General Supercharger Thread
  1. Apr 24, 2025 at 2:49 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Make us a better option for the front of our pigs
    nags, Wynnded and HulkSmurf14 like this.
  2. Apr 24, 2025 at 2:53 PM
    snivilous
    SW UT
    300k+ Supercharged 2008
    I did, the thread is called "DIY trans cooler for $300" :D
    koditten, Tripleconpanna, Mdl and 9 others like this.
  3. Apr 24, 2025 at 2:56 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    LOL the people want billet bro it's the new thing like AI
  4. Apr 24, 2025 at 7:12 PM
    NatesNightMare
    NatesNightMare Is what it is
    Pinetop Az
    I just want to upgrade my stock cooler lol
  5. Apr 25, 2025 at 6:05 AM
    nags
    nags New Member
  6. Apr 25, 2025 at 6:06 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
  7. Apr 25, 2025 at 11:56 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    I finally got the pistons knocked out. Three of them wouldn't rotate past the residue, but using a red scotch brite with a lite touch I was able to clean them up and knock them out as well. The crank spins smoothly and the rod journals look great. There doesn't appear to be any cylinder wall damage. I've got some honing oil on the way and will use a flex hone to clean up the cylinders so the new rings will seat properly, but I think I'll be able to use this block without sleeving.
    After I flex hone it, I will measure the bores with my dial bore gauge set and that will tell me if the bores need any machine work. I know they can't be bored out, but I've had success previously on a 1GRFE and a light hone and they have the same liner thickness. I will take the block and heads to a shop anyways as I'm putting in main studs and larger valves that will require a line hone on the mains and enlarging the valve seats.
  8. Apr 25, 2025 at 12:02 PM
    HulkSmurf14
    2014 Tundra Limited
    Fingers are crossed!! Great progress and keep it up!!
    Tripleconpanna, Mdl and armyoffoo like this.
  9. Apr 25, 2025 at 12:11 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Almost forgot, I received the 8HP90 on Tuesday, and the CANTCU was delivered today. I'm still waiting on Domiworks adapter and cantcu/8hp harness shipping, and I'll need to find another source for the shifter as Toyota said it's not in stock and they have no date estimate. I'll probably pick up a used one off eBay if I can find it.
  10. Apr 25, 2025 at 12:15 PM
    HulkSmurf14
    2014 Tundra Limited
    That's a huge b!tch!!! She goin' fly!!
  11. Apr 25, 2025 at 12:22 PM
    Jowett
    Jowett New Member
    North Adams, MA
    2011 Regular cab long bed 5.7 Work Truck Package
    Many on the way.
    The aftermarket sells multiple overbore sizes, so someone has found that over boring can work.
    e30cabrio, Mdl, Wynnded and 2 others like this.
  12. Apr 25, 2025 at 12:24 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Thank you, that's great news!
    Mdl and HulkSmurf14 like this.
  13. Apr 25, 2025 at 12:38 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
  14. Apr 25, 2025 at 1:27 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    That is good to hear. I was just going by the lextreme tear down from years ago. Plus most want a 6.0 or 6.8.
    reywcms likes this.
  15. Apr 25, 2025 at 2:22 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    What's the most cost effective (budget) way to rebuild a not-blown motor?
    I'd like to get the original motor done so I can use it now & then do the go crazy later on the 70k smoking motor.
  16. Apr 25, 2025 at 2:26 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    I'd say forged pistons and rods, head gasket and head studs would be minimum, bearings if needed. Pistons and rods to handle the power, HG and studs to keep the heads in place when cranking the boost.
    reywcms, M3Tundra-JK, Wynnded and 2 others like this.
  17. Apr 25, 2025 at 4:02 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Does anyone have pictures of the ECU out of the truck and the gasket/mount removed? I'm planning on making a mount for the Boomslang harness adapter that will mount to the firewall in the stock ECU location, so from the engine bay it looks like the stock connections instead of a rats nest of wiring...
  18. Apr 25, 2025 at 4:12 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    The ECU side or firewall?
  19. Apr 25, 2025 at 4:13 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Thank you! Does the ECU fasten to the outer metal piece, or is it all one piece?
    reywcms likes this.
  20. Apr 25, 2025 at 4:21 PM
    e30cabrio
    Here is front
    4 screws.
    HulkSmurf14, Wynnded and armyoffoo like this.
  21. Apr 25, 2025 at 4:25 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    It has some semi tacky white fipg but could be slide out of the housing. The male plug portion has the white goop holding it in too.
  22. Apr 25, 2025 at 4:32 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Thank you both, that helps! I should be able to come up with an adapter to get the harness to screw to that. The harness has a channel around the part the stock engine plugs go into, but no screws, so I'll have to make a metal adapter that fits into the channel and attaches to another outer panel that screws to the firewall...fun times. Once I get that worked out, next hurdle will be mounting the stock ECU behind the dash...somewhere.
  23. Apr 25, 2025 at 5:03 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Here's what I'm thinking...inner will be two piece so that it can slide into the channels and held in place by screwing to the outer panel, the outer will fasten to the firewall...not to scale
    HulkSmurf14, Mdl and e30cabrio like this.
  24. Apr 26, 2025 at 8:45 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    I verified that the SCOL coupler is the same thickness as the Harrop stock coupler (much tighter fit than stock), and opened up and smoothed out the snout a little bit around the throttle body mounting flange so the 103mm matches up with the snout.
  25. Apr 26, 2025 at 8:53 AM
    HulkSmurf14
    2014 Tundra Limited
    Oh man, that'll aide in longer smiles, for sure!!
    armyoffoo and Mdl like this.
  26. Apr 26, 2025 at 9:28 AM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    Any damage to the stock Harrop coupler?
    I hope those firecrackers make it into a video showcasing engine upgrades.
    HulkSmurf14 likes this.
  27. Apr 26, 2025 at 9:32 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    There was a little play in the coupler, like the holes were loose, was easy to remove, but no noticeable damage though. It's a hard plastic piece, no spring like the one I had on my Tacoma's TRD SC.
  28. Apr 27, 2025 at 8:14 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Coupler did NOT solve the knocking sound. Starts and idles for about a minute before the knocking starts. Video of sound is below.
    https://youtu.be/y4cm_ln_lpk
    HulkSmurf14, Saltyhero13 and Wynnded like this.
  29. Apr 27, 2025 at 8:27 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Well shit. That annoying wondering if it’s rotor play bearing issue.
  30. Apr 27, 2025 at 8:28 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    I was leaning that way as well, I've emailed Harrop support and linked the video...we'll see what they say.
