Removing plastic scratches on interior door panels
Discussion in '2.5 Gen Tundras (2014-2021)' started by 1UP, Apr 19, 2025.
  1. Apr 19, 2025 at 8:45 AM
    1UP
    1UP [OP] Truck Gang
    2019 Red CM TRD sport 4x4
    As the title says, I have a lot of scratches on the inside of my doors. Kids, dogs, and life happens. Does anyone have a solution to removing that light grey scratch mark?
    I was thinking maybe a little black dye on a qtip?
  2. Apr 19, 2025 at 8:50 AM
  3. Apr 19, 2025 at 9:04 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I've got a can of this stuff I plan to use
  4. Apr 19, 2025 at 9:14 AM
    1UP
    1UP [OP] Truck Gang
    @KNABORES
    The top scratches look worse than this, just not showing well in the pic.
  5. Apr 19, 2025 at 9:25 AM
    Dave8699
    Dave8699 Trackrat
    NJ
    04 Tundra AC, 2014 Tundra 1794 Crew Max
    Whole truck Raptor liner in olive green, leer camper cap, 5100 with OME, Wheelers AAL and Firestone Air bags.
    Following as I have a shit load also.
    BrandonL812 likes this.
  6. Apr 19, 2025 at 9:32 AM
    Don't spray it. There is a way to doing it with a low setting on a heat gun. You will have to research it.
  7. Apr 19, 2025 at 9:44 AM
    1UP
    1UP [OP] Truck Gang
  8. Apr 19, 2025 at 10:12 AM
    PJSD
    PJSD New Member
    Following... I was considering just replacing the entire interior door panel eventually. I found the part online, it isn't crazy expensive or hard to replace. But if you find a way to get rid of the scratches lemme know
  9. Apr 19, 2025 at 10:14 AM
    1UP
    1UP [OP] Truck Gang
    Sounds good. I painted my silver strips red so I was trying to save the panels versus replacing them. Also I have little ones so the scratches will come back no matter the solution. So fixing them seems like the best long term option.
  10. Apr 19, 2025 at 6:21 PM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    Im in for a solution also, aside from replacing the door panel of course. Previous owner had pet(s). Scratches all over. It wad a lap pet because most scratches are on the driver’s panel. But other door were not spared either.
  11. Aug 4, 2025 at 11:32 AM
    Coljohnson09
    Coljohnson09 New Member
    2018 Tundra SR5 TSS Blackout
    Stock, looking to upgrade
    I tried the heat gun. I install tint and PPF for a living. And the heat gun method doesn't work that well. Light scratches maybe. But with kids and dogs I also have this problem. I'm taking my entire interior apart this weekend to paint it with Dupli-color fabric/plastic paint. Just make sure to really clean the parts. Lightly sand or scuff, then paint. I have a buddy that did this to a 93 Honda EK hatch. Looks fantastic. Even didnthe headliner and all the pillars. It's just all about the prep work making sure it's clean and no oils left behind.
    pvmike, panicman and 1UP[OP] like this.
