Rust Opinion
Discussion in 'General Tundra Discussion' started by Mj35, Apr 22, 2025.
  1. Apr 22, 2025 at 4:57 PM
    Mj35
    Mj35 [OP] New Member
    Marcus
    In the market
    So I'm in the process still of finding a 2.5 gen tundra and came across one that spent about 20k miles in Saskatchewan, Canada and is now in Idaho. I'm down in the southwest so currently working with dealer to get more pics but I've got video screenshots. Curious your guys thoughts? I'm more or less just trying to avoid any foreseeable rust issues and I know they get quite a bit of snow up in Saskatchewan. Anyone from that region or that has familiarity with the area their above is greatly appreciated. Vehicle only has 35k miles on it. It's a 2020 Tundra. I appreciate all your guys help. Had it happen to me once with a car so trying to avoid it a second time and doing my due diligence
  2. Apr 22, 2025 at 6:23 PM
    68 RS/SS
    68 RS/SS New Member
    MIke
    New Hampshire
    2020 TRD Sport DC
    What rust? Oil undercoat it and drive it
  3. Apr 22, 2025 at 6:42 PM
    Do it
    Mj35[OP] likes this.
  4. Apr 22, 2025 at 6:54 PM
    Mj35
    Marcus
    In the market
    I appreciate you all. I'm probably being a bit over paranoid. Just trying not to have the same thing happen twice
  5. Apr 22, 2025 at 8:42 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    That good of a deal vs something local? Wont this be a Canadian version with a different speedo/odometer?
    Canadian trucks are always sus here since they often spent time in winter salt then ship to WA/OR/ID.
  6. Apr 23, 2025 at 6:58 AM
    Mj35
    Marcus
    In the market
    Yeah that's what happened with this one. Got shipped to ID now. That's what my worries were. I just haven't been able to really find anything local with low mileage. I know it'll be difficult in general
  7. Apr 23, 2025 at 9:28 AM
    apwisher
    apwisher New Member
    Everett, WA
    2007 CM SR5/TRD 4x4 White
    canopy, TRD Sway, audio
    I'm always suspect that they are beat to death on dirt roads or sat idling for hours and hours on end. That said, It looks clean (check for dirt packed into the undercarriage) and at 20K miles I'd guess it was a lease or something.
    Do you have the Carfax? Sometimes that will fill in a lot of gaps.
  8. Apr 23, 2025 at 9:54 AM
    2mchfun
    Just be patient, and look closer to home. 60 or 80k on the odometer just means someone else took the depreciation.
  9. Apr 23, 2025 at 10:36 AM
    Mj35
    Marcus
    In the market
    That's what I'm leaning. May have found one in Vegas that's a 2020 with only 55k miles on it.
    I did look at the carfax and looked clean but again even with all the clean service records you don't know what kinda driving was done or how much of a beating underneath it took. Closer to home may be my best bet and hopefully I can find something around 50k miles if I'm lucky
    2mchfun[QUOTED] likes this.
  10. Apr 23, 2025 at 11:19 AM
    2mchfun
    Look at the paint on the hitch safety chain loops for frequent towing signs, look at rubber pad on brake pedal for wear as a heavily city driven truck, how is the driver door alignment, latch wear, and seat bolster? Dirty seat belt? There are ways to check things out. Check for cam tower oil leaks, missing rubber seal on the radiator cap, signs of valley plate coolant leak, was it backed into water launching boat(s), water in rear end, etc. Have the various drain and fill plugs been wrenched on? Much can be seen if one looks closely.
    Mj35[QUOTED][OP] likes this.
  11. Apr 23, 2025 at 12:18 PM
    Red&03Taco
    Red&03Taco YUT
    Jerad
    2018 Tundra Crewmax Platinum 4WD
    OP these trucks are extremely robust and overbuilt. If you find one with a clean carfax and good, complete service records, and a reasonable amount of mileage on it, I wouldn't overthink it and sweat the small stuff (that it was driven hard or beat on). Many folks beat on these trucks for years and have little to no problems
  12. Apr 28, 2025 at 6:53 PM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Saskatchewan used next to nothing for salt on the highways. Think of it like a northern Colorado. The truck looks very clean and I wouldn’t be afraid of it in the least.
