3rd Gen Accessory Thread
Discussion in '3rd Gen Tundras (2022+)' started by jimfish98, Dec 17, 2021.
  1. Mar 25, 2025 at 8:22 AM
    #2701
    Zudrick
    Zudrick New Member
    2024 Tundra Lunar Rock Limited
    None….so far
    I don’t, normally if you feel the headrest, the back is often softer and the front is. It’s because the front is designed to deal with hair and the increased level of oil, the rear is not and will wear out quicker. Additional the front is designed at an angle so if your in a crash it minimizes neck injury. So while on my Subaru (they were the worst at this) the head rest was far more comfortable turned around, it would wear out quicker and be worse in a crash.
  2. Mar 25, 2025 at 8:50 AM
    #2702
    Kerplunk
    Kerplunk New Member
    I use it when I need to take a nap. Turn on cruise control and LKA, and I am good to go.
    CAPT_Squatchy86 and 75tranzam like this.
  3. Apr 22, 2025 at 9:51 AM
    #2703
    greg8765
    greg8765 New Member
    Grant
    Utah
    2021 Cement Tundra
    :monocle::D:D:D
