SOLD: Used SABM kit, almost everything you need to install, $50 delivered to CONUS, PayPal only
Discussion in '2.5 Gen Tundra Parts Marketplace (2014-2021)' started by Cthulhu, Apr 16, 2025.
Thread Status:
Not open for further replies.
  1. Apr 16, 2025 at 11:27 AM
    Cthulhu
    Cthulhu [OP] The White and Black Goat of the Woods
    So after a few 4 months of having the SABM, I've decided to remove it. Although it sounds fantastic, since i upgraded to 5.29's which pretty much restored my power, I am returning a lot of the mods I did to increase power to OEM; if there's a chance any of the "power" mods are detrimental to longevity of the truck, I'd rather err on the side of caution, because I want to be buried in this truck. Besides, not sure how much power is really gained on a NA 5.7; only really saw evidence of it benefitting FI engines.
    So, if anyone wants my used SABM kit that I made, I'll be happy to send it to you for $50 delivered to CONUS, PayPal only please. Will include (2) clamps for the short intake tube, the short intake tube (already cut for the distance between the air box bottom and the inner fender well), the air box bottom with the hole drilled out and the intake tube plate already mounted to it (what's cool about me offering this included is that you can keep your OEM air box bottom if you don't like the SABM, and all you have to do is reinstall your original box, and plug the hole in the inner fender well), and I'm even throwing in the hole saw, which I only used once to drill the holes. Only thing you would need to do is clean up the old caulk, reapply new caulk when installing (to eliminate any whistling that has occurred on some installations of the SABM, right @RainMan_PNW :D?), drill the hole in the inner fender well, and provide four fine thread stainless steel sheet metal screws for the intake tube plate that mounts to the inner fender well. Thanks in advance for any interest! :thumbsup:
    What you'll get:
    Before I removed it:
  2. Apr 16, 2025 at 12:11 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    That’s a good deal!
    Cthulhu[OP] likes this.
  3. Apr 16, 2025 at 3:05 PM
    AZTundra
    Paul
    Phoenix, AZ
    Was this one of the pre-made SABM kits out in the market or was this a kit that you pieced together? I'm FI and have been contemplating doing this mod. This would be a no brainer as you mentioned and would retain my current airbox. Not sure if you can save my spot in line while I wait for a response, but I'm 99% sure I'll take it. Let me know.
  4. Apr 16, 2025 at 3:27 PM
    Cthulhu
    It’s one I put together myself, using this as a guide: https://www.tundras.com/threads/alternative-stock-air-box-mod-sabm-cheap.3428/
    I’ll PM you. :thumbsup:
    TRDFerguson and AZTundra[QUOTED] like this.
  5. Apr 16, 2025 at 3:32 PM
    Cthulhu
    Pending sale.
  6. Apr 16, 2025 at 3:39 PM
    Cthulhu
    TRDFerguson and AZTundra like this.
Thread Status:
