3rd gen - Rear bed step recommendations
Discussion in '3rd Gen Tundras (2022+)' started by cartage1, Apr 13, 2025.
  1. Apr 13, 2025 at 6:04 AM
    cartage1
    cartage1 [OP] New Member
    Ohio
    2023 TRD Pro
    Hello gang, any rear bed step recommendations, and/or quick reviews. Not a ton found searching, and thanks in advance for any replies.
    Links certainly not required, but appreciated. I.e, so many listed on AMZN, would be good to know which one you are referring too.
  2. Apr 13, 2025 at 7:44 AM
    ScottieBones
    ScottieBones New Member
    NC
    2025 Limited 4x4 TRD OR
  3. Apr 13, 2025 at 10:19 AM
    cartage1
    Ohio
    2023 TRD Pro
    Cool, thank you sir. Will check them out.
    ScottieBones likes this.
  4. Apr 14, 2025 at 1:29 AM
    Sodamo
    Sodamo New Member
    Big Island Hawaii
    2024 1784 Crewmax hybrid
    I got that one as well. Easy install. Works well.Like it.
    cartage1[OP] likes this.
  5. Apr 14, 2025 at 4:45 AM
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    Another satisfied user of the AMZ step linked above. Mine was from a different seller, but looks identical. I assume they all come out of the same factory.
    ScottieBones and cartage1[OP] like this.
  6. Apr 14, 2025 at 10:25 AM
    Sodamo
    Sodamo New Member
    Big Island Hawaii
    This was a good mod for me. Just not as agile at 78 as I used to be. Coming from a Honda Ridgeline with the dual opening tailgate, getting into the higher Tundra was a challenge and PITA at times.
    cartage1[OP] and oddhours like this.
  7. Apr 14, 2025 at 1:07 PM
    sandiegosteve
    sandiegosteve New Member
    San Diego
    24 Limited TDR Lunar Rock
    I've had this cheap Amazon one on since February. https://www.amazon.com/dp/B0CR2SM4R6?ref=ppx_yo2ov_dt_b_fed_asin_title
    No problems. Easy install, fits well. Has seen offroad in the desert and salty boat ramps. Well, it doesn't come close to getting wet, but lots of dust in the desert and still works well. You do loose a little departure angle if you are getting crazy in the rocks.
  8. Apr 14, 2025 at 3:11 PM
    Sodamo
    Sodamo New Member
    Big Island Hawaii
    I did have delusions of installing the power step, but that would mean the power running boards as well. Not in budget.
  9. Apr 14, 2025 at 3:11 PM
    Dfrink
    Dfrink New Member
    SR5 CM 4wd
    Another who purchased the cheap one from Amazon. I've had it for over a year. No problems. Works as described.
    BlackNBlu and cartage1[OP] like this.
  10. Apr 14, 2025 at 5:28 PM
    cartage1
    Ohio
    2023 TRD Pro
    The bed height on these is not inconsequential...
    Appreciate everyone's replies and comments. Thank you!
    ScottieBones and Tundrastruck91 like this.
  11. Apr 16, 2025 at 5:23 PM
    WineryCowboy
    WineryCowboy New Member
    2022 White Tundra SR5
    Timbrens SES Rear
    IMG_0756.jpgI just wanted to add, you might notice that after installing, it will be touching the trim piece and I know a lot of folks are adding washers onto the bolts to push it out more, but I’ll say don’t worry about it. Just use it and over time it’ll stretch out and no longer touch the bumper. My personal experience.
  12. Apr 17, 2025 at 4:58 PM
    PNW Tundra Mike
    Southern Cal
    MX4 Tonneau, Talon's Trans/Cat Shield
    I can’t get over how it looks. Not for me.
  13. Apr 17, 2025 at 6:33 PM
    WineryCowboy
    Timbrens SES Rear
    I wasn’t a fan on how it looked initially, but I needed a step with how often I climb in the back and it looks fitting after a while. Maybe I just got used to it but the practicality of it more than makes up for the looks in my opinion. Also kicking it back up and down is fun haha.
    cartage1[OP] and BlackNBlu like this.
  14. Apr 17, 2025 at 9:37 PM
    Bigbadpoppa
    Bigbadpoppa New Member
    I've been using this. Not a fan of the side corner bed step since it's only 1 side. I wish they actually did what Ford did with their integrated step which comes out from the bed door.
    This poor mans option gives me full flexibility to step from any position around the bed door, i just toss it in the bed and it's ready to go whenever I open the bed.
    Just a thought...
  15. Apr 17, 2025 at 10:36 PM
    Derfla
    Derfla MUDBATH PRO
    Las Vegas, NV
    2025 TRD PRO
    I had an Amazon step on my 22 Tundra that I kept when I upgraded to a 25 Tundra which came with a step.
    They are the same as OEM. I swapped the step itself to the OEM base. The bolts line up. The tread is a little different but the intended purpose isn’t any different.
  16. Apr 18, 2025 at 1:58 AM
    woods
    woods New Member
    2021 SR5 TRD Sport
    We use this at my business. We have a golf cart for older folks and injured folks, and use this as a step assist for them. This thing can take a lot of weight and folds down nice and small. Been using it for almost 3 years now.
  17. Apr 18, 2025 at 5:02 AM
    WineryCowboy
    Timbrens SES Rear
    That is a very clever idea I am buying that right now. Yes having a step only on one side is limiting.
    woods likes this.
  18. Apr 18, 2025 at 5:46 AM
    RDW
    RDW New Member
    Rob
    NJ
    2025 Tundra Platinum TRD Off-road
    Heritage Grille w/ TRD Marker Lights, Diode Dynamics Light Bar and OEM TRD Dash Switch, Rigid Yellow Fogs, Diode Dynamics C1 Hitch Pod Light, AMP Powersteps Smart Series, Aftermarket Power Bed Step, Bedbug XLT, Rough Country Neoprene Rear Seat Cover
    Technically you can run the power bed step without the power side steps. I wired up both, but standalone on either products is def achievable. The issue is the power bed step is $500, but it sure works great and looks super cool!
  19. Apr 18, 2025 at 5:48 AM
    RDW
    RDW New Member
    Rob
    NJ
    The powered step is level with the body, one of the other reasons I got it instead of the manual step…my OCD hates the angle of the manual one!
  20. Apr 18, 2025 at 6:08 AM
    woods
    woods New Member
    2021 SR5 TRD Sport
    I live where it snows. Power steps are not anything you want on your truck if you live where it snows. Just don't go together, they freeze and don't work half the year, jealous of the folks who can run them.
  21. Apr 18, 2025 at 6:14 AM
    RDW
    RDW New Member
    Rob
    NJ
    I live in NJ so we get some snow, but not enough to worry me about it. I just got this truck so time will tell, but I had auto steps on my last 4Runner and never had an issue with freezing.
    woods[QUOTED] likes this.
  22. Apr 18, 2025 at 6:46 AM
    DRP
    DRP Old Member
    Dave
    2 Minnesota winters so far and no issues but I will turn them off if I'm driving in slushy/freezing slopes just in case. Otherwise just let them do their thing.
    woods[QUOTED] and RDW like this.
  23. Apr 18, 2025 at 6:52 AM
    woods
    woods New Member
    2021 SR5 TRD Sport
    Your winters are harder than mine. I had them in 2018ish...so maybe they've improved them.
