Front diff drain plug seized
Discussion in '2.5 Gen Tundras (2014-2021)' started by SoTexTundra, Apr 17, 2025.
  1. Apr 17, 2025 at 2:44 AM
    SoTexTundra
    SoTexTundra [OP] New Member
    19 DC TRD OFF-ROAD
    Anyone have some thoughts or experience with the seized front diff drain plug? Also part numbers for the Lexus bolt style drain plug to replace once or if I can get this one off? Thanks in advance
  2. Apr 17, 2025 at 2:59 AM
    gizardlizard
    gizardlizard New Member
    Madison,WI
    2017 TRD pro Tundra
    6” lift, 35 inch tires, chrome delete, ridiculous stereo
    Been there, done that. Grip edge RPT and a breaker bar removed my stripped plug. I also put the Lexus plug in but don’t have the part number handy.
  3. Apr 17, 2025 at 3:55 AM
    SoTexTundra
    19 DC TRD OFF-ROAD
    Thank you just ordered some grip edge 1/2 in drive. I will see if this works or not and I’ll have to look around either for the Lexus plug or put a new Toyota one back on just to replace the damaged one
  4. Apr 17, 2025 at 4:04 AM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
  5. Apr 17, 2025 at 5:12 AM
    agrestic1
    agrestic1 New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
    Just did mine. Allen, breaker bar, pipe for leverage, hammer......Finally broke free and replaced it with the Lexus plug..
  6. Apr 17, 2025 at 6:00 AM
    Yota303
    Yota303 -Running on hope and gasoline-
    Washington
    2016 MGM Crewmax 4x4 Limited
    Make sure you can get the fill plug off first before the drain plug, if you haven’t tried yet
    14crwmaxltd likes this.
  7. Apr 17, 2025 at 11:55 PM
    dadtrucklife
    dadtrucklife New Member
    2021 SR5 TRDOR 4x4 (Army Green)
    PB blaster should help. My rear differential plug was tight and PB blaster helped free it with a breaker bar.
  8. Apr 18, 2025 at 4:35 AM
    DCRB4X4
    DCRB4X4 New Member
    BLACK 2015 DCRB SR5 4X4
    5100's front, spacer rear
    Heat it and shock it with a hammer. Worked great on bolts torqued to 1200 lbs ft and red loctited. Don't go crazy, use your calibrated hammer.
    JLS in WA, 14crwmaxltd and Yota303 like this.
  9. Apr 18, 2025 at 7:09 AM
    Mr Badwrench
    Mr Badwrench New Member
    Heat and just a little hammer. Just don't clobber it, the housing is casted.
  10. Apr 18, 2025 at 3:22 PM
    dadtrucklife
    This☝. PB Blaster does wonders. Works on either diff plug. I would try this before hammering on anything.
    Tunrod likes this.
  11. Apr 18, 2025 at 4:05 PM
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
    Real men use Kroil....Lol
  12. Apr 22, 2025 at 9:22 PM
    smokint
    smokint New Member
    2017 1794 2002 Tacoma
    I couldn’t get mine off once even using my feet on a breaker bar. Put my tail between my legs, and took it down to the Dealership. Tech called me back once up on lift to show me what they do to loosen it. Took a club hammer (small flat faced sledge hammer), and pounded it square on the plug a few times (hard). Came right out.
    agrestic1 likes this.
  13. Apr 23, 2025 at 4:03 PM
    SoTexTundra
    19 DC TRD OFF-ROAD
    I believe I have the items along with a new oem drain and fill plugs with crush washers since no luck in finding the Lexus plugs local to me. Will let y’all know how this goes in the next few days.
  14. Apr 28, 2025 at 3:58 PM
    SoTexTundra
    19 DC TRD OFF-ROAD
    So unfortunately I couldn’t get the drain plug off so I used my drill powered fluid transfer and sucked the old fluid out and replaced with new fluid with a new fill plug and washer.
  15. Apr 28, 2025 at 5:20 PM
    smokint
    smokint New Member
    "Patience you must have my young Padawan."
  16. Apr 30, 2025 at 7:03 AM
    SoTexTundra
    19 DC TRD OFF-ROAD
    Haha i was tempting to use a cold chisel but was worried of doing more damage to the actual diff.
  17. May 2, 2025 at 7:48 AM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    After this thread surfaced I decided to hit all my drain and fill plugs with PB Blaster a couple of weeks ago. Today I hit the front differential again and tried loosing ... like butter with 1/2" ratchet. Something to try before fluid change.
    I used this
    dadtrucklife and smokint like this.
  18. May 2, 2025 at 1:00 PM
    Red&03Taco
    Red&03Taco YUT
    Jerad
    2018 Platinum Tundra, 1997 FZJ80, 2003 Tacoma SR5 V6 5Spd
    Lexus plugs are the way to go
    ZappBrannigan and smokint like this.
  19. May 10, 2025 at 12:33 PM
    SoTexTundra
    19 DC TRD OFF-ROAD
    I wanted the Lexus plugs but couldn’t find them in my area plus never got the drain plug off
  20. May 10, 2025 at 9:17 PM
    Red&03Taco
    Red&03Taco YUT
    Jerad
    Try Partsouq.com for the Lexus plugs
  21. May 11, 2025 at 6:55 AM
    agrestic1
    2016 CrewMax
    I got mine from Ebay..Lexus 90341-24016 plug & 90430-24003 gasket-crush washer..combo for front diff drain plug
  22. May 11, 2025 at 7:59 AM
    AZBoatHauler
    So.Arizona
    Funny thing is I rounded off the rear fill plug - front was no problem.
  23. May 11, 2025 at 8:47 AM
    Red&03Taco
    Red&03Taco YUT
    Jerad
    Interesting. My rear fill plug on my Tacoma started to round off and I found that a 15/16" socket fit a lot more snug than a 24mm, which saved it from getting completely rounded. I wonder if that would apply to the Tundra's rear fill plug
    AZBoatHauler[QUOTED] and Tunrod like this.
  24. May 11, 2025 at 8:58 AM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    That's what I used on my rear diff as I couldn't find my 24mm. No issues.
    AZBoatHauler likes this.
