  1. Apr 22, 2025 at 1:08 PM
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
    What size shock are you going with?
  2. Apr 22, 2025 at 1:13 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    2.5x10" Coil over remote resi
    3.5x10" triple bypass remote resi
    Rear shock on the way is 4.0x18"
  3. Apr 22, 2025 at 1:14 PM
    BreyTundy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Jesus. What travel numbers are you hoping with such a long stroke?
    Giggity
  4. Apr 22, 2025 at 1:49 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    The front will be 17-18" The rear shock is also for future plans of potentially linking the truck. The rear will cycle 27"+ if we link it. With leafs anywhere from 16"-19"
  5. Apr 22, 2025 at 2:14 PM
    BreyTundy
    Andrew
    Colorado Springs
    2016 White DC TRD
  6. Apr 22, 2025 at 4:29 PM
    therealjonwick
    therealjonwick New Member
    JR
    2019 OR
    Want to de-badge. Worried it will show on my paint.
    1794TX and bulldog93 like this.
  7. Apr 22, 2025 at 5:22 PM
    woods
    woods New Member
    2021 SR5 TRD Sport
    Heat gun, some string, rubbing alcohol and then a wax over the area you did it to. Done this on 6 cars or so, never had it show. I'm sure there are fancier ways.
  8. Apr 22, 2025 at 5:42 PM
    therealjonwick
    JR
    2019 OR
    Appreciate it. I’m just worried the paint has faded a bit and it will look darker where the badges were.
    Tripleconpanna and 1794TX like this.
  9. Apr 22, 2025 at 7:00 PM
    2014 Black tundra
    2014 Black tundra New Member
    2014 tundra sr5
    Put RC rock lights in the wheel wells. They’re bright enough. I turned the other Tractor Supply rock lights on that changes color. But those aren’t as bright. I put the RC n TS switches together on the console . It’s ok, but the shadows bug me. I guess it’ll add some light at the campground IMG_8147.jpg IMG_8149.jpg IMG_8152.jpg
  10. Apr 22, 2025 at 7:12 PM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 Coachbuilder Shackles 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI
    upload_2025-4-22_21-5-12.jpg PXL_20250301_183946930.MP.jpg Get rid of that tear drop switch and get a switch like this off Amazon and install it in the dashPXL_20250414_214555427~2.jpg
  11. Apr 22, 2025 at 7:17 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Some new Coopers. So much quieter than the Goodyear Wranglers we that were worn out. :thumbsup:
  12. Apr 23, 2025 at 2:17 AM
    woods
    woods New Member
    2021 SR5 TRD Sport
    I don't think that is a problem, maybe someone else can chime in. But I am almost positive I debagged a 2003 Tacoma in 2020 and there wasn't any issue.
    Sleeper16plat and TundyManFL like this.
  13. Apr 23, 2025 at 4:34 AM
    drhntr
    drhntr New Member
    Derrick
    New Hampshire
    2017 Cement Pro DC
    GoRhino 2.0 Diamondback Switchback 295/70/18 TOYO AT3 TRD CAI Window Tint
    IMG_5117.jpgJust added a Diamondback Switchback after the bakflip MX4 wasn’t holding up any longer
  14. Apr 23, 2025 at 5:13 AM
    2014 Black tundra
    2014 tundra sr5
    I do need to organize my light switches. The blank spots on the dash is used already. But, with different style switches .
    BR73[QUOTED] likes this.
  15. Apr 23, 2025 at 5:17 AM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    My 42" light bar came with that same tear drop switch and I was thinking there's got to be a better looking more OEM switch.The new switch had 4 leads vs 3 for the original but I finally figured it out...lol
    HulkSmurf14 likes this.
  16. Apr 23, 2025 at 5:19 AM
    1794TX
    Steven
    N.TX
    '20 1794
    Be careful with the heat gun. A warm setting will do it. Get it too hot and your paint will suffer. I used a hair dryer. I used 50lb monofilament fishing line to cut off the badge and my thumb to roll off the adhesive. You can search the forum for folks who've used this wheel to great success:
    3M Stripe Off Wheel Adhesive Remover Eraser Wheel Removes Decals, Stripes, Vinyl, Tapes and Graphics 4” diameter x 5/8” thick 3/8-16 threaded mandrel 07498 Pack of 1: Power Rotary Tool Accessories: Amazon.com: Tools & Home Improvement
    It seemed harsh to me when I first read about it, but there are raves about its results.
    If you wind up with any residual goo, some orange-oil-based solvent will get it off:
    Amazon.com: Goo Gone Original Liquid - 8 Ounce - Surface Safe Adhesive Remover Safely Removes Stickers Labels Decals Residue Tape Chewing Gum Grease Tar Crayon Glue : Arts, Crafts & Sewing
    Wash it off with soap and water after.
    Good luck.
  17. Apr 23, 2025 at 5:47 AM
    Yota303
    Yota303 -Running on hope and gasoline-
    Washington
    2016 MGM Crewmax 4x4 Limited
    I was just thinking yesterday that some 30 lb. test fishing line might work good for this. Good to know a hair dryer will do the job for heat too. Thanks for the info.
  18. Apr 23, 2025 at 5:47 AM
    woods
    woods New Member
    2021 SR5 TRD Sport
    Good point on the heat gun, I only use the first or second setting if its real cold out. I have used the wheels to mixed success, but they aren't a bad solution. I find just the fishing line/heat gun to be the real winner. Any thread will do but the thinner and stronger the better.
    Good tips!
  19. Apr 23, 2025 at 7:26 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    It's not so much the length, but the diameter is just so :eek:... intimidating!!!!
  20. Apr 23, 2025 at 8:37 AM
    TundyManFL
    TundyManFL New Member
    2021 MGM TRD Pro CrewMax
    Any color differences from the sun on the paint underneath badge? I don't wanna take mine off and find that and have to deal with it, so curious.
  21. Apr 23, 2025 at 8:40 AM
    TundyManFL
    Can the paint color affect this? Like some paints might be more susceptible. I'd have to search but have come across some posts here mentioning they saw a diff.
    woods[QUOTED] likes this.
  22. Apr 23, 2025 at 8:47 AM
    Uhhhh....
    Uhhhh.... New Member
    Dave
    Virginia
    2016 Silver Limited DC
    7” BDS, 37s
    You can always just take one badge off, and if it's discolored, put the badge back on.
  23. Apr 23, 2025 at 8:53 AM
    @RainMan_PNW can help with that......
  24. Apr 23, 2025 at 8:57 AM
    Mullen
    Mullen Desert Dude
    Corona, CA
    2001 Prerunner, 2014 DC 4wd
    I installed my TRD Pro headlights and Baja Designs fog light kit. The Squadron Sports came off my first gen as I upgraded those to XL80. Looks so much better than the 10 year old headlights. I still need to do something about the bumper as it looks terrible.
  25. Apr 23, 2025 at 8:58 AM
    Ebrperk
    Ebrperk Old member
    South Central Kansas
    2018 1794 MGM
    Tinted windows, go rhino D6 side steps and shorty antenna, Bilstein 5100's rears, 6112's fonts set to 2.5" Rocktrix RT111 18x9 -12offset NItto Terra Grapplers G3's 275/70 R18's. Amp from James @ Tech12volts FRAC Harness
    I was wondering how he got that good of mileage:monocle::monocle:
    Corndog123[QUOTED] likes this.
  26. Apr 23, 2025 at 9:38 AM
    Ghosty
    Ghosty New Member
    2020 Tundra TRD Pro
    No issues whatsoever. Went really smooth. Took me about 20 minutes total. It was really dirty behind them, though. I think I could possibly be an issue on an older vehicle or a darker color, but I didn’t have even the slightest variation of color.
  27. Apr 23, 2025 at 10:41 AM
    woods
    woods New Member
    2021 SR5 TRD Sport
    So a week or two ago I posted that I can't find many 2nd gens for sale, and I was wondering what you guys were thinking. No one really replied, but I did get this email today saying my trucks in high demand and value is up. Not ever going to sell it, but I see it as reaffirmation that 2nd gen is the best gen.Screenshot 2025-04-23 at 1.38.02 PM.png
    bflooks, BR73 and HulkSmurf14 like this.
  28. Apr 23, 2025 at 11:18 AM
    KevAlv
    KevAlv New Member
    Houston, Texas
    2021 White TRD Sport
    Heated Leather Seats Flowmaster Super 50 Dual Exhaust Tint Bed Cover Chrome Steps & Handles Under Seat Storage
    RobertD likes this.
  29. Apr 23, 2025 at 11:18 AM
    RobertD
    Robert
    DFW, Texas
    woods likes this.
  30. Apr 23, 2025 at 12:05 PM
    Ebrperk
    Ebrperk Old member
    2018 1794 MGM
    Saying you have young kids without actually saying you have young kids
