Coolant replacement the easy way
Discussion in '2.5 Gen Tundras (2014-2021)' started by vtl, May 10, 2024.
  1. Feb 7, 2025 at 11:13 AM
    #61
    therealjonwick
    therealjonwick New Member
    JR
    2019 OR
    Just noticed my coolant a little low. Am I OK to just top it off until I get around to changing the coolant next week?
  2. Feb 7, 2025 at 11:15 AM
    #62
    vtl
    vtl [OP] New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Of course.
  3. Feb 7, 2025 at 12:08 PM
    #63
    WAtundra4x4
    WAtundra4x4 Retired from active retirement.
    Den
    Wet side WA
    2018 Cement Tundra TRD crewmax limited
    Forward looking camera, Stub Antenna, 3M clearshield. A few other non lifted items.
    I’d be doing a Quick Look around for a leak…..
  4. Feb 7, 2025 at 12:41 PM
    #64
    therealjonwick
    JR
    2019 OR
    Yeah, I keep checking in my driveway and at work every day and never find anything.
    WAtundra4x4[QUOTED] likes this.
  5. Feb 7, 2025 at 1:19 PM
    #65
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Look underneath your front end.
  6. Apr 14, 2025 at 1:13 PM
    #66
    d33pt
    d33pt New Member
    i just did this. Super easy. I only did the radiator and passenger side. I had the truck parked on an incline, nose up. Approximately 2.7G came out and that much also went right back in. I didn't even have the start the engine to burp it. I'll drive it around for a bit and check it again in the next couple of days.
    Thanks OP for the pics and guidance.
    ATV25 and JMGmanAZ like this.
  7. Apr 14, 2025 at 1:33 PM
    #67
    Mr Badwrench
    Mr Badwrench New Member
    I have to get my fat lazy ass in gear to do this at some point soon. Glad you guys make the write-ups on these.
    JMGmanAZ likes this.
  8. Apr 14, 2025 at 1:35 PM
    #68
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    Same...
  9. Apr 14, 2025 at 1:36 PM
    #69
    d33pt
    d33pt New Member
    My truck has 125k, and I don't know if it was ever done since I just got it, so I figure I'll do it and feel better. The old coolant was still very pink and clean though, so I think they must have done it at some point.
  10. Apr 14, 2025 at 2:04 PM
    #70
    NWPirate
    Zach
    WA
    Same..:anonymous:
    I'm almost at 80k miles so not terrible.
    Would ramps on both driver side tires be beneficial at draining the passenger side block?
  11. Apr 14, 2025 at 3:08 PM
    #71
    d33pt
    d33pt New Member
    No ramps needed. Just turn the wheel all the way to the right and there's plenty of room.
  12. Apr 14, 2025 at 4:24 PM
    #72
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    I took the wheels off just too make it easier, ramps definitely wouldn't help at all.
  13. Apr 14, 2025 at 5:13 PM
    #73
    NWPirate
    Zach
    WA
    I was more thinking to drain the block completely, probably not necessary though
  14. Apr 14, 2025 at 5:24 PM
    #74
    therealjonwick
    JR
    2019 OR
    How do I know when the radiator is full? Maybe a dumb question. Never done this before. Thanks all.
  15. Apr 14, 2025 at 5:29 PM
    #75
    Joe333x
    Joe333x Member
    Boston
    Use something like this. https://a.co/d/7V7wvuU
    The Dude, Lucid Tundra and texasrho83 like this.
  16. Apr 14, 2025 at 5:40 PM
    #76
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
  17. Apr 14, 2025 at 5:45 PM
    #77
    therealjonwick
    JR
    2019 OR
    Ordered. Thanks! So basically when it gets to the top you plug the bottom and remove?
  18. Apr 14, 2025 at 6:07 PM
    #78
    TundraBrew
    TundraBrew New Member
    Good thread. I'm just over 40k on my 2019. Plan to drain/fill around 50-60k.
  19. Apr 14, 2025 at 6:33 PM
    #79
    Joe333x
    Joe333x Member
    Boston
    You fill it up locked into the radiator until there's maybe 1/4 of the funnel filled, start the truck up and let it run until the thermostat opens, bubbles will come up the funnel, keep the lid on a little, obviously not snap on but enough so that coolant doesn't spray you when it bubbles. Give the engine some revs and squeeze the rubber hoses going to the radiator. That will make sure you don't have any air in the system. Also make sure you overflow take is filled half way. Once done shut the truck off, plug the funnel, replace the radiator cap and drain the extra coolant back into the bottle.
  20. Apr 14, 2025 at 6:36 PM
    #80
    d33pt
    d33pt New Member
    Hah, i was too cheap to buy the fancy funnel. I just did it the old fashioned way. Just filled it up slowly until it overflowed.
    Mr Badwrench likes this.
  21. Apr 14, 2025 at 6:41 PM
    #81
    Joe333x
    Joe333x Member
    Boston
    I've done something similar with my motorcycles since they don't make those snap funnels that fit them I just stick a funnel that fits in, fill it and start the bike up til the thermostat opens, gotta watch it though or is easy to get the funnel to overflow.
