  1. Apr 23, 2025 at 6:32 PM
    notlikejohnny
    notlikejohnny New Member
    Shenandoah Valley, VA
    2005 4WD DC Limited, Phantom Grey
    Definitely a whistle, like a tea kettle, or ringing in the ear high pitch.
    starting to drive me nuts!
  2. Apr 23, 2025 at 6:43 PM
    shifty` Oh, I have felt Cobain's sarcoma
    Cap the F B J! Nobody wants to be fabby! ;)
    JakeJake[QUOTED] likes this.
  3. Apr 23, 2025 at 10:11 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Out with the old and in with the new!
    Was getting annoyed with the mounting of my trailer brake controller and decided to upgrade to a more minimalist footprint controller so I bought the Tekonsha. Love the look and ability to have a few set trailers in it with the Bluetooth. Was a little bit of a pain to find a spot that I could mount it as the rear of the unit is fairly deep and needs space.
  4. Apr 24, 2025 at 5:02 AM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    I have a 30 amp fuse assembly just like the one on your battery terminal, I assume it's just factory tow package stuff from the earlier trucks.
    Dblock500[QUOTED] likes this.
  5. Apr 24, 2025 at 5:28 AM
    Dblock500
    Dblock500 New Member
    DMV
    2002 SR5 AC 4.7 V8 4WD
    Yeah that seems to be the most likely case based on what others have observed as well. But could be on other occasions that it was also part of the older curt kit installs.
    Tried measuring the tailgate end that I posted earlier that was just hanging the whole time with my neighbor who is an electrician with tons of tools, legit contractor grade multimeters, etc. Weren't able to get a reading on it unfortunately, so may have to wire it up from square one. The harness could just be dirty and grimy since it's been dangling with no cover for who knows how long. We didn't spend a ton of time on it so we'll probably get a better look at it again
  6. Apr 24, 2025 at 5:30 AM
    Trace it back from the dangle. You're liable to find someone either disco'd something, or spliced it poorly.
  7. Apr 24, 2025 at 5:48 AM
    Dblock500
    DMV
    The dangled/open end is part of a split thats connected to the tailight, it then splits and runs up the frame to towards the battery, and another line goes to the hitch 4 pin connector as pictured. I don't know why the dangling end was open to begin with though
    The bottom of this picture shows the line going to the trailer hitch 4 pin connector before the picture cuts the actual connector off from view
  8. Apr 24, 2025 at 8:18 AM
    TUNDRAH
    TUNDRAH New Member
    Tacoma, Washington
    2002 Tundra SR5
    2" spacer level 285/70/17 Falken Wildpeaks
    Rust repair. Still need to sand and bondo but looking good. IMG_20250421_134028.jpg IMG_20250423_162234.jpg IMG_20250423_182018.jpg IMG_20250423_184747.jpg
  9. Apr 24, 2025 at 8:21 AM
    FiatRunner
    FiatRunner 2003 rich
    Jack
    Chicago Suburbs/Milwaukee
    Looks good! I'm pretty scared of what might be underneath my fender flares...
  10. Apr 24, 2025 at 8:27 AM
    Oh yeah, they totally used ScotchLoks on that 4-pin pigtail. Damn, that sucks. I'd probably peel the tape off, see how they got into it, remove any splices, cut/solder the wires, liquid electrical tape, then re-wrap.
    Looking at the video you posted, I'm assuming that dangly connector in your first picture is this guy, and someone pulled it out of that plastic insert, eh? I pulled the install doc for the Curt package in that video but sadly it doesn't show the wire layout of that connector to know what should be doing what. (more info after this pic)
    I know you said your neighbor helped with a DMM. But ... things to consider. First, on that connector, if I look at the Curt pictures, it looks like the only thing that would have constant power to test on that OEM connector would be the center pin BUT it'd only have power if you had that short tether at the battery side connected. Clearly, Curt's connector is only picking up on four wires on that OEM harness with the arrow I put above. Those are here (but will obviously be reverse-image on the OEM connector - and again, more after the image):
    Worth noting something else. If you are testing at the OEM end of the harness on the 5 "outer" pins (i.e. all but the center pin) you see in my last image there, you probably won't see voltage on any of them unless, for example, you've got the hazards on (two pins should be alternating power), or the brakes are mashed (one pin should show constant power while brake pedal is pressed).
    So I guess I'd ask you: When you and the NASA scientist were testing for voltage at the OEM connector, did you have something wedged under the brake pedal, and the hazards flashing? Did you test that center pin while feeding voltage into the little grey harness next to the battery?
  11. Apr 24, 2025 at 8:31 AM
    Pinch weld rub lines, or no? (I assume these were on the front at some point and got rotated back)
    I ask because my 285/70r17 had same issue, see the right-hand side of the old tire here.
  12. Apr 24, 2025 at 8:34 AM
    TUNDRAH
    TUNDRAH New Member
    Tacoma, Washington
    2002 Tundra SR5
    Fortunately not, those lines are just from cleaning the rust and debris the fell onto the tire after removing the fender flare. I still don't have any rubbing from the tires but I expect that will change once I move to 5100 struts
    shifty`[QUOTED] likes this.
  13. Apr 24, 2025 at 9:16 AM
    Dblock500
    DMV
    OK, will try to cut the tape and see what is going on and/or cut and resolder if needed. May end up just rerunning a line and fuse from the battery just to not deal with it though. And yeah that's what I was assuming too, but then there's another connecter plugged in there on mine--which is what is throwing me off. We only briefly tried checking the dangling connector that does not have those same 5 pins so far. Will have to do a deeper dive into it probably tomorrow when I'll have all the stuff in to hopefully complete this project anyway.
  14. Apr 24, 2025 at 9:21 AM
    I guess I'm not really understanding what's going on with the wiring then.
    If it were me, knowing how to use a DMM, I'd probably...
    • Locate the grey connector beside the battery that was used for factory tow package, shown in that video
    • Apply a signal to it, I assume it only has one terminal inside, maybe use alligator clips to clip on its terminal, then clamp the other end to the battery terminal
    • Go to the back of the truck and test the (I assume center pin) of the connector I put an arrow on to see if +12v is showing, but for shits and giggles maybe test the rest too, in case the center pin isn't what's hot
    • If you have power, you know the wiring is correct, and the Curt system you posted in that video will work for you
    There are other ways to test this, if there are two terminals on either end, like shorting one end of the connector at one end, then testing for continuity on the two corresponding terminals at the other end, but if that power feed is a 1-wire, then ... there's nothing to bridge, other than bridging that single wire to something you can read, i.e. +12v
  15. Apr 24, 2025 at 10:07 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Did you and your bud happen to check the 30A fuse ?
    Looking into that further, that is indeed the same type inline fuse and harness Toyota provided.
    Also attached TSB AX006-02 dealing with wiring harness for 7 Toyota vehicles.
  16. Apr 24, 2025 at 10:07 AM
    Dblock500
    DMV
    That makes 2 of us haha. But I don't think the connector you pointed out in the picture is the same as what I have dangling (which is the one I checked). The dangling one is a female end without the pins in it. I need to just follow like what the video shows (which I didn't do yet, I was curious about this open/dangling connector) and what you're saying. I can overcomplicate/think things by being too curious sometimes smh
  17. Apr 24, 2025 at 10:15 AM
    Dblock500
    DMV
    ahhh, thanks for pulling that. We did not, will do a more thorough check of everything tomorrow and hopefully get it all done
    BubbaW[QUOTED] likes this.
  18. Apr 24, 2025 at 12:00 PM
    FiatRunner
    Jack
    Speaking of towing- my truck does not have a hitch, and I will need one this summer.
    OEM ones are still available but cost $60-100 more than an aftermarket one. Worth it? I like how close the OEM one tucks below bumper and stays hidden behind it.
  19. Apr 24, 2025 at 12:09 PM
    NickB_01TRD
    KY
    Don't you have to have the right bumper support for the OEM hitch? I was thinking maybe they were different but I'm not for sure. Did your truck ever have a hitch on it?
  20. Apr 24, 2025 at 12:16 PM
    FiatRunner
    Jack
    I don't think the truck has ever had a hitch. I've got a brand new bumper and the whole support assembly for it, but isn't that just for the bumper pull hitch?
    Edit: can I put a 2" receiver on the support for the bumper?
  21. Apr 24, 2025 at 1:37 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    I found a used curt one for mine. No issues.
  22. Apr 24, 2025 at 7:09 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    I know the truck is closer to the door in one pic vs the other, but comparison of the original style mini projectors and the 160w (top).
    It’s definitely brighter in person just aligning it. It’s got more scatter, but I’m thinking it’s the clear vs black housings. I’ll report back after driving it.
    Jack McCarthy and G_unit3000 like this.
  23. Apr 24, 2025 at 8:55 PM
    The abberation (purple) is definitely much more tolerable. Curious how it looks at a distance.
    khooiii[QUOTED] likes this.
  24. Apr 25, 2025 at 5:01 AM
    Hi06silver
    Hi06silver Fat. Thumbs.
    2006 DC 4x4 Waltrip
    Did you happen to notice how much sand and shit was up behind the sidewalk of the bed?
    I don't have flares and mine.ia starting to get small rust spots. One side is worse than the other but from what I understand sand and what not gets up in that area and slowly works away from the inside out.
    I think i.was loosely quoted around 5000 to repair the bed and paint. Didn't matter the amount of rust and was told may be better to.buy new sides for the repair.
  25. Apr 25, 2025 at 7:30 AM
    Someone else on here used replacements from a Dodge pickup to replace his and it turned out (IMHO) quite good.
  26. Apr 25, 2025 at 7:48 AM
    TUNDRAH
    TUNDRAH New Member
    Tacoma, Washington
    2002 Tundra SR5
    It does collect mud and dirt, I usually spray up in there pretty good when I wash it but I think the main issue is the seam sealer they use between the wheel well liner and bottom edge of the fender around the wheel well. Once that stuff fails it creates that pocket.
  27. Apr 25, 2025 at 8:24 AM
    Dakillacore
    Georgia
    Generally it's just good old 3M double sided tape around the top edges of the flares that holds it to the bedside. The clips provide the actual holding power. It does wear over time and allow debris into the pocket.
    You can always replace the tape to refresh it. Clean the bedside really good of the old adhesive tape and reapply. We also use adhesion promoter wipes to help the adhesive of the tape sick to the panels better.
  28. Apr 25, 2025 at 8:27 AM
    TUNDRAH
    TUNDRAH New Member
    Tacoma, Washington
    2002 Tundra SR5
    The seam sealer gap is visible from the inside. It's between the metal arch where the fender flare screws in and the outer edge of the wheel well.
  29. Apr 25, 2025 at 8:40 AM
    Hi06silver
    2006 DC 4x4 Waltrip
    I've read that on here never seen it. I'll probably get some quotes and try to find some bed sides when a sale is going on.ayne that'll save me someoney on the body shop side (not having to cutout Bondo etc.). If I'm paying I'd rather not have Bondo if it's avoidable.
  30. Apr 25, 2025 at 8:49 AM
    You posted some great pics of the problem over here: https://www.tundras.com/threads/box-wheel-arch-rust.125599/#post-3212509
    @gbcpope said he was gonna use Dakota arches to make it work. Another memeber "had a friend do the work" and posted pics, but hell if I can find it now.
