Need advice on g43 holster
Discussion in 'Guns & Hunting' started by 455h0le_dachshund, Mar 2, 2025.
  1. Mar 5, 2025 at 4:03 AM
    Bought2Pull
    Bought2Pull New Member
    Greg
    WV
    2006 Tundra 4 door
    I don't trust Google.
    Seriously I can't stand them and I've literally read two opposing internet results in two searches done 10 seconds apart.
    455h0le_dachshund[OP] likes this.
  2. Mar 5, 2025 at 4:25 AM
    Bergy24
    Bergy24 New Member
    I would highly recommend Crossbreed for any Holster or Belt.
    The SuperTuck and MiniTuck are great options for IWB if you comfort and concealability. I would suggest the Mini for the G43.
    If you need a belt, sizing can vary depending on the specific belt and buckle you want. I have 4 of them (Both 1.25" and 1.5") and can help you out with sizing if need be.
    Between my son and I, we have numerous Mini and Super Tucks and as well as other brands and we both agree that Crossbreed is out favorite. It basically disappears and you forget you are even wearing it, its that comfortable.
    If you want a OWB holster, look at the Snap Slide.
    Horse Hide will be the most durable for the holsters but there are other options too, such as there Founder Series Leather which is very nice.
    I recommend the Founders Series leather in the belts.
    Customer service is also second to none.
    There is a Crossbreed Seconds website which is not affiliated with Crossbreed but is legit from what I have read.
    You can save a lot of money by going with a second but I think you will lose the warranty if you go this route.
  3. Mar 18, 2025 at 6:00 PM
    455h0le_dachshund
    455h0le_dachshund [OP] Tesler Thought Experiment
    Reverend Hotdog
    TX...big surprise
    I might buy these later. Still debating, because I read the description and apparently they only work with a certain type of Glock mag and I don't know which one I have.
    Ordered. Thanks for the recommendation. I know you know your stuff. Hopefully it comes in before I leave to T2S
  4. Mar 18, 2025 at 6:42 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    :fingerscrossed:
    Shipping times are a bit all over the place from them... If it's 'in-stock', it'll probably arrive before you leave. However, if they are building it for you, probably not...
    Either way, I'm sure you'll like it once you have it :hattip:
  5. Mar 18, 2025 at 6:43 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Worse case scenario, I'll do as I did in 2023, and take my 1911 in it's soft case. Just won't be able to have it on my person at all times.
    I'm just not willing to drive across the desert (likely alone omw home, again) without being strapped haha
  6. Apr 2, 2025 at 5:09 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Should arrive this Friday. :quickdraw:
  7. Apr 2, 2025 at 5:48 PM
    Vizsla
    Vizsla 2 = 2.5
    Excellent advice and great choice! My G43 and really old G-CODE Eclipse with Mojo Riser, absolutely love it. It’s difficult for me to conceal carry, not a big guy and stay in really good shape. Don’t hate on the pocket clip.
  8. Apr 2, 2025 at 7:56 PM
    Tripleconpanna
    :yes:
  9. Apr 14, 2025 at 8:14 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
  10. Apr 15, 2025 at 12:49 PM
    Tripleconpanna
    Well??
    How do you like it so far???
  11. Apr 15, 2025 at 1:21 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    I like it. It almost matches my Glock.
    But I haven't actually worn it out of the house yet :anonymous:
    I can't wear it on duty because I'm "unarmed" (with an Axon X2).
    I tested it with my gym shorts, but because I've lost ~150lbs in the last 20 months, my gym shorts are all way big on me. Even with the drawstring as tight as I can get it, the holster really weighed em down. So I went shopping in my closest and found some pants that fit (probably from a decade ago, with the tags still on em), that I'll be wearing the holster with.
