General Supercharger Thread
  1. Apr 20, 2025 at 6:37 AM
    carn_dogg
    carn_dogg i don't think so
    Pat
    Eastern Shore MD
    2013 Black Tundra Platinum
    Happy Easter fellas
    Mdl, Silver17, Saltyhero13 and 4 others like this.
  2. Apr 20, 2025 at 6:56 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Fixed that for ya ;)
  3. Apr 20, 2025 at 9:42 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Anderson Engineering said they do offer the 3UR manifold spacers in delrin. They will update the website tomorrow to show them available. Last year they had a 20% off discount for Memorial Day. Have to keep an eye out for a sale this year.
  4. Apr 20, 2025 at 9:57 AM
    bflooks
    bflooks New Member
    Metrowest MA
    Glad they responded to you. Have heard no response to my request for performance data. I do recognize the temp variable is key for the SC folks. Just figured they'd have the additional data points aside from IATs
    HulkSmurf14, Silver17[QUOTED] and Mdl like this.
  5. Apr 20, 2025 at 10:05 AM
    snivilous
    SW UT
    300k+ Supercharged 2008
    What other performance metrics would you want?
    Spacers on a plastic intake I think would be even harder to see any performance benefit. And if you're not measuring temperature in a runner then you're not really getting useful data. If they had a probe in the spacer itself for IAT that'd be best.
  6. Apr 20, 2025 at 11:26 AM
    bflooks
    bflooks New Member
    Metrowest MA
    Tacoma specs on their site vs Tundra. I'm curious what they see on the 3ur platform, specifically. "Increases driveability" is so vague, especially compared to their other listings.
    Saltyhero13 and HulkSmurf14 like this.
  7. Apr 20, 2025 at 12:21 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Not sure I'll be able to use this block unless I sleeve it...driver's side and passenger side have rust in the bores. I vacuumed it all out and wiped it down, but it's into the liner. I'll try a dingle ball hone and see what that does for me. If no good, I will run it by the machine shop on Monday and see what they say.
  8. Apr 20, 2025 at 12:38 PM
    Abell207
    Abell207 New Member
    Anthony
    Maine
    2020 Army Green TRD PRO
    6.8L time
    AZTundra, HulkSmurf14 and Mdl like this.
  9. Apr 20, 2025 at 1:57 PM
    snivilous
    SW UT
    I think you're drinking the snake oil too much. It's an intake spacer :p 90% of the shit they say is marketing. Delrin has high stiffness? It's a fucking plastic, about the only thing it's stiffer than is a piece of foam (not that it matters at all in this use case). Low friction and wear? All that air friction that's saved from using a self lubricating plastic? At least it wears good :confused: Some dude probably didn't copy and paste the description correctly between the two trucks. Anything beyond saying it makes the intake run cooler I would assume is BS.
  10. Apr 20, 2025 at 2:07 PM
    bflooks
    bflooks New Member
    Metrowest MA
    Drinking, yes. Snake oil, not yet. I haven't purchased but did inquire about the additional data. Their silence supports your position. Can we still be friends? o_O
  11. Apr 20, 2025 at 2:12 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    It might be ok...but the liners are thin.
    armyoffoo[QUOTED] likes this.
  12. Apr 20, 2025 at 2:34 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Found the crank trigger information in TIS, I will still need to use the Oscilloscope function in the Haltech software to get the offset angle setup with a timing light.
  13. Apr 20, 2025 at 2:48 PM
    Silver17
    Eastern PA
    I messaged them on their Facebook page several days ago, they just replied today. If there’s a sale I may consider them. Realistically, it’s another tinker mod that’s not 100% necessary. Lower intake temps are always good though.
    HulkSmurf14 and bflooks[QUOTED] like this.
  14. Apr 20, 2025 at 3:26 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Soooooo the 2025 suck continues. Cyl 8 appears to have ring issues (it had a 308 & the plug was oily) I gave it HD 5-40 & the smoke dissipated. but what the actual FUCK?????
    This video is on the 5-20.
    https://vimeo.com/1077138992?share=copy
    Isn't it odd it goes away on the throttle?
  15. Apr 20, 2025 at 6:05 PM
    Ryuu
    Ryuu Hwat!?
    Oscar
    SouthEast, TX
    2017 TRD PRO Barcelona Red
    a few
    Looking like I might have an issue with my maggy2650. Started making a weird whistling noise yesterday. Gets louder with a higher idle. Odd part is if I put some pressure on the lid with my hand the whistle seems to settle down and comes back once I take the pressure off.
    Anybody here experienced anything like that before?
  16. Apr 20, 2025 at 6:08 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Are the lid bolts torqued to spec?
  17. Apr 20, 2025 at 6:10 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Sniped!
    HulkSmurf14 and Mdl[QUOTED] like this.
  18. Apr 20, 2025 at 6:13 PM
    Ryuu
    Ryuu Hwat!?
    Oscar
    SouthEast, TX
    a few
    not really sure, but I really hope so since I had it installed for me. I only got a chance a few minutes ago to really look at it.
    Already got dark here but going to look up the torque specs to go have a look.
  19. Apr 20, 2025 at 6:20 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
  20. Apr 20, 2025 at 6:35 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I just looked at the install instructions. Is their a lid gasket, o-ring? It wasn't mentioned or shown.
  21. Apr 20, 2025 at 6:40 PM
    Winks4x4Toy
    Winks4x4Toy New Member
    Maryland
    2015 1794 Super White Tundra
    Bak Flip cover, LED interior lights, American Flag tail gate letter inlays, 20in wheels, full audio system, 12in Android center screen.
    Thank you! Like most things, just takes time and research, hard work and money, and sometimes trial and error.
    As far as the 4l80e transmission goes I'll keep you all posted on the details. Currently using an early 2000's transfer case from a Cadillac Escalade. Then modifying the fueling and ecu and then they're gunna throw the sauce at it and see what it can do! This time around it'll a have koyo rad, the bigger trans cooler as well.
    bflooks[QUOTED] and Mdl like this.
  22. Apr 20, 2025 at 6:47 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Dang, I don't remember. I know that there wasn't a gasket, so I would lean toward an o-ring along the lines of the intake plenum o-ring. I mean, there needs to be somethings, right? I just don't recall....:bananadead:
    snivilous[OP] and HulkSmurf14 like this.
  23. Apr 20, 2025 at 6:47 PM
    Ryuu
    Ryuu Hwat!?
    Oscar
    SouthEast, TX
    a few
    thanks.
    looked over the install instructions and there's no mention of any kind of gasket for the lid. Just the lid straight to the supercharger.
    Also all the lid bolts seem to be to spec, all of them clicked at 18ft-lb.
  24. Apr 20, 2025 at 6:53 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I guess there is on the lid side but can't recall either and I don't have a 2650...
    Wynnded[QUOTED] and HulkSmurf14 like this.
  25. Apr 20, 2025 at 6:57 PM
    Ryuu
    Ryuu Hwat!?
    Oscar
    SouthEast, TX
    a few
    no lid gasket.
    only gaskets mentioned are the OEM intake manifold ones
    HulkSmurf14 and Wynnded like this.
  26. Apr 20, 2025 at 7:03 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Ya, we're looking at the same instructions. But I just can't believe that there isn't something between the upper and lower halves. It's just been so long since I installed mine. What's it do if you blip the throttle?
  27. Apr 20, 2025 at 7:10 PM
    snivilous
    SW UT
    If you need help give me a call, though probably someone in here that knows stand alones better than me. Sounds like the Haltech is the same way the ECU Masters is. Setting up timing I thought was pretty straightforward, lock the timing and then timing light to confirm and then adjust the offset until the input timing matched the timing light. The bigger issue I had and struggled with a lot was getting the ECU to reference the correct part of the crank as #1 TDC, which ultimately was an option as simple as swapping trailing tooth to leading tooth or something, which seemed to be the opposite of what other 2JZs were doing but worked fine for me. Of course the engine wouldn't run without doing that first, so getting the timing offset was a down the line type thing.
  28. Apr 20, 2025 at 7:10 PM
    Ryuu
    Ryuu Hwat!?
    Oscar
    SouthEast, TX
    a few
    yea seems like an odd choice for no type of gasket.
    noise goes up with the rpms, at 2k rpm it sounded like a belt squealing / tea kettle, very high pitched and annoying.
    HulkSmurf14 and Wynnded[QUOTED] like this.
  29. Apr 20, 2025 at 7:14 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Thanks, I appreciate it, and probably will need help. I'm still waiting on sensors, so not ready to hook it all up yet.
    HulkSmurf14 likes this.
  30. Apr 20, 2025 at 7:14 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Hopefully you don't need to drive it tomorrow and will have some more time to see if you can localize the sound with the assistance of daylight.
