2024 (3rd Gen) / Non Hybrid / JBL Audio - Upgrade thread
Discussion in 'Audio & Video' started by Bigbeckster, Oct 4, 2024.
  1. Oct 30, 2024 at 6:13 AM
    #61
    Bigbeckster
    Bigbeckster [OP] New Member
    2024 Tundra TRD OF package
  2. Nov 7, 2024 at 6:27 PM
    #62
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    Not sure I understand your position there.
    Neither TT nor AHH are using matching Toyota colors on their jumper harness.
    What makes the TT more user friendly?
    I not trying to debate the merits of one over the other. They both do the same thing and I'm sure both will work fine.
    AHH does give you the option to break out whatever wires you choose to pigtail, so that's why I went with them.
    I was able to get the pinout of the 30-pin connector from Brian at AHH so I know exactly which speaker circuits I'm dealing with.
    @brianNC44
    Thanks Brian!
  3. Nov 7, 2024 at 6:52 PM
    #63
    BlackNBlu
    Rich
    MN
    According to the pinout chart I have: (from AHH)
    6 pigtail wires on TT harness left to right:
    Pin 1: yellow: 12V+ constant
    Pin 3: black: ground
    Pin 20: SUB - (negative)
    Pin 5: SUB + (positive)
    Pin 14: LH Front Door + (positive)
    Pin 29: LH Front Door - (negative)
    eddiefromcali[QUOTED] likes this.
  4. Nov 7, 2024 at 8:17 PM
    #64
    Bigbeckster
    I'll be honest I originally responded this while working. I think I had in my head it was the picture of the factory harnesses.
    You are totally correct it doesn't matter on either company. Because this is a completely new harness anyways. You can just match it up.
    BlackNBlu[QUOTED] likes this.
  5. Nov 8, 2024 at 6:20 AM
    #65
    BlackNBlu
    Rich
    MN
    Scope creep incoming.
    So I did a thing. If you scroll back to post#53 you'll see I posted a pic and a link to a PPI 3-way component set, and of course I bought it.
    I know they're not Focals or Morels, or even JL's, but I doubt my old ears are gonna know the difference.
    Seeing as how this was meant to be a "budget" system upgrade, up to this point using what are essentially previous vehicles cast-off audio parts, I wasn't about to spring for a $600+ set of components.
    I'm driving the whole shebang with a 10 year old, 5-channel PPI amp, so why not a PPI component set?
    The scope creep part is that speaker upgrades (beyond subwoofer) were going to be stage 2 of this project. Well, they just got rolled into stage 1. Wish me luck.
  6. Nov 8, 2024 at 11:06 AM
    #66
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Just like their post described.
    I'm going to look into low freq bass blockers for the front doors as they are very bass biased.
  7. Nov 8, 2024 at 6:21 PM
    #67
    Bigbeckster
    Don't believe you have gotten everything hooked up yet, but wonder if you just control the bass output on the LC7i, and completely lower the bass from the head unit? What it would sound like.
  8. Nov 9, 2024 at 6:38 PM
    #68
    BlackNBlu
    Rich
    MN
    Sub box (re)build is done.
    Down-firing, single 10" MB Quart Discus DS1-254 in a sealed 3/4" MDF box. It has dual, 4-ohm VC's that I'll be running at 2 ohm from the PPI 900.5 amp.
    It was previously just a free-standing rectangular box that I originally built for a Scion TC hatchback. It sounded amazing. Tight. Accurate bass. Not boomy, but plenty loud.
    Pics will show the angled "addition" that sits on the center tunnel in the underseat storage area that brings the box volume out to the recommended .65 cubic feet. It was undersized before, just under .50
    After smoothing everything out and rounding all the edges, I finished the MDF in Rustoleum 2X Ultracover Paint & Primer in 4 coats of gloss Deep Blue. Followed that up with Rustoleum "Stone" in "Granite" textured finish to help hide imperfections. (The original box was covered in black Plasti-Dip.) I think it turned out OK. I just hope it sounds as good as it did in the Scion.
    And of course, stickers for added HP. Because Racetruck. :rolleyes:
    Oh yeah, the "JBL" sticker is going to get a red "X" across it via some red vinyl pinstriping.
    Sub-bottom side.jpg side view showing angle and terminals.jpg Top-visible side.jpg Box in place.jpg
    Next step: Amp and LOC mounting on the back cab wall.
  9. Nov 9, 2024 at 6:58 PM
    #69
    eddiefromcali
    Eddie
    100% Stock
    Idk if that's possible with the jbl setup and might a lot more work too.
  10. Nov 9, 2024 at 8:01 PM
    #70
    Bigbeckster
    Yeah, I haven't found a real clear answer. This what I did in my 2011 GTI. Turned the bass basically off (@headunit), and controlled all the bass through LOC and Amp. Worked great and kept from my doors rattling.
  11. Dec 12, 2024 at 4:49 PM
    #71
    Frank_TRD23
    Frank_TRD23 New Member
    Frank
    2023 Tundra TRD Mag grey
    1.5 Wescott lift 20" wheels on 37s Stillen Trucontroller
  12. Dec 12, 2024 at 4:56 PM
    #72
    Snert
    Snert New Member
    2021 SR5
    $1500 for just the pillars, no speakers. Only explanation I have is that it takes quite a few hours to do custom work like that. Pillars are probably $100-$150 a piece and then $1000 in labor. Personally I’d do it myself (although it would be nowhere near as nice as theirs) and anybody could do it for ~half the cost or more if you have the time/patience.
  13. Apr 14, 2025 at 8:46 PM
    #73
    Swifty26
    Swifty26 New Member
    2025 Tundra Limited
    Hey all.
    I’m attempting to add an amp and new component speakers to the front and rear doors. I purchased the TT make your own harness wire adaptor. They do not provide a stock wiring diagram explaining which wires to tap from. My plan is to buy AudioControls 4.800 amp, sum the signals from the stock woofers and tweeters in the amp, while using the factory wiring. (The only thing that was respectable in the truck.) Then run the power to the passive crossover supplied with the Infinity components. I have been taking notes of the wiring from the stock speakers, but it would be helpful to have the 30 pin color diagram.
    Thoughts on if this will work? Did I miss the colored 30 pin call out?
  14. Apr 15, 2025 at 12:36 PM
    #74
    Wtundra2023
    Wtundra2023 Bad Weld Aficionado
    2023 Limited Tundra, 2014 Limited Sequoia
    Has you verified the sum of the a pillar tweeters and front door speakers represents a full range signal? I am considering a similar route but my sticking point is the possibility the fronts are an active 3 way system where the dash speakers are supplied a midrange signal that isn't provided to the doors or tweeters and would leave some frequency ranges out of signal being summed.
  15. Apr 15, 2025 at 9:50 PM
    #75
    Swifty26
    Swifty26 New Member
    2025 Tundra Limited
    I haven’t but that’s a good idea. I’d probably go to a local studio shop so they could assist.
    I did have a thought today when I was swapping out the rear door speakers with 6.5” infinity components. I wonder if those high level speakers inputs would provide the full range to feed the output channels? I know one of the AC amps will copy the signal from channel 1&2 to 3&4, not sure about the 4.800?
    Also, when I added the power leads to the crossover on the rear door, no music was playing. I’ve read that the woofers and tweeters are in parallel and must be used to complete the circuit. I plugged the stock tweeter back in, all 3 speakers worked. I left it plugged in for now until I figure out how to integrate this amp.
    On another note, I decided to replace the 6.5” components in the front with 6x9 components. It took a couple spacers to accommodate for the extra depth, but they fit. They sound way better than the stock. Now I really have to get that amp installed.
  16. Apr 16, 2025 at 6:46 AM
    #76
    Wtundra2023
    "I haven’t but that’s a good idea. I’d probably go to a local studio shop so they could assist." -- If you do find anything out, please report back it would be greatly helpful to many here, myself included.
    "I did have a thought today when I was swapping out the rear door speakers with 6.5” infinity components. I wonder if those high level speakers inputs would provide the full range to feed the output channels? I know one of the AC amps will copy the signal from channel 1&2 to 3&4, not sure about the 4.800? " - - Take a look at the block diagram from the amp. on the LC6.1200 only the front high and front 1/2 channels are summed. The LC 4.800 looks to do the same. The rest are just amplified.
    "Also, when I added the power leads to the crossover on the rear door, no music was playing. I’ve read that the woofers and tweeters are in parallel and must be used to complete the circuit. I plugged the stock tweeter back in, all 3 speakers worked. I left it plugged in for now until I figure out how to integrate this amp." - - You have to use a connector like this one plugged into the tweeter connector - https://www.amazon.com/dp/B07RMZ4CR6?ref=ppx_yo2ov_dt_b_fed_asin_title to get the woofer to work as they are wired together. It is a full range signal but the bass is tuned down pretty low in the rear. This is how I wired mine using that adapter. Note the red input wire (typically noted as +) from the factory amp is going to the negative terminal on the crossover. This is due to the adapter being set up with the polarity opposite of how the truck wiring is set up. After the crossover, wire everything normally if using a factory wiring set up. Probably want to draw it out to make sure you get it right.
    "On another note, I decided to replace the 6.5” components in the front with 6x9 components. It took a couple spacers to accommodate for the extra depth, but they fit. They sound way better than the stock. Now I really have to get that amp installed." - - 6X9's are stock on the JBL equipped trucks. I used this adapter and drilled the holes out to make it work with my 23. https://www.amazon.com/dp/B00IIC6CPE?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1. You will want to get longer screws with larger washers if you go this route as the modified adapter holes may become a bit too large for the factory screws/washes. I found the screws used to secure the mudflaps work well for this (I had extra from when I added mud flaps to my truck).
    This thread documents part of the work I did on my truck. I am not running the beatsonic dsp currently. I wanted to work out the system to play nice with the factory amp first then maybe add it later. https://www.tundras.com/threads/2023-w-jbl-audio-speaker-replacement.154664/#post-3865522
  17. Apr 16, 2025 at 1:17 PM
    #77
    Swifty26
    Swifty26 New Member
    2025 Tundra Limited
    Thanks for sharing. My 2025 Tundra with JBL definitely came with 6.5” components in the front and rear doors.
    I’ll order a couple of those adaptors. I ran the power from the woofer to the crossover. And I agree that the bass is turned way down in the rear.
    Would it make sense to use the rears high levels to feed the amp? I’m still not sure how to wire it, but it arrived yesterday.
  18. Apr 16, 2025 at 1:31 PM
    #78
    Wtundra2023
    For the rear door, its a full range signal that is fed into the connector at the tweeter. The positives and negatives of the tweeter and the woofer are connected together inside the connector on the back of the tweeter. Instead of doing what I did, you could connect to the tweeter using the adapter I linked too, wire that to the input of the crossover and then use your own leads to connect to the woofer and tweeter ignoring the factory woofer connector.
  19. Apr 22, 2025 at 10:56 AM
    #79
    Swifty26
    Swifty26 New Member
    2025 Tundra Limited
    Right on. It sounds odd that there’s full range signal being sent to/thru the tweeters, but I like your suggestion. Then I’ll run power from the P crossover to the woofer using those adaptors to connect to the tweeters.
    I watched the AudioControl LC 4.800 video on YT. He installed tweeter high level inputs for a high range and midrange HLI and then summed them in the amp. (Which is why I bought this model). Thinking about it, could I just use the rear speaker level inputs, sum them, and feed the fronts and rears? I was planning on using the stock wiring and splice the amp in using an aftermarket harness. But if it’s easier to do this knowing I get full range from the rear doors, I would run new wire to feed the fronts.
    It’s hard to know exactly since so many of these speakers are run in parallel with eachother
  20. Apr 22, 2025 at 11:22 AM
    #80
    Wtundra2023
    Keep in mind that the connectors I have linked to have their polarity opposite the factory wiring. The red wires of the adapter will need to be connected to the negative input of the crossover. After the crossover everything can be wired normally (red = positive, black = negative). The wiring diagrams here https://www.tundras.com/threads/ultimate-tundra-wiring-diagrams-collection.81448/ help a lot in making it all work.
  21. Apr 22, 2025 at 11:23 AM
    #81
    Swifty26
    Swifty26 New Member
    2025 Tundra Limited
    Yep, I get it. I edited my last post and added another thought
  22. Apr 22, 2025 at 11:30 AM
    #82
    Wtundra2023
    You would loose a lot bass since the factory amp tunes that out. If and when I go down the amplifier route, I will install this an ap4-ty14 https://pac-audio.com/products/ap4-ty14. I have heard good things about it and it would eliminate the need for summing. I know you already bought the LC4.800 but the AP4-TY14 would complement it nicely and allow for a full range signal to be delivered to each location should you choose do it that way. Or you could use the built in crossovers.
  23. Apr 22, 2025 at 2:32 PM
    #83
    Swifty26
    Swifty26 New Member
    2025 Tundra Limited
    I did think about going that route. Almost too many ways to skin a car out there. I’ll think it over. Ultimately, I’ll swing through my local car audio shop and ask if they’ll use an RTA to verify the frequency range prior to installing the amp. Understood if I get the PAC, I won’t have to worry about that.
    A couple thoughts:
    1. If I grab the signal from the HU to the rear doors before the amp (using the AM harness) would you still have to worry about attenuation from the stock amp?
    2. With the PAC unit, you would get an AM harness for the stock amp out and connect whatever channels I’d want to power with the AM amp? The benefit is having full frequency sound?
  24. Apr 22, 2025 at 4:36 PM
    #84
    Wtundra2023
    - The signal from the back of the HU is full range, however, the volume control is handled at the factory amp not the HU. If you want to keep the functionality of the factory volume knob active, you have to get the signal at the amp or have something that can maintain that interface such as the PAC or the J.A.R.V.I.S from taco tunes. Its worth noting only the PAC will route your system prompts (navigation, beeps, etc..,) through your aftermarket amp
    There may be other units that do the same, but I haven't found them yet.
    The benefit is a full range signal with no time delays or other filters added into it. It would be clean. Very clean. It would greatly simplify the install. Instead of active fronts, you could go passive with a standard passive crossover, and since the voice prompts are routed through the PAC, you could effectively remove the dash speakers from the system. You could add a an active crossover in between thr PAC and amp and create an "Active" front system with the dash speakers that way. You could also do what I am thinking about and create a passive threeway front system. There is a lot more freedom when you go with the PAC. Its like the old school systems where you get a clean pre out signal from the back of the head unit and route it to the amp.
    PAC offer a harness that allow you to splice into all the factory amplifier speaker wiring. Its most complete harness i have seen offered without a special order. But it is purchased separately from the amp. You could purchase the harness and use that to sum the front highs and lows and route the AM amp back to the fronts assuming it provides a full range signal. If the channel summing doesn't work out, you could install the PAC later and simply cap off the output side of the factory amp and use the RCA's off the PAC and AM amp.
  25. May 1, 2025 at 12:45 PM
    #85
    Wtundra2023
    Did you ever stop by the audio shop and confirm if the signal produced from the tweeters and front doors can be summed to a full range signal?
  26. May 1, 2025 at 5:20 PM
    #86
    Swifty26
    Swifty26 New Member
    2025 Tundra Limited
    I did not. I’ve been stewing on your suggestions. I didn’t want to spend the money on the PAC unit, but I think it’s the cleanest way and most confident way to get the full range signal. (Sure an LOC would have been an option), but additional time installing the high level inputs just didn’t seem worth it and I have the amp.
    That being said the following items arrived this week:
    - PAC APH-TY02 Speaker Connection Harness
    - PAC AP4-TY14
    - Kicker 46CK4 4 AWG Amp Kit w/RCA
    - Red Wolf tweeter harnesses
    I’ve installed the aftermarket tweeters in the mirror trim cover on the driver and passenger door. That way I didn’t have to mess with the A pillar tweeter and it makes it easier to run wire to the crossover.
    Once I get everything installed, do you think I could use the stock wire (with tweeter adaptors) to power the aftermarket speakers or would it be easier to just run new wire? I’d hate to hook the stock wire up and blow something else downstream since some speakers are run in parallel? At this point running new wire wouldn’t be the end of the world, but I also wouldn’t mind using the stock wire. The plan is to use the LC-4.800. I’m hoping the Accubass feature helps with the bass drop off in the rear speakers.
    Thank you for all your help with this. Once I tear into it, and make good progress, I’ll post pictures to share.
  27. May 2, 2025 at 8:04 AM
    #87
    Wtundra2023
    - I have thought about this too. That location will help a lot with imaging. You can find the non-JBL a pillars on EBAY if you want to remove the OE tweeters. Another option is to tap into the factory wiring out of the amplifier for the fronts and install the crossovers under the seat. An integration harness from taco tunes or pac is available to access the factory wiring with out cutting https://www.amazon.com/dp/B0842BLRGM. That will allow you to only have to wire to under the drivers seat. If you want that harness, pick it up now from Amazon. The price on PAC's website increased to 110 bucks since I last looked at it.
    - For the rear speakers you can run the stock wire into the factory connector for the tweeter at the input of the crossover. From there you can either choose to use after market wiring to the woofer or connect the output of the crossover into the factory wiring for the woofer. The tweeter will require you to run new wire in the door. There is nothing other than the speakers downstream of the rear door tweeter connector so there is no worry of hurting the other speakers.
    #87
