  1. Apr 16, 2025 at 3:56 PM
    14crwmaxltd
    14crwmaxltd New Member
    T.
    2014 crewmax 4x4 Limited
    Leer cap
    Installed a repaired heat shield above the tailpipe that attached to the bed underside.
    Put the front skidplate back on after cleaning things up a bit, under there.
    Parked next to my trucks big brother while picking up some grub
  2. Apr 16, 2025 at 4:13 PM
    koditten
    Kirk
    Midland of the Mitten
    Mine have been gone for the last 5 years. I've been wondering what the results would be, but can claim no excitement.
    14crwmaxltd likes this.
  3. Apr 16, 2025 at 4:37 PM
    14crwmaxltd
    T.
    Leer cap
    I guess it is there to minimize water from blasting the front diff in the rain
  4. Apr 16, 2025 at 4:41 PM
    14crwmaxltd
    T.
    Leer cap
    I found a ton of leaves inside the front frame near where the cab mounts are located. I guess the leaves get sucked into the frame, even though the opening faces rearwards. Finally got use of a 2' long blowtip i bought for my compressor, years ago
  5. Apr 16, 2025 at 4:46 PM
    14crwmaxltd
    T.
    Leer cap
    Removed the factory nerf bars / steps, so I can blast and coat the mounting brackets. Broke 2 bolts off in separate locations, so Ill need to figure out a fix
    Tripleconpanna and bulldog93 like this.
  6. Apr 16, 2025 at 5:13 PM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    2020 SR5 Barcelona Red Tundra
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 Coachbuilder Shackles 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI
    PXL_20250331_011552993.MP.jpg :)
  7. Apr 16, 2025 at 5:25 PM
    2014 Black tundra
    2014 Black tundra New Member
    2014 tundra sr5
    Looks nice. :thumbsup: Looks like the sidewall is flush with the fender flares. That’s perfect in my opinion.
  8. Apr 16, 2025 at 5:34 PM
    Pimpala1962
    Pimpala1962 New Member
    Kyle
    Massachusetts
    2015 double cab
    HulkSmurf14 likes this.
  9. Apr 16, 2025 at 5:43 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    New high output Alternator on the way and upgraded steering rack bushings. Might as well while it’ll be apart
  10. Apr 16, 2025 at 5:52 PM
    koditten
    Kirk
    Save those mounting bushings from the old alternator. Most new ones don't come with them.
    It sucks because the bushings are carbon steel and the alternator housing is aluminum. Those 2 parts galvanic weld to each other.
    I had to destroy my old alternator housing to salvage those mounting bushings.
    Let us know if they are now coming with bushings included.
  11. Apr 16, 2025 at 6:34 PM
    SwitchThrottle
    2021 Barcelona CrewMax
    ...on the Sequoia door handles...fronts and rears are direct replacements for our trucks?
    HulkSmurf14 and Corndog123 like this.
  12. Apr 16, 2025 at 6:37 PM
    jackienguyener
    jackienguyener OKToyota
    Jackie
    2016 Tundra 1794
    I’ve had mine for a few years now with no issues. Just full disclosure, there have been quite a few instances of very poor customer service with them, but I’ve been pretty lucky with purchasing these lights and their window modules.
    Boneskull420, Jego, GAknight and 4 others like this.
  13. Apr 16, 2025 at 6:39 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    Yup
  14. Apr 16, 2025 at 6:42 PM
    SwitchThrottle
    1UP[QUOTED] likes this.
  15. Apr 16, 2025 at 9:09 PM
    Pimpala1962
    Kyle
    Massachusetts
    2015 double cab
    I saw after i ordered them that it says only for driver side auto , i have a limited and have the auto windows on both driver and passenger , think itll work ?
  16. Apr 17, 2025 at 3:04 AM
    jackienguyener
    Jackie
    2016 Tundra 1794
    They have a kit for 2 auto switches now for the harness. They didn’t when I first ordered so I had to hardwire the passenger side. Driver side was plug and play.
    JMGmanAZ and HulkSmurf14 like this.
  17. Apr 17, 2025 at 3:12 AM
    Corndog123
    Corndog123 New Member
    Sam
    Tennessee
    2014 SR5 Tundra Crewmax 4wheel drive 5.7
    Rough Country suspension, 305s, ARB bumper, light bar, Smittybuilt 10k winch. XD Buck 25 rims
    Oh wow, no way!? That would be nuts!! On my way to and from Atlanta I like that it's an easy drive for the most part, lots to look at. But Cleveland merging with Chatt. would be something else. Like a suburb of Chattanooga or something.
    Boneskull420[QUOTED] likes this.
  18. Apr 17, 2025 at 3:24 AM
    Abell207
    Abell207 New Member
    Anthony
    Maine
    2020 Army Green TRD PRO
    Which alternator did you go with?
  19. Apr 17, 2025 at 3:28 AM
    Corndog123
    Sam
    Tennessee
    Not sure if you would want to do this or not but I'd be really interested if you would do a sort of step by step of what needs to be done with your Tundra. With pics of course....ha ha ha
    Anyway, I'm sure others here would find it interesting as well. But no problem at all if you'd rather not do that. I know how we only have so many days in the week.
    BR73 likes this.
  20. Apr 17, 2025 at 5:08 AM
    Corndog123
    Sam
    Tennessee
    Oooooo I like that!!
    BR73[QUOTED] likes this.
  21. Apr 17, 2025 at 5:37 AM
    Dr3wski
    Dr3wski New Member
    2018 SR5 4x4
    What did you use for the ambient light strip on the passenger side of the dash?
  22. Apr 17, 2025 at 5:47 AM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    Thanks and the install wasn't bad.Cutting the dang template off the shipping box was a PITA .I used an exacto knife and scissors for the template and a carpet knife for the removal of the carpet/insulation.I wanted a tight fit so I cut to the slim side
    Corndog123[QUOTED] likes this.
  23. Apr 17, 2025 at 5:59 AM
    jackienguyener
    Jackie
    2016 Tundra 1794
    It’s a Dreamcolor ambient lighting kit from Amazon. It’s been a few years so I don’t have a link handy.
  24. Apr 17, 2025 at 6:03 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Don't know haven't done it yet....
  25. Apr 17, 2025 at 6:13 AM
    14crwmaxltd
    T.
    Leer cap
    Changing rear diff fluid. Old fluid is actually pretty clean, but 100k on the clock.
  26. Apr 17, 2025 at 6:17 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Wallygator, bflooks, Mdl and 3 others like this.
  27. Apr 17, 2025 at 6:19 AM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    bulldog93 and reywcms[QUOTED] like this.
  28. Apr 17, 2025 at 6:20 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Well these will be thrown in when the motors out. So little bit different process of install than what most will do. @snivilous will be doing the work since I’m deep in work season and have zero time. I’m sure he will share a ton of pics as we progress. Got some other things in mind to update as well in other areas while it’s down.
  29. Apr 17, 2025 at 6:21 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    LOL
  30. Apr 17, 2025 at 6:29 AM
    TundyManFL
    TundyManFL New Member
    2021 MGM TRD Pro CrewMax
    What's the knob for? Volume?
