Method 318
Discussion in 'Wheels & Tires' started by Goingbroke, Mar 30, 2023.
  1. Feb 27, 2025 at 8:19 PM
    Mike1305
    Mike1305 New Member
    2011 White SR5
    Bilstein 5100’s on middle setting. I did not do any trimming and there is no rubbing whatsoever. BUT, in my experience, the BFG’s im running tend to run a little smaller than other brands in that size, so test fit whatever you’re thinking of putting on.
    1G3 Tundra likes this.
  2. Feb 28, 2025 at 9:57 AM
    1G3 Tundra
    1G3 Tundra New Member
    thanks man, that's definitely a helpful data point. I keep hearing mixed things about tire size fitment on stock suspension.
  3. Feb 28, 2025 at 2:05 PM
    Mike1305
    Mike1305 New Member
    2011 White SR5
    I’m sure you would be fine if you went with the same size tires with stock suspension. They are only 1 size bigger than what came on the truck. If not, well then you have an excuse for adjustable bilstein’s :D
  4. Mar 13, 2025 at 9:36 AM
    1G3 Tundra
    Ended up going with the Method 318 in 40mm offset. Tires are Yokohama Geolandar X-AT's 285/65R18 which offer a bigger look than stock but don't rub at all which is great. Totally stock suspension as of right now but planning to do the Eibach stage 2r kit in the next few months.
    attillatundra likes this.
  5. Mar 17, 2025 at 5:18 AM
    attillatundra
    attillatundra New Member
    Looks really nice. I have been eying those wheels. Any issues with balancing the Yokohamas? Also, how is the ride with those? TIA
  6. Mar 17, 2025 at 7:20 AM
    1G3 Tundra
    The Yokohama's seem pretty good so far. I got them in standard load range vice the E load which really helps with ride quality. They balance well and arent too loud on the highway. They balance better than wildpeaks and KO2s ive had in the past. Hope this helps.
  7. Mar 17, 2025 at 7:55 AM
    attillatundra
    Thanks. Appreciate the input. It's hard to find the best tire these days to address multiple needs without sacrificing too much with on road manners.
  8. Apr 16, 2025 at 8:25 AM
    Tundra694
    Tundra694 New Member
    AJ
    2021 Tundra Crew Max Trd Off Road
    For comparison sake do you have a front shot to see the side poke ? I had 18x9 +40 AR201s with 285/75R18 Duratracs and the poke was a little much. I kept the tire and put it on BBS pro wheels. I like the look but it runs the sway bar now. Now thinking of these methods and wondering if the 1/2” less rim width will keep it tucked in a little bit more. It never ends I need to stop with the wheel changes. …. Pic of my poke with the AR201. Pic of current pro wheels. Love the style but my truck looks like it skips leg day now.
    Tundrav82019 likes this.
  9. May 24, 2025 at 11:42 AM
    Tundrav82019
    Tundrav82019 I have all the duckies
    Leo
    2019 Tundra Limited TRD Off Road
    Which offset are these, +18 or +40?
  10. May 26, 2025 at 5:02 PM
    17inferno
    17inferno New Member
    mine are 18x8.5 +40. 295/70 18 michelin defenders
