Yakima track question
Discussion in '2.5 Gen Tundras (2014-2021)' started by Blkdmax, Apr 15, 2025.
  1. Apr 15, 2025 at 5:37 AM
    Blkdmax
    Blkdmax [OP] New Member
    Tennessee
    2021 Cement CrewMax 4x4
    I posted this in the camper shell forum but got zero responses.
    Just purchased a new to me leer 100r. It’s in the shop getting painted to match my truck as I type this. When I get it back I’m going to install tracks before I put the windows back in. Should I get the 54” tracks or 60” tracks?
    I understand I can just go measure my truck bed but I’m curious if the curvature of the camper shell will affect that measurement.
  2. Apr 15, 2025 at 6:01 AM
    I put 54” bars on my 2019 CM topper (also in cement). The rails came as 65” long. I cut them to length I believe.
  3. Apr 15, 2025 at 6:15 AM
    Blkdmax
    Tennessee
    Just to clarify you have 54” crossbars or tracks?
  4. Apr 15, 2025 at 6:25 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    What are you going to do with these rails? It's a lot of holes to drill, one or another will eventually compromise. I ended up installing a Holman aluminum rack w/ 2 rachet straps, it mounts on 4 posts, 2 holes each. Does not add much wind noise, if anything, can mount my 13 ft canoe firmly, bring long lumber from Lowes back home, have awning attached, etc, etc.
  5. Apr 15, 2025 at 7:17 AM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    I can measure my tracks later this morning. I swap between a Yakima system and a Prinsu Toprack.
    Blkdmax[OP] likes this.
  6. Apr 15, 2025 at 10:12 AM
    Blkdmax
    Tennessee
    Rtt, paddle boards, water port, awnings, quite a few plans. Really want a full track system
  7. Apr 15, 2025 at 10:15 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Weight maybe too much for Leer. Keep an eye on it.
  8. Apr 15, 2025 at 10:30 AM
    The rails, the part that mounts to the roof so that you can attach the cross bars, were 65”. Trimmable to customize length. The crossbars are 54”.
  9. Apr 15, 2025 at 4:43 PM
    mountainpete
    On my ARE cap, the rails (tracks mounted to the shell) are 50" long from front to back including the plastic caps.
  10. Apr 15, 2025 at 4:47 PM
    mountainpete
    It's an ARE cap, but some additional pics to give you an idea. They are older pics but still relevant here.
    Tundra805, KNABORES and Blkdmax[OP] like this.
  11. Apr 15, 2025 at 5:46 PM
    Blkdmax
    Tennessee
    Looks awesome man, thanks. I may get the 54”.
    mountainpete[QUOTED] likes this.
  12. Apr 15, 2025 at 7:59 PM
    SYNCRO
    SYNCRO New Member
    What model shell is that? I like the side window lower rear trim.
  13. Apr 16, 2025 at 5:37 AM
    It’s an ARE CX
