Baja Design 40" S8 & SDHQ Hood Bulge Mounting Bracket clearance question.
Discussion in '2.5 Gen Tundras (2014-2021)' started by brkncly, Mar 22, 2025.
  1. Mar 22, 2025 at 6:15 PM
    brkncly
    brkncly [OP] New Member
    Oregon
    I'm installing a Baja Design 40" S8, using the SDHQ hood bulge bracket kit. I've cut the sheet metal supports & cut the require 5/8" on the outer of the hood bulge opening. I'm ready to drill the two 1/4" holes using the provided template, the directions really tell you how to line it up. After reading some posts about installing this, people are having the a hard time getting the hood bulge to snap tight to the hood some are stating that they have had there hood bulge crack. Some are saying to elongate the holes, really don't want to do that, would like to lay it out correctly the first time. Wanted to know if I need to put drill the holes back further than the instructions says? Anybody that has done this, can you please give some advice before I drill the holes. Really don't want to make swiss cheese out of my hood. I read somewhere to use the factory holes then mark for the second one, will this be enough for clearance? SDHQ directions for laying out is horrible. Did you guys drill out the three 3-1/4" per directions to install the bolts? Going to wait till somebody chimes in before I drill. Any suggestion for those of you that have installed this help would greatly appreciated. Thanks
    coTony and BillyB like this.
  2. Apr 23, 2025 at 6:13 PM
    SoCal760
    SoCal760 New Member
    San Diego
    I installed this and some issue ocurred including hood struts to light to handle the weight and the bulge pulling up on freeway but fixed with some tie down washers.
  3. Apr 23, 2025 at 10:23 PM
    BillyB
    BillyB New Member
    Billy
    AZ
    2021 SR5 TRD Sport 4x4
    I know this post is over a month old, but I just did this mod a few days ago.
    When I had the bar mounted and sitting as high as it could in the bar mounts, I had slight issues with the bulge not wanting to seat all the on the far edges where you actually use the factory snaps. So, I adjusted the bar to sit a little farther down, about halfway or so, and the bulge fit perfect.
    Also, on one side, I actually drilled two holes for the mounting brackets before I got to the other side and realized I was probably supposed to use the hole that was already there, and one that I drilled. Still worked just fine even with one side not totally correct.
    I did do the three 3-1/4 holes. That part was the hardest part of the whole project. Mostly because of the holesaw jerking, and of course sawing upwards is tiring and difficult. Use both hands and don't apply much pressure. Just let the holesaw do it's cutting slowly. Buy a brand new holesaw bit, it'll help. I used a Milwaukee one.
    bulldog93 likes this.
  4. Apr 24, 2025 at 4:12 AM
    WinterWarlock21
    WinterWarlock21 New Member
    South Jersey
    2016 Quicksand TRD Pro CrewMax
    https://gearproject.co/profile/SandShark21
    Had the same issue with my hood struts not being able to handle the weight ,albeit I installed a rigid light bar, as socal said too. My bulge also would pop out at highway speeds 60 mph+. I glued in the plastic things and had no issue going forward. Was tired of both issues and eventually removed the light bar and bought a brand new color matched bulge. I do have a dual 40 inch in my bumper so I didn’t need another one in the hood. I also didn’t think the 40 rigid gave off that much light neither compared. Should’ve went Baja designs to begin with. Maybe I’d have a different opinion.
    If I had a brand new 2.5 gen I would’ve never done it to begin with. It’s a cool idea, just not for me when you can fit a 30 inch in the bumper and throw on some small ditch lights.
    i had a RIGID Industries SR-SERIES PRO 40" SPOT MIDNIGHT 940214BLK fwiw. My curved 40 inch dual row in my bumper is a black oak led.
    good luck!
  5. Apr 24, 2025 at 4:55 AM
    I installed mine a couple of years ago. It definitely takes patience. I had alot of bulge on and off until I had the bar where I wanted it. I also have the screen on mine as I did not like the open area and gap between the bulge and the bar.
  6. Apr 24, 2025 at 7:18 AM
    BillyB
    BillyB New Member
    Billy
    AZ
    That's a bummer. I love the mod. It compliments my lower lights very, very nice.
  7. Apr 26, 2025 at 1:56 PM
    therealjonwick
    therealjonwick New Member
    JR
    2019 OR
    Asked a lot and have had zero luck… seems doing a lightbar in the bumper is a no go with bumper shims. The brackets don’t work. Don’t want to remove the shims due to my tire plans. This is the only other thing I can think of trying zroadz light bracket. Seems id also have to modify it a bit to make it fit. I’d put some pods I want on it. Or just say F*** it and get the Ironman 4x4 bumper with the lightbar. Don’t really want to spend that at the moment.
  8. Apr 26, 2025 at 2:15 PM
    Maybe have some brackets made?
  9. Apr 26, 2025 at 2:35 PM
    therealjonwick
    JR
    2019 OR
    That would be great. No clue who could do that for me in my area. I’ll have to start researching.
  10. Aug 23, 2025 at 8:55 AM
    coTony
    Tony
    Montrose, CO
    It really amazes me that SDHQ still prints that shit and when you call them they ALWAYS give you the option of them installing it at their prices. The brackets are nothing complicated at all, just an L shape with holes.
    I have a failed hood bulge I kept for a jig. I also used a piece of metal flat bar found in the hobby section of Ace Hardware and I shaped and cut it to fit at the piece that contacts the hood on top to keep that from bowing and making the look more professional then Gorilla glued it in.
    Before anyone asks for pics I will apologize for not having any pics. When I did this I lived in Arizona and it being HAF I. The AZ heat and the mess with the glue I have no pics. The hood bulge I used for a jig is in my storage shed. Then the big delay is that I got my neck worked on from C3-T2 yesterday and I am a sore MoFo today and not being able to do much for a while at only 10 lbs of lifting.
