Rokblokz vs Rekgen flaps…need pics for 3rd gen
Discussion in '3rd Gen Tundras (2022+)' started by Nitro1794, Feb 4, 2025.
  1. Feb 4, 2025 at 8:10 AM
    Nitro1794
    Nitro1794 [OP] New Member
    2024 mesquite tundra 1794 imax hybrid
    If you were going to spend the money, which would you choose? 2024 1794 edition with power running boards…STOCK setup (haven’t modified anything…yet)
    would like to see pictures of both the Rokblokz (standard size) and the Rekgen on a 22+ tundra if anyone has put either on? The stock OE flaps are too small…don’t work very well IMO
    thanks!
  2. Feb 4, 2025 at 8:14 AM
    trazerr
    trazerr New Member
    Oregon
    2024 Toyota Tundra Platinum LR
    I went Rekgens on my 2024 Platinum. Not sure I have any pics on my phone. Can grab some in a bit.
  3. Feb 4, 2025 at 9:57 AM
    nodak67
    nodak67 New Member
    JR
    try the mudflap thread.
  4. Feb 4, 2025 at 10:26 AM
    SilveradoSwap
    SilveradoSwap New Member
    2024 1794 Edition Tundra
    I have RekGen Sport Flaps. I have 1.5" of tire poke and they cover almost all the poke. I was not a fan at first because I felt it took away from the clean look, but after about 2 weeks I really liked the look and performance.
    BlackNBlu and Crawldad like this.
  5. Feb 4, 2025 at 10:53 AM
    Bigbadpoppa
    Bigbadpoppa New Member
    Rokblokz standard here. 24 TRD PRO, stock wheels, 295/70/18. The Rokblokz is a high quality, easy to install and has some adjustability from left to right. I have mine pulled all the way out and it sits flush with the tires. Any wider of a tire/offset, i suggest going non-standard.
  6. Feb 4, 2025 at 11:00 AM
    SilveradoSwap
    Same here, pulled all the way out, wheel offset at +20 w/11.5" tire
  7. Feb 4, 2025 at 12:42 PM
    Nitro1794
    Decided on the Rokblokz, ordered today. Will post pics and thanks
    Tundrastruck91 and SilveradoSwap like this.
  8. Feb 4, 2025 at 2:06 PM
    Crawldad
    Crawldad New Member
    2024 Tundra Limited TRD OR w/3” Lift
    After installing 315/70/17’s on +20 x 8.5” wheels my tires rubbed the Oem mudflaps. Removed the flaps and the tires rubbed the liner which I zip tied back and no more rubbing. Now my tires spray water/mud down the side of my truck.
    I’m looking at the Rekgens and Rokblokz to keep the side of my truck clean. I figure I’ll have to use a heat gun or zip tie to keep from rubbing on those as well.
    Could you post a pic looking at the front flap where the tire might rub please?
    Rubbing on factory flap
    flap removed and liner tied back
    Yaboy likes this.
  9. Apr 19, 2025 at 6:55 AM
    Mmatt
    Mmatt New Member
    Oshawa, ON (Toronto)
    2024 limited nightshade 6.5
    Does anyone know if the rock gens have more coverage? I have 2 1/2" poke and don't really want to put fender flares on for protection. Would rather the flaps
  10. Apr 19, 2025 at 4:22 PM
    Derfla
    Derfla MUDBATH PRO
    2025 TRD PRO
    Here’s a before and after on 295 wide tires on a 18x9 +20 wheel:
    I don’t poke much so these Rek Gen Sports are not what you need. The Pro fenders stick out a bit more too though.
  11. May 2, 2025 at 9:19 AM
    Frank_TRD23
    Frank_TRD23 New Member
    Frank
    2023 Tundra TRD Mag grey
    1.5 Wescott lift 20" wheels on 37s Stillen Trucontroller
    Bringing this back to the top(yeah I know it's totally, im old new fashion) anymore folks with aftermarket mudd flaps?
  12. May 2, 2025 at 9:42 AM
    Mmatt
    Mmatt New Member
    I'm waiting on my rockblokz.. and will post pics of I remember
  13. May 2, 2025 at 7:03 PM
    Frank_TRD23
    Frank
    After looking at how much room I have. Mudd flaps would have to be thin to fit with the 37s. So who has 37s and aftermarket mudd flaps.
