General Turbocharger Thread (formerly "Turbo Charging A Tundra!")
Discussion in '2.5 Gen Builds (2014-2021)' started by bflooks, Nov 15, 2022.
  1. Apr 13, 2025 at 3:22 PM
    #2161
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    T off of the vacuum/ boost line going to your gauge and attach to the fp regulator.
  2. Apr 13, 2025 at 3:28 PM
    #2162
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Don't you run a stock intake setup? If so it's already boost referenced since it's seeing boost.
  3. Apr 13, 2025 at 3:30 PM
    #2163
    centex
    centex New Member
    It’s already setup that way. The FPR is tee’d into the main vac line coming from behind the TB.
    Define stock intake setup. If you are talking about the intake manifold then yes, stock.
  4. Apr 13, 2025 at 3:41 PM
    #2164
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Turbo vs SC reference points. Got it.
  5. Apr 14, 2025 at 6:36 AM
    #2165
    TurboKits
    TurboKits New Member
    Im thinking we adjust fueling off boost for the higher PSI fuel pressure and just leave it. Since we can get it to run 100% either way, why add the complexity of a switch and potentially an additional maintenance / failure point.
    Mdl, Wynnded and bflooks[OP] like this.
  6. Apr 14, 2025 at 6:46 AM
    #2166
    bflooks
    bflooks [OP] New Member
    Metrowest MA
    K.I.S.S. method for the win
  7. Apr 14, 2025 at 6:52 AM
    #2167
    TurboKits
    Exactly... I am off with the Kiddos for some spring break fun. Will be back on Wednesday if you guys don't get an immediate response. That is why!!
  8. Apr 14, 2025 at 7:00 AM
    #2168
    bflooks
    Metrowest MA
    Enjoy! I hope it is somewhere warm and sunny.
    TurboKits likes this.
  9. Apr 14, 2025 at 7:13 AM
    #2169
    bflooks
    Metrowest MA
    M3Tundra-JK likes this.
  10. Apr 14, 2025 at 8:20 AM
    #2170
    DiamondW
    DiamondW Stockblocker
    Kent
    CenTex
    ‘17 CM
    Damn you @centex I was set on just doing a Maggy but you had to mention this thread. After reading the whole thing over the last few days my old ways are coming back. I’ve never owned a SC and was thinking it would be a nice change, I built a turbo sport bike in the early 00’ and spent a good bit of years in the diesel performance world, and I think my old ways may flare up again.
    Jego, Tripleconpanna and M3Tundra-JK like this.
  11. Apr 14, 2025 at 8:25 AM
    #2171
    centex
    centex New Member
    I cut my teeth in the diesel world also. Back in 01 when it was a fringe movement. Something about a single 72 spooling to 60psi just does something to you.
    DiamondW likes this.
  12. Apr 14, 2025 at 8:33 AM
    #2172
    DiamondW
    Kent
    CenTex
    ‘17 CM
    It does indeed. If you ever spent any time around the track at Marion, I was the guy who broke this truck regularly… billet shafts couldn’t keep up with me trying to cut lights :rofl:
    I also managed to blow this bike up at the 8th mile mark but was pulling just behind a Busa, not bad for a stock length 600, but I got greedy with the boost.
  13. Apr 14, 2025 at 8:38 AM
    #2173
    centex
    centex New Member
    Never Marion. Did run at Little River a few times. P-Pump swapped 24v, Hamilton Cam, S472, DTT full billet, etc.
  14. Apr 14, 2025 at 8:47 AM
    #2174
    DiamondW
    Kent
    CenTex
    ‘17 CM
    Solid setup, sounds very familiar.
    I never ran anything up there, but went with a buddy for his C10 one night, cool track.
  15. Apr 14, 2025 at 10:05 AM
    #2175
    bflooks
    Metrowest MA
    So as to not clog up the SC Thread too much, I moved the stock intake manifold discussion here:
    Background: I'm looking for a replacement stock manifold to replace my "steam cleaned" original. A question came up about what I had planned that would require a second manifold.
    Negative. From what I read (very brief, part of a different search), porting these things yield negligible gains.
    Mdl and Black@Blue19 like this.
  16. Apr 15, 2025 at 4:49 PM
    #2176
    Jego
    Jego New Member
    Orlando
    PR
    2018 Tundra 1794
    Received my Dragy DRG70-C today :)
  17. Apr 16, 2025 at 6:12 PM
    #2177
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    Any differences over older models?
    Jego[QUOTED] likes this.
  18. Apr 17, 2025 at 8:52 AM
    #2178
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    From website:
    Updated hardware Dragy DRG70-C
    • Ublox 10th Gen high performance GPS Module (DRG69 the previous model was 8th gen)
    • Extremely low power consumption up to an incredible 25 hours + DRG70-C comes equipped with a USB-C charging port (DRG69 & DRG70 feature a micro USB charging port).
    • Better accuracy and positioning vs previous generation Ublox model.
    • Concurrent reception of up to four GNSS systems (GPS, Glonass, Galileo and BeiDou).
    Jego likes this.
  19. Apr 17, 2025 at 3:32 PM
    #2179
    centex
    centex New Member
    Another 400 mile road trip done. 12.5-13mpg. Got to hot rod it for some work colleagues and they were impressed. Doing another 400 miles this weekend. Truck is driving great. Bumping the pressure up really made a big difference in how it drives. It’s much more responsive and the turbo comes on even better. To say I’m happy is an understatement. I’m gonna let it go for another week then bump the boost up a bit more. For now I’m just enjoying driving it.
  20. Apr 17, 2025 at 3:50 PM
    #2180
    bflooks
    Metrowest MA
    Remind us, please. 6.5/7.0psi?
  21. Apr 17, 2025 at 5:01 PM
    #2181
    Jego
    Jego New Member
    Orlando
    PR
    2018 Tundra 1794
    Additionally, I watched some videos on YouTube comparing the old dragy with the new one, where the new version showed faster results and smoother graphics, confirming higher accuracy.
  22. Apr 17, 2025 at 5:14 PM
    #2182
    centex
    centex New Member
    6.5-6.8. And it’s happy at that. Ran it through three gears and AFR’s with meth we’re solid 11.6.
    Jego and bflooks[QUOTED][OP] like this.
  23. Apr 17, 2025 at 5:56 PM
    #2183
    bflooks
    Metrowest MA
    6.7psi got me a 5.21s 0-60 time. It's a bunch of fun and super safe. Enjoy it! Sounds good, pulls hard, faster than many.
  24. Apr 17, 2025 at 6:27 PM
    #2184
    centex
    centex New Member
    I’m not done yet. If the supercharger folks are running 12-14psi I see no reason we can’t hit 8-10psi. I’m for sure going to finish up in the 7’s. Just busy right now and no time to test.
  25. Apr 22, 2025 at 8:12 AM
    #2185
    centex
    centex New Member
    Test 1 2. Mic check.
    bflooks[OP] likes this.
  26. Apr 22, 2025 at 8:39 AM
    #2186
    bflooks
    Metrowest MA
    You caught some behind the scenes ninja stuff happening. ;)
    centex[QUOTED] likes this.
  27. Apr 22, 2025 at 6:52 PM
    #2187
    Jego
    Jego New Member
    Orlando
    PR
    2018 Tundra 1794
    Ordered the 2 elbows to make the full bypass. Wondering if you used any fipg sealant or rubber ring to prevent leaks?
    centex, bflooks[OP] and Mdl[QUOTED] like this.
  28. Apr 22, 2025 at 6:56 PM
    #2188
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    You need two o-rings on the threaded side. 90301-11030 I just used some that were the size of the o-rings from the puck and those could be reused too.
    Jego[QUOTED] and bflooks[OP] like this.
  29. Apr 22, 2025 at 7:04 PM
    #2189
    Jego
    Jego New Member
    Orlando
    PR
    2018 Tundra 1794
    Thank you!
  30. Apr 22, 2025 at 7:39 PM
    #2190
    centex
    centex New Member
    Another 800 miles in 5 days. Been enjoying the power. I absolutely love the boost solenoid control from the scg1. I leave it off and still get 3.5-4psi which is fun for most things but its low enough I can throw the keys to my wife or whoever and I don’t have to worry about it.
    Still kicking around adding more boost but I’m curious to see how @TurboKits testing is going on their 2016 truck and what they’ve found for limits.
