Custom Driving mode.. the problem
Discussion in '3rd Gen Tundras (2022+)' started by JohnF4x4, Apr 16, 2025.
  1. Apr 16, 2025 at 4:12 PM
    JohnF4x4
    JohnF4x4 [OP] New Member
    US
    2025 Platinum Windchill Pearl with AVS
    Today finally brought home my new 2025 Platinum with Adaptive Variable Suspension system
    While trying to setup "Custom" mode the second item "Suspension control in Custom
    mode*" supposed to have three options like on the picture from the user manual "Normal" Sport" and "Comfort", however, on the display menu there are only two options, "Normal" and "Sport". The "Comfort" is missing.
    Am i doing something wrong or it is some issue with this car?
  2. Apr 16, 2025 at 6:20 PM
    lapoolboy
    lapoolboy New Member
    No idea but it's a truck.
    Terndrerrr, Blufin and Wallygator like this.
  3. Apr 16, 2025 at 9:04 PM
    gdisarray
    gdisarray Short term member
    2023 Tundra Limited HV
    Tint and wheels. Decked box in the bed. S and B Cold Air filters under the hood. Shiftpower throttle response controller.
    I would think that since it is a Platinum, that standard mode would be the "Comfort" mode.
  4. Apr 16, 2025 at 11:51 PM
    PNW Tundra Mike
    Back in So Cal
    MX4 Tonneau, Talon's Trans/Cat Shield, Vantrue Cam
    No idea what you just said because I can never get past your avatar :)
  5. Apr 17, 2025 at 3:56 AM
    Blufin
    Blufin Seasoned member
    Bob
    Cape Cod,MA.
    23 Capstone
    Good guess but no,Regular or standard is the norm,if you leave it in Sport+,Sport or custom mode when you turn it off,it will default to Regular/normal when you fire it back up.
    As for OP,I'm not sure why Comfort mode isn't being recognized.
    If you just brought it home I'd go back to the Stealership and get it straighten out,because it should be there
  6. Apr 17, 2025 at 5:35 AM
    JohnF4x4
    US
    It is not where problem is. Look at the top position on your picture. There us "custom " mode. When you choose it There supposed to be options. There I miss the "comfort " mode!
  7. Apr 17, 2025 at 5:39 AM
    Blufin
    Bob
    Cape Cod,MA.
    23 Capstone
    Ahhh got it,sorry about that.
    Soooo if my memory serves me correct,go to the infotainment center and there you can make your adjustments for the custom mode.
  8. Apr 17, 2025 at 7:15 AM
    JohnF4x4
    US
    It is exactly what i say, there is no "comfort" option to chose it there, only normal and sport , see my first post with the image
  9. Apr 17, 2025 at 7:40 AM
    LunaTuna
    LunaTuna New Member
    He said something ? lol
    yeah I think you should have all 3 options
  10. Apr 17, 2025 at 8:01 AM
    J_haus
    J_haus New Member
    Josh
    TN
    2023 Blueprint Tundra Platinum 4x4
    Stillen Trucontrol BAK Flip F1
    23' Platinum and same as you're getting. Only options within Settings in the "custom drive mode" for "suspension" are Sport and Normal.
  11. Apr 17, 2025 at 8:04 AM
    Blufin
    Bob
    Cape Cod,MA.
    23 Capstone
    I think this is what you are missing,this is what I had mentioned in my 2nd.post...
    FYI I can't see your pic,it won't open.
    If this ain't it then I dunno:facepalm:
    J_haus likes this.
  12. Apr 17, 2025 at 8:14 AM
    J_haus
    J_haus New Member
    Josh
    TN
    Wondering if it's a Capstone feature. This is what is available in mine and what is shown in my manual.
    Tundrastruck91 likes this.
  13. Apr 17, 2025 at 8:17 AM
    Blufin
    Bob
    Cape Cod,MA.
    23 Capstone
    Huh,that's weird, do you have load leveling?
    I'm reaching here...
  14. Apr 17, 2025 at 8:35 AM
    J_haus
    J_haus New Member
    Josh
    TN
    I do on mine.
    No idea why it wouldn't have that selection available.
  15. Apr 17, 2025 at 8:47 AM
    DRP
    DRP Old Member
    Dave
    Just checked my 1794 with AVS and air bags. I don't have comfort mode available either in the custom settings.
  16. Apr 17, 2025 at 8:54 AM
    Blufin
    Bob
    Cape Cod,MA.
    23 Capstone
    Sorry to hear this and I'll be 100% honest with you both.I never use Custom mode and your not missing anything "ground breaking",I basically use Sport+,Tow+ and comfort mode.
    Tow+ for fucking around with the guy next to me at a light and strictly comfort mode for the HWY.
    DRP likes this.
  17. Apr 17, 2025 at 10:09 AM
    J_haus
    J_haus New Member
    Josh
    TN
    2nd on this, in the almost 2 years and 40k miles I've had mine I have put it in custom about 4 times. Mine lives in Normal unless driving in certain situations to which I'll flip it to comfort, sport +/S, or Tow.
    DRP and Blufin[QUOTED] like this.
  18. Apr 17, 2025 at 3:06 PM
    JohnF4x4
    US
    Exactly!!! It is what i'm missing and "Comfort" is supposed to be there. There only normal and sport. Found some complains about 2024 Taco with same issue. They say there is TSB about it. My hope was some of the 3rd gen tundra has same issue and would recommend a solution
  19. Apr 17, 2025 at 3:12 PM
    JohnF4x4
    US
    1. I payed for this option and would like it to work.
    2. I was looking for this option all over, waited 4 month for this car, why would i compromise? I could pay $1K less and get a car in 20 minutes locally without driving 2 hours each way
    3. I want to use "Sport" for power, "Comfort" for suspension and "Sport" for steering, and again, look the #1 and #2 above ;)
  20. Apr 17, 2025 at 3:49 PM
    DRP
    DRP Old Member
    Dave
    What truck is this picture from? Capstone?
  21. Apr 17, 2025 at 3:52 PM
    Blufin
    Bob
    Cape Cod,MA.
    23 Capstone
    First off nice Avatar :thumbsup:
    Yeah,I hear ya man you paid for it and yes it should be there,I too built mine from the ground up and waited 4.5 months.
    In all honesty thou I've maybe used Custom mode only few times just because it's there.
    Tow+,Comfort and Sport+ is the only way I roll and I wish you luck in your quest and it goes your way.
  22. Apr 17, 2025 at 3:53 PM
    Blufin
    Bob
    Cape Cod,MA.
    23 Capstone
    Mine.
  23. Apr 17, 2025 at 5:07 PM
    DRP
    DRP Old Member
    Dave
    Oops, missed that from your earlier post. I would say my truck should have the comfort option as well but I really don't care so probably won't do anything about it. I wonder if having the dealer reload the software would help? Or find out what that TSB says for more info?
    Blufin[QUOTED] likes this.
  24. Apr 17, 2025 at 7:14 PM
    gnc1017
    gnc1017 New Member
    22 Tundra Platinum Hybrid 6.5 Blueprint
    1.75 leveling kit Nitto Ridge Grappler tires (305/55/20) Black Rhino Arches Gunmetal wheels Truxedo Deuce cover w/ TonneauMate box
    PXL_20250418_020805952.MP.jpg Comfort suspension is an option for my Custom mode as well. So weird.
  25. Apr 19, 2025 at 12:15 PM
    Gepperso
    Gepperso New Member
    Greg
    Georgia
    2022 1794 Smoked Mesquite
    Talon Garage Catt Shield, 2 K&N Air Filters, Thorton Chip Tuning
  26. Apr 19, 2025 at 12:28 PM
    Breathing Borla
    AZ
    Hybrids have that option , standard do not,
    as to why, only the mothership knows, but there is nothing “wrong” with truck.
    DRP likes this.
  27. Apr 19, 2025 at 3:58 PM
    JohnF4x4
    US
    Thanks, do you have a source for this info? I'd like to see there what else i'm not supposed to get.
    Also, can it be added using tech stream or whatever the name of this professional tool is?
  28. Apr 19, 2025 at 6:45 PM
    Breathing Borla
    AZ
    I’m not sure what you mean by source , I said I don’t know why .
    it’s just the way it’s been since release in 22, the hybrids had comfort in custom the standard do not , I don’t even use custom with all the other modes so it doesn’t bother me
  29. Apr 19, 2025 at 7:30 PM
    JohnF4x4
    US
    You learned it from somewhere, right?
    can it be added using tech stream?
  30. Apr 19, 2025 at 7:52 PM
    Breathing Borla
    AZ
    i learned it from the fact that nobody in a non hybrid has that and never has, it’s been discussed before here, so I was just relaying that to you
    I’ve never seen anyone add it and I highly doubt it can be.
    So what combo are you wanting that bad that this is upsetting
    you have comfort mode, sport , sport +, normal , and lame ass eco . Plus you can do a few custom ones.
    im either comfort , sport +, or tow , tow+
    those are the ones that matter to me
