2024 TRDPro hybrid - Spun bearing
Discussion in '3rd Gen Tundras (2022+)' started by TundraP226, Apr 15, 2025.
  1. Apr 15, 2025 at 7:56 PM
    TundraP226
    TundraP226 [OP] New Member
    2023 Tundra TRD PRO
    I have a 2024 tundra trd pro hybrid with 109k kms
    spun a rod bearing last night on the way home. Toyota won’t do anything for me.
    Regular warranty is 36months or 100k
    they are telling me I have 3rd party warranty till 2030 or 175k Kms.
    Will only replace bottom short block won’t give new engine.
    Maintence record is immaculate as it’s had all Maintence always on time by my local Toyota dealer.
    any advice?
    Ty.
    Terndrerrr and sudobash like this.
  2. Apr 15, 2025 at 8:05 PM
    Timmy23
    Timmy23 New Member
    OR
    25 1794 MGM Tundra
    None
    Be happy you have the 3rd party warranty and have them do the work. Long blocks are only going in the recalled vehicles.
    sudobash likes this.
  3. Apr 15, 2025 at 8:11 PM
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    Rod bearings are different from the main bearing failure recalls that get new engines. And your truck isn't covered under that recall.
    Sorry, but you're at the mercy of whatever Toyota decides.
  4. Apr 15, 2025 at 8:25 PM
    TundraP226
    2023 Tundra TRD PRO
    Such a shame… sold my Cummins to try Japanese gas. Looks like I’m headed back.
    vtl and Black@Blue19 like this.
  5. Apr 15, 2025 at 9:36 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Out of curiosity what was your use case for the tundra?
    Rodtheviking and sudobash like this.
  6. Apr 16, 2025 at 1:34 AM
    troutback
    troutback New Member
    2023 Blueprint SR5 CC
    Have you called Toyota Corporate to get them involved? After that I am sure the press would be interested in the story.
  7. Apr 16, 2025 at 2:39 AM
    GREENPUS
    GREENPUS New Member
    Scott
    2024 Black Tundra Limited TRD Off-Road
    Isn’t that the reason you bought the extended warranty?
    DIYReid, oddhours, caboj and 2 others like this.
  8. Apr 16, 2025 at 4:38 AM
    SR5BART
    SR5BART New Member
    Bart
    Chicago
    21 SR5 TRDOR
    If you have an extended warranty that will get you back together and on the road what more do you need? You're not getting a long block as only the recalled VINs are
    ScottieBones, DIYReid and Raven67 like this.
  9. Apr 16, 2025 at 6:39 AM
    Alex261
    Alex261 New Member
    Alex
    Boston, Ma
    2024 Tundra Platinum LR
    What is your build date on your door sticker out of curiosity? I know you said it’s a 24 but your profile says 23
  10. Apr 16, 2025 at 6:45 AM
    DIYReid
    DIYReid New Member
    KC
    2024 Ice Cap Tundra Limited
    You realize Ram would do the same on your Cummins, right?
    raylo, sudobash and Tundra family like this.
  11. Apr 16, 2025 at 7:43 AM
    sudobash
    sudobash New Member
    Who said that it was only main bearings in the recalled vehicles?
    Terndrerrr likes this.
  12. Apr 16, 2025 at 7:53 AM
    sudobash
    sudobash New Member
    This isn't always 100% the case.
    There are plenty that have gotten a partial engine assembly instead of a short block. A partial engine assembly is different from the engine assembly being used in the recall.
    Kap1 and cartage1 like this.
  13. Apr 16, 2025 at 7:54 AM
    sudobash
    sudobash New Member
    Toyota Corporate isn't going to do anything if the customer has an extended warranty.
    The press isn't going to care either. It is a known issue and while this failure is outside of the recall dates, it isn't anything new.
    cartage1 likes this.
  14. Apr 16, 2025 at 7:59 AM
    I will be interested in the long term of the new 2025 Cummins HO engine. Heard a lot of changes (not a bad thing considering all the HO engine failures).
    Terndrerrr and Black Wolf like this.
  15. Apr 16, 2025 at 8:33 AM
    Gonefishingdave
    Gonefishingdave New Member
    Dave
    Central New York
    2024 MGM Tundra TRD OR Limited
    Bakflip cover, AVS vent visors
    Yes, please tell us your build date. It’s on the sticker on driver door jam.
    Raven67 and sudobash like this.
  16. Apr 16, 2025 at 4:12 PM
    TundraP226
    2023 Tundra TRD PRO
    11/23 door jam
    Toyota officially declined the warranty.
    Service manager at Toyota says if 3rd party declines they will try a “good faith” purchase of a new engine I pay only 35% of total cost and labour. Yay!
    I wasn’t aware that I paid for extended warranty until now. but they are also on the line of declining warranty because I don’t have 1 oil change receipt from when I first got the truck. when I first got the truck I had an oil change done at 7000 kms which is the one I’m missing because they are telling me that I haven’t had an oil change from 0-20k kms and that’s why it spun a rod NOW. When I heard that I was blown away at the stupidity I was dealing with.
    But if you see my Toyota history from the dealer after that it was consistent oil changes at every 7k and all fluids done as per Maintence manual.
    RIP help me.
  17. Apr 16, 2025 at 4:57 PM
    sudobash
    sudobash New Member
    35% is still probably going to be in 5 figures.
    Where were your oil changes done?
  18. Apr 16, 2025 at 4:59 PM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
  19. Apr 16, 2025 at 6:17 PM
    nastycucumber
    nastycucumber New Member
    Ontario
    '25 Tundra
    nah, how much do you think 100% is if 35% is 5 figures.
    ctrl+D on that
    Tundrum74 likes this.
  20. Apr 16, 2025 at 6:23 PM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    what are you even talking about?!?! 5 figures?????……your math and my math don’t compute.
    troutback likes this.
  21. Apr 16, 2025 at 6:36 PM
    nastycucumber
    Ontario
    '25 Tundra
    @TundraP226
    So, like a previous post, what did do with your truck ? A 2024 truck with 109.000km is quite a lot of driving, definitely way above average.
    67k. miles
    Kap1 and ZappBrannigan like this.
  22. Apr 16, 2025 at 6:39 PM
    lapoolboy
    lapoolboy New Member
    Uh, aren't these engines north of $30k?
    35% of 30k is $10,500.
    Kap1, brhodea, sudobash and 2 others like this.
  23. Apr 16, 2025 at 6:44 PM
    shawn474
    MoCo, Maryland
    That’s inflated hyperbole…..a way for Toyota to make it seem like they are helping the consumer by going them a favor and still recouping their cost. I don’t believe that for one second those are real world numbers.
  24. Apr 16, 2025 at 6:45 PM
    lapoolboy
    Have you tried to buy one? How do you know what they cost?
    woods likes this.
  25. Apr 16, 2025 at 6:45 PM
    shawn474
    MoCo, Maryland
    Because my best friend is the gsm at one of the highest volume Toyota dealerships in the country.
  26. Apr 16, 2025 at 6:46 PM
    lapoolboy
    Has your best friend validated your hypothesis? If so, please enlighten us and help OP out. What do they REALLY cost?
    AZBoatHauler likes this.
  27. Apr 16, 2025 at 6:54 PM
    shawn474
    MoCo, Maryland
    I can only go by his dealership and what his is charging…..no it doesn’t cost that much. The price they charge the consumer for the repair and the price they charge Toyota for the warranty repair is very different…..
  28. Apr 16, 2025 at 6:57 PM
    lapoolboy
    Well no shit Sherlock....this is true of EVERY manufacturer. This isn't what we are discussing here. OP said Toyota officially denied warranty and 3rd party "may" deny, so warranty pricing would be irrelevant here. If that happens, he has been offered the goodwill gesture of 35% of RETAIL and like #NotRyan said, it will be in the 5 figures.
    Hank Hill and sudobash like this.
  29. Apr 16, 2025 at 7:13 PM
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
  30. Apr 16, 2025 at 7:26 PM
    shawn474
    MoCo, Maryland
    Let me ask where you heard a replacement engine cost $30+k???? On this forum? Or another? Have you confirmed that to be true? Or just regurgitating someone else’s hyperbole?
    I can only tell you what my buddy has told me - and there is a ton of misinformation out there regarding warranty, non-warranty, etc.
    Regardless, if this was me, I would drop the hammer on Toyota corporate, the dealership and the third party warranty company. I wouldn’t accept a simple no for an answer……it would be interesting to know more about the usage of the truck and how so many miles were put on it. Work truck? Towing? If the only issue is missed documentation of one oil change 100,000km ago, I don’t believe that is the only issue here…..There is likely something more to this particular story.
    in regards to engine replacement cost out of warranty, a $32k repair would likely total that truck if insurance were to get involved. Absent of the “good faith” I don’t see how anyone would absorb that kind of cost. His guess is whatever shop quoted the price of $32k to replace an engine and offering a 35% “good faith” cost, was trying to recoup their costs by making it seem like they were helping out the owner. His cost isn’t that much. However I didn’t initially notice that this was a hybrid so that may increase cost…..
