2016 brake conversion?
Discussion in '2.5 Gen Tundras (2014-2021)' started by RangerDan, Apr 15, 2025.
  1. Apr 15, 2025 at 3:49 PM
    RangerDan
    RangerDan [OP] New Member
    2016 tundra TRD
    Has anyone done a front brake conversion on second gen tundra like on first gen? I've read posts about swapping lexus rotors and calibers on first gens, is it possible to do that on a second gen? My truck has 60000 miles and I'm on my third set of rotors. Two sets of OEM and have napa premium grooved rotors now. All have " wraped" within 5000 miles of install. I have Wagner oex pads. No towing and I have taken the truck to local toyota dealer. They had the truck for about 3 hours and did not find any reason for.the issue. They waved the 200 diagnosis fee. Any help would be great.
  2. Apr 15, 2025 at 4:10 PM
    APalmTree
    APalmTree Sometimes helpful
    Brandon
    SW Washington
    A few... Definitely more than 2
    HulkSmurf14 likes this.
  3. Apr 15, 2025 at 4:12 PM
    RangerDan
    2016 tundra TRD
    Thank you sir.
  4. Apr 15, 2025 at 5:14 PM
    Dave8699
    Dave8699 Trackrat
    NJ
    04 Tundra AC, 2014 Tundra 1794 Crew Max
    Whole truck Raptor liner in olive green, leer camper cap, 5100 with OME, Wheelers AAL and Firestone Air bags.
    I wished they had an upgrade like the 1st gen. I did the upgrade on my 1st gen and it was a huge difference.
    RangerDan[QUOTED][OP] likes this.
  5. Apr 15, 2025 at 6:22 PM
    It’s not normal for the rotors to warp that fast. You’re either really hard on brakes, or you’re driving with your foot resting on the brake pedal, or you have stuck calipers or something. General consensus is factory rotors are better than most aftermarket. Alcon makes a killer upgrade kit, but it’s $$$.
    caboj and HulkSmurf14 like this.
  6. Apr 15, 2025 at 6:48 PM
    RangerDan
    2016 tundra TRD
    Thanks for the info. I know this is not normal. I drive a ford f150 for work. 82000 miles same rotors and brake pads. I can buy a lot of $100 rotors for a $3200 big brake upgrade. Very frustrating.
  7. Apr 15, 2025 at 7:10 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    The rotors and calipers on the tundras are the same components used on the equivalent Lexus suvs. The reason 1st gen’s gained from a larger rotor is because the brakes were small to begin with. These trucks come with a 14” rotor. The oem rotors kinda suck. I’m going on 60k miles on my Stoptech High Carbon slotted rotors. Still smooth as can be when braking. But I am using oem pads which does make a difference.
    RangerDan[OP] likes this.
  8. Apr 15, 2025 at 7:12 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    I have 106k on my oem brakes...sounds like your calipers are needing rebuilt or the slide pins lubed up...
  9. Apr 15, 2025 at 7:14 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    You must live in a lot of hills my oem brakes lasted 65k
  10. Apr 15, 2025 at 7:19 PM
    Yota303
    Yota303 -Running on hope and gasoline-
    Washington
    2016 MGM Crewmax 4x4 Limited
