2007 ...5.7 SR5 wont shift into 5th or 6th gear
Discussion in '2nd Gen Tundras (2007-2013)' started by 07tun, Apr 17, 2025.
  1. Apr 17, 2025 at 7:44 AM
    07tun
    07tun [OP] New Member
    2007 tundra SR5
    none
    Which transmission contol solenoid controls 5th and 6th gear??Check engine light on, VSC light flashing, and skid warning light on. Won't shift into 5th or 6th gear. Diagnostics code P0983. Saw a youtube video showing transmission control solenoid "D" as 3rd from rear (blue) connection as fix. Replaced that one and didn't fix problem.(Although olms tested way out of working range on old one)..Help, please.
  2. Apr 18, 2025 at 10:51 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Change your fluid. Make sure you check fluid level and clear all codes.
  3. Apr 18, 2025 at 10:53 AM
    blackdemon_tt
    Did you do it?? Or did a shop do it??
  4. Apr 19, 2025 at 11:12 AM
    07tun
    2007 tundra SR5
    none
    I did it...Changed fluid when replaced solenoid...I cleared the code with high dollar diagnostic tool and removed battery cable.. Code comes back immediately either way. Problem was intermitent at first but constant now. Thanks for reply..
  5. Apr 19, 2025 at 12:09 PM
    blackdemon_tt
    May be a wiring issue. I had that with a torque convertor clutch problem. I would reset and would come back. I replaced that solenoid and solved my issue. So far I'm 4 solenoids in.
  6. Apr 19, 2025 at 1:14 PM
    n0rth
    n0rth New Member
    J.W.
    2019 Tundra Crewmax
    Similar but different- this was my experience with the shift solenoids on my 07.
    https://www.tundras.com/threads/p0973-shift-solenoid-“a”-control-circuit-low-advice-help.109939/#post-2909951
    I realized some of the links in my post were gone, tried to find the links with no luck. I did find this article that discusses the solenoid functions and codes.
    From the article
    "Code P0766 is a Shift Solenoid “D” Performance code (Shift Solenoid Valve S4) S4 stuck OFF malfunction or brake control valve malfunction shifting to 5th and 6th gears is impossible."
    https://gearsmagazine.com/magazine/toyota-trouble-builders-beware/
  7. Apr 20, 2025 at 3:19 PM
    07tun
    2007 tundra SR5
    none
    Thanks for all replies. It could be a wiring issue. I just didn't think so since "D" solenoid tested bad after I removed it (blue one, 3rd from front). The original diagnostic code was "P0983 Shift Solenoid "D" Control Circuit High". And like nOrth said, it won't shift into 5th or 6th. I was about to order whole solenoid kit but will try to test wiring going into plug at transmission first. I have has rats under the exhaust cover, so wiring problem not out of question.
    blackdemon_tt and n0rth like this.
