  1. Apr 14, 2025 at 12:54 PM
    Shifty might recall better, but I thought it was mainly the bearing on the bracket that was going bad on people with issues, I assume the fan can still be on, just check for play where the clutch mates to the bracket
    shifty`, CodyP[QUOTED] and BroHon like this.
  2. Apr 14, 2025 at 2:25 PM
    CC80guy
    CC80guy New Member
    Larry
    Lehighton, PA
    Took advantage of a non-rainy day and replaced the map, dome, door, and kick panel bulbs with LED's. It's a bright day!
  3. Apr 14, 2025 at 3:26 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    I can take a look tomorrow and if they’re in good shape I’ll grab them.
    Mustanley[QUOTED] likes this.
  4. Apr 14, 2025 at 5:34 PM
    Dblock500
    Dblock500 New Member
    DMV
    2002 SR5 AC 4.7 V8 4WD
    Put on new headlight assemblies with led projectors, however all 3 10mm nuts were rusted and broke completely off on the passenger side along with the bolts. The bolts are attached to the frame and the nut is supposed to thread onto it. Only the philips head screw on the top is holding the headlight in place. WTH can I do to fix this? I'm guessing welding is the only way?
  5. Apr 14, 2025 at 5:50 PM
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    Looks like you could grab some of them real tight with vise grips and turn them out. Even easier if you file two flat edges to grab onto.
    The others you might be drilling out.
  6. Apr 14, 2025 at 6:05 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    You should make a thread on how to do it with pics. I'd love to do this some day.
    oscardog86 and Nicklovin like this.
  7. Apr 14, 2025 at 6:21 PM
    Dblock500
    DMV
    The only problem is they aren't supposed to come out, they are apart of/attached to that larger metal piece that is attached to the body. That said, maybe you're right about drilling them out--could work and would allow a hole to be used to insert a new bolt piece. Thank you
    Tundra2 likes this.
  8. Apr 14, 2025 at 6:24 PM
    Got a few of these to try out tomorrow and see how well they strip surface rust.
  9. Apr 14, 2025 at 6:34 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    By some miracle I didn’t cut out anything that holds the factory fog housing in place LOL
    I do like the all clear turn signal and housing better than the black.
  10. Apr 14, 2025 at 6:36 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    So you decided to ditch the LED pods you had in the fogs?
  11. Apr 14, 2025 at 6:38 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Moved them up to the grille. I had 3 XL’s and 2 squadrons. Now all 5 are XL’s. They look perfect there, but I can’t use them on the street at all cause they’re too bright and the beam is too tall.
    G_unit3000 likes this.
  12. Apr 14, 2025 at 7:22 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    I got some of these after watching a buddy effortlessly strip my spindles to bare metal with them. I've used them a couple times for surface rust since and they weren't half bad.
  13. Apr 14, 2025 at 7:24 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    So what you gonna do with the squadrons? Ditch lights? Auxiliary reverse lights?
    khooiii[QUOTED] and FrenchToasty like this.
  14. Apr 14, 2025 at 7:52 PM
    Sirfive
    Sirfive Master Procrastinator
    ‘02 Limited AC TRD
    Bassani cat-back
    Some folks deserve it.
    https://youtu.be/Rzk3x3HZbJI?si=_Eyn_8z690vDu4Lx
  15. Apr 14, 2025 at 8:17 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Going on the wife’s gx haha.
  16. Apr 14, 2025 at 8:26 PM
    MT-Tundra
    Montana
    Ah shoot. Been a little while since I've been in there. I thought it was just welded nuts with bolts threaded in. But yeah, drilling out and putting a bolt and nut through would work. I hate drilling out broken bolts...
  17. Apr 14, 2025 at 8:29 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Good choice. But have you picked where?
  18. Apr 14, 2025 at 8:37 PM
    How does it drive with the front locker? Locked and unlocked.
    G_unit3000 and 455h0le_dachshund like this.
  19. Apr 15, 2025 at 4:24 AM
    kieljon
    kieljon New Member
    Southeast US
    2005 Double cab 4x4 TRD
    What brand of LED did you use (or where did you get them)? I replaced all my internal lights with LEDs about 2 years ago and now 1/4 of them are out.
  20. Apr 15, 2025 at 4:31 AM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    A buddy gave me some ditch light brackets a few months ago so they're going on the A pillars. I was going to wait until we lifted it or made it look less stock, but oh well lol.
  21. Apr 15, 2025 at 4:52 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    www.superbrightleds.com
    Is where I buy all my interior LEDs. I've only ever had one go bad in about 5+ years
    G_unit3000 and Dakillacore like this.
  22. Apr 15, 2025 at 6:44 AM
    CC80guy
    CC80guy New Member
    Larry
    Lehighton, PA
  23. Apr 15, 2025 at 7:19 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Send some self tappers in and forget about it until the next time
  24. Apr 15, 2025 at 11:04 AM
    TundraFirstGenGuy
    TundraFirstGenGuy New Member
    Aaron
    Washington state
    05 Tundra DC 4x4
    OME 2.5” leveling kit. 285/70R17 Toyo RT, 17x9” -12 offset wheels. Arb air lockers front and rear. 12,000 hidden badlands winch.
    It drives like normal unlocked. Surprisingly it doesn’t drive as bad as I thought it would locked, but I’ve only had to use the lockers in the snow and mud and not very often. If I air the tires down and engage the lockers though, this thing will go almost anywhere. Long wheel base sucks for big rocks, humps, etc obviously (not a Jeep) but it crushes it in mud and snow.
  25. Apr 15, 2025 at 11:38 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Unlocked rear vs lsd rear? Ever get stuck spinning at an uphill intersection? Will it lock in on the fly?
  26. Apr 15, 2025 at 11:52 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    I know my Eaton can lock and unlock stationary or up to 3mph.
    Iirc the TRD e-locker can unlock or lock up to 10mph
    oscardog86 and TundraFirstGenGuy like this.
  27. Apr 15, 2025 at 11:53 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Air stuff might load/unload different.
    TundraFirstGenGuy likes this.
  28. Apr 15, 2025 at 1:36 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    Sorry @Mustanley but the bumper covers were gone along with the bumper.
    Mustanley likes this.
  29. Apr 15, 2025 at 2:46 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Maybe. But I found the TRD e-locker sticker, for posterity .
    oscardog86 likes this.
  30. Apr 15, 2025 at 2:58 PM
    BroHon likes this.
