuzu design, well sorted out and very few major issues.
  20. Apr 27, 2025 at 10:12 AM
    #50
    pursuit2550
    pursuit2550 New Member
    2020 Tundra SR5 Maggie 1900
    Yeah well, GM thought it would be a good idea to manufacture the "Allison" themselves, we will see how long they last.
    Breathing Borla likes this.
  21. Apr 27, 2025 at 10:24 AM
    #51
    pursuit2550
    Problem is people keep buying the garbage they put out. One of the reason I didn't give into the new tundra. Not to mention Toyota wanted double my current lease payment. Yeah, like the 3rd gen was worth double, insane. Friend at work just bought a 25 Tahoe even though he knows about the lifter issues. That's what I cant grasp. You know there is a problem but your willing to risk $70k that you vehicle isn't one of them, mind blowing. The videos I have seen lately of the amount of garbage they are putting in these vehicles is ridiculous. They will NOT hold up for long term.
    ZappBrannigan likes this.
  22. Apr 27, 2025 at 10:28 AM
    #52
    WNY PAT
    WNY PAT New Member
    Western New York
    It’s not the same 10 speed that Fordband GM co-developed. Same deal as the ZF in the Ram.. designed and built to specs. The Allison / 6.6 Duramax has a great track record thus far.
  23. Apr 27, 2025 at 10:42 AM
    #53
    pursuit2550
    Like I said, we will see how long they last. GM hasn't fixed the AFM issue since 07 when it came out. I just bought a 98 Z71, it doesn't have seat warmers or messaging seat, or any fancy electronic tech, but what it does have is a good old American iron block 350. To top it off, I dont need to be a rocket scientist to change out an alternator or starter, etc. Like Badwrech said, what they are putting out is garbage. I want to see what a 2025 vehicle will look like in 30+years, if they make it that long.
  24. Apr 27, 2025 at 11:48 AM
    #54
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Keep that 98, sort of miss my old 97. Fuel pump was most common culprit, easy fix, everything else was simple too.
    pursuit2550[QUOTED] likes this.
  25. Apr 27, 2025 at 3:17 PM
    #55
    Miss my 95 Short wide manual and my 98 X-cab stepside. When Chevy was the deal for sure. Even my 2001 V6 manual short wide was a great truck.
    pursuit2550 likes this.
  26. Apr 28, 2025 at 9:19 AM
    #56
    2WD
    2WD New Member
    Polo08816 and ColoradoTJ like this.
  27. Apr 28, 2025 at 10:35 AM
    #57
    Could you imagine going 70+ mph towing 15000 lbs and that crap happened?
    There is an aftermarket fix that will run 1700-2700.00 depending on who you trust/use.
    I'm not doing this again. I did a CP3 conversion on my current DM to help stave off disaster and 12000.00 coming out of my pocket. That cost 1750.00 and a few days of my time.
    If these manufactures can't get their junk designed right the first time...I have different options for sure.
  28. Apr 28, 2025 at 11:08 AM
    #58
    22whatwedo
    22whatwedo New Member
    The Open Road
    22 SR5 TRD OR Army Green
    Probably the 2.7 turbo actually. About the same performance as the 5.3 with no AFM.
  29. Apr 28, 2025 at 7:06 PM
    #59
    2WD
    2WD New Member
  30. Apr 28, 2025 at 7:21 PM
    #60
    yakeng
    yakeng 3URFE Apologist
    A ZF transmission mated to a deleted Cummins is very tempting. If it wasn’t for electronic issues RAM often suffers with, I think it would be an interesting platform. Looks good too.
