Truck wont move
Discussion in '1st Gen Tundras (2000-2006)' started by Tondrama, Apr 16, 2025.
  1. Apr 16, 2025 at 6:03 PM
    Tondrama
    Tondrama [OP] New Member
    Victor
    Bay area calif
    2001 toy tundra sr5 access cab
    Work in progress
    So I have a 2001 Toyota tundra SR5 was heading out to Mavericks in half moon bay when all of a sudden I lose my drivetrain, no power moter starts up fine no moving though I had it towed home and found it wont stay when put in park ,checkthe parking pawl everything looks good there ,whenever i move it from reverse to park i hear a winding noise ,it goes into 4hi and 4lo but wont move the propeller shaft spins but doesn't engage any idea where i should start was about to start trying to figure it out but I'm not sure where to start
  2. Apr 16, 2025 at 6:15 PM
    Where does movement stop? You say the prop shaft spins ... is the pinion flange spinning? If yes, then something is toast between the pinion flange and the axles. I'd find it highly unlikely if you snapped both axles...
  3. Apr 16, 2025 at 7:00 PM
    Tondrama
    Victor
    Bay area calif
    Work in progress
    I did recently replace the front CV axles I've spoken with some friends and they think it's my rear differential
  4. Apr 16, 2025 at 7:06 PM
    Tondrama
    Victor
    Bay area calif
    Work in progress
    I've read a couple of threads with people who have the same problem but no one post what the exact problem was or what it took to fix
  5. Apr 16, 2025 at 7:13 PM
    You need to identify the final point where driveline rotation stops.
    Like ...
    If the driveshaft isn't spinning after the output shaft of the transmission, that suggests it's something from the tailshaft of the transmission forward.
    If the driveshaft spins from the carrier bearing foward, but not the carrier bearing back, your carrier bearing is potentially shot.
    If both sections of the rear driveshafts are spinning, and the pinion flange is spinning too, then potentially the pinion shaft, pinion gear, or component of the rear diff grenaded/broke.
    You get the gist, right? Where does shit stop moving?
  6. Apr 16, 2025 at 7:18 PM
    Tondrama
    Victor
    Bay area calif
    Work in progress
    I'll take a look and get back to you thanx I appreciate the help
  7. Apr 17, 2025 at 8:00 AM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    It’s not uncommon for the spider gears inside the 3rd member to strip out on the 1st gen tundra.
    shifty` likes this.
  8. Apr 22, 2025 at 5:47 PM
    Tondrama
    Victor
    Bay area calif
    Work in progress
    Found part of the problem seems my rearend has blown out lol pun intended ,no seriously I pulled the rearend and removed the shafts cracked the rear differential and found pinions wrecked ,now I need to repair or replace got a quote for complete new rear, axle A03A was thinking about changing it up to an A03C just wanted to know if I could change it up to a B03C using the same axle housing and shafts
  9. Apr 22, 2025 at 5:51 PM
    Tondrama
    Victor
    Bay area calif
    Work in progress
  10. Apr 22, 2025 at 5:53 PM
    Tondrama
    Victor
    Bay area calif
    Work in progress
    I guess that's what happens while getting all 4 wheels off the ground at 45/50 mph any leads on new parts in the bay area calif
  11. Apr 22, 2025 at 6:16 PM
    Pics of jump?
    Hi06silver and Filthyphil like this.
