Air Bags with Lift Blocks
Discussion in 'Suspension' started by birdman076, Apr 23, 2025.
  1. Apr 23, 2025 at 5:50 AM
    birdman076
    birdman076 [OP] Bird, bird, bird...bird is the word
    Chuck
    Montana
    2015 Brown Tundra Crew Max Limited
    Airbox with K&N Filter, 2" lift on 33's, Alpine iLX-F309 head unit, Pull out bed tool boxes, brown with black trim, rims, etc, black leather interior, matching topper. Muffler delete (too loud..) 62k miles!!!
    Quick question I'm sure has been answered before but I didn't find anything in the search. I'm looking at air bags as I do a lot of hauling (Water, hay, wood, etc). Currently the truck has 2" lift blocks of the cheap variety that I cannot stand as they have no locating pin at the bottom so they had been shifting around with the sub par u-bolts the previous owned reused a bunch of times. I replaced the u-bolts and they have been stable but I'm still wanting to replace them with a better option or if the air bags essentially replace the lift blocks then I'm good with that as well.
  2. Apr 23, 2025 at 8:38 AM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    Airbags + hauling = :thumbsup:
  3. Apr 24, 2025 at 2:14 PM
    2014 Black tundra
    2014 Black tundra New Member
    2014 tundra sr5
    image.jpg I have airbags and lift blocks. It works for me. I also put in an RC airbag cradle. The airbag is not attached on the bottom. So, if you raise the truck off the ground (a lift or suspension flex) it won’t rip or tear the bag. The cradle did give me more rake so I had to put less air in the airbags.
    whodatschrome likes this.
