2005 4x4 regear questions
Discussion in '1st Gen Tundras (2000-2006)' started by Bed Tundy, Sep 1, 2024.
  1. Dec 4, 2024 at 7:19 AM
    Dustbox
    Dustbox New Member
    Southern Utah
    2000 Black AC 4.7l V8 4x4 SR5
    285/75/r16 tires on stock suspension Tubed Bumpers
    There is a dude who put a 2nd gen bigger front diff into his 1st gen sequoia. treehouse off-road I think it was, he has a long video on YouTube about it. It was very very extensive work like doing a cab lift so he could get his engine and trans up higher just so he had the space for it and then still had to modify the diff itself a lot. So it is possible
    junkyard GM 14 bolt axles can come stock with 4.56s and are pretty much the cheapest beefy axle there is…………….
    455h0le_dachshund likes this.
  2. Dec 4, 2024 at 7:32 AM
    Just ran through the assembled third member diff builder on ECGS website. Looks like for $2300 you can regear front and back with open front and locked rear in 4.30. Not bad......
  3. Dec 4, 2024 at 11:33 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    What he said. 100% a typo on that website.
  4. Dec 4, 2024 at 2:14 PM
    Elevatorguy
    Elevatorguy Yotas and JD Green!
    James
    05 DC, 4.7, 4wd, LSD.
    I did too but with True tracs f&r. 4k minus the 1K in cores.
  5. Dec 4, 2024 at 5:08 PM
    Bed Tundy
    Bed Tundy [OP] Like changing a tire, the 1st time you're careful
    Neature Gary
    Moscow, ID
    (W) 2005 AC 4.7 4x4 with VSC, (G)2005 AC 4.7 TRD Sport RWD
    See Signature or my Photo Album
    I swear about 20% of the Internet is now AI generated nonsense. It wasn’t just that website I read it on.
    ECGS seems like the way to go, I was hopeful I could find a 04 white 4.30 parts truck to use for around $1000 and save myself some money while also getting color matched spare body panels.
    shifty` and 455h0le_dachshund like this.
  6. Dec 5, 2024 at 8:52 AM
    BluegrapeVr6
    BluegrapeVr6 New Member
    J
    Only second hand info* but i know two people that dont like true-tracks in front. They both said it was harsh transition and was like a poor version of KDSS or whatever yota calls it. Active brake diff is how I think of it. Anyone with 1st hand experience id like to hear it.
    Truetracks seem to be loved or mixed feelings. I wouls spend another couple hundo snd go e- locker. If you go for it please let us know your thoughts.
    Bed Tundy[OP] and PNW15 like this.
  7. Dec 5, 2024 at 8:56 AM
    BluegrapeVr6
    J
    And fyi I used SEQIOUA RING gear front. But also had 02 4-runner 3rd member front pull it yard ( code read 4.30) and they * both looked the same when I regeared my truck.
    Everything else I sourced from totaled donor tundra that had gears already installed.
    Bed Tundy[OP] and shifty` like this.
  8. Apr 3, 2025 at 9:17 AM
    PNW15
    PNW15 New Member
    WA
    2006 DC V8 4WD
    @Bed Tundy did you follow through on the re-gear? If so, what did you choose and how do you like the results?
  9. Apr 14, 2025 at 11:25 PM
    Bed Tundy
    Neature Gary
    Moscow, ID
    Sorry I’ve been busy at work and MIA on the forum for a bit. Winter was my down time and I had lots of Energy to think about the truck. This re-gear has been revitalized and brought to the top of my to do list because I just snapped something in my front diff playing in the snow last weekend. Rwd works fine and it grinds and slips in 4x4. Sooooooo, I don’t have the money for the full re-gear yet, I will have to try and source 4.30 geared parts from wrecking yards and this might give me a chance to use my broken parts to build what I really want down the line. Is there anyone with direct knowledge about the compatibility of just swapping the whole front and rear differentials/axles from an 04 v6 4x4 auto to an 05 v8 4x4? If you find my parts and buy them before me I will find you! Haha. I need my 4x4 back!
  10. Apr 14, 2025 at 11:46 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Totally swappable, as long as the gearing matches front to rear. Bonus if you find a limited slip.
    PNW15 likes this.
