P0012 and P0022 code
Discussion in '2.5 Gen Tundras (2014-2021)' started by Jermarsala, Apr 11, 2025.
  1. Apr 11, 2025 at 4:18 PM
    Jermarsala
    Jermarsala [OP] New Member
    Jerry
    2019 Tundra SR5
    2019 Tundra 5.7 SR5 86k miles. Got a P0012 code. Replaced the Cam timing oil control valve bank 1. Went fine then I got codes P0012 and P0022. Truck runs normal. Pick up is normal. Had oil change done 900 miles ago. Going to change the oil filter to make sure it’s not a pressure issue from that. Anyone else have this issue. I find it hard to believe it is a timing chain issue.
  2. Apr 11, 2025 at 4:23 PM
    Tyman
    Tyman Isaiah 41:10
    Tyler
    Indiana
    2020 Tundra Sport 4wd MGM
    Has any other maintenance been done? Any accidents? Engine mods?
  3. Apr 11, 2025 at 4:25 PM
    Jermarsala
    Jerry
    2019 Tundra SR5
    No. Just regular oil changes every 6k. Transmission service at 75k. I baby this truck
  4. Apr 23, 2025 at 8:13 PM
    ToyotaBeast
    ToyotaBeast New Member
    More then likely and oil filter issues. If the center support rod did stayed in the old filter it may have been thrown out. The new filter will crush itself with the suction.
