BUMP STOP IGNORANCE
Discussion in 'Suspension' started by smokint, Apr 13, 2025.
  1. Apr 13, 2025 at 5:07 PM
    smokint
    smokint [OP] New Member
    2017 1794 2002 Tacoma
    OK, so I thought I’d finish my bump stop project today
    equin likes this.
  2. Apr 13, 2025 at 5:09 PM
    smokint
    But I didn’t realize there’s TWO bump stops up front !
  3. Apr 13, 2025 at 7:32 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Bump. Stop Ignorance.
  4. Apr 13, 2025 at 8:47 PM
    smokint
    Stop my ignorance, please.
    Don’t want to have to take these wheels off again, I’m out of shape!
    Saltyhero13[QUOTED] likes this.
  5. Apr 14, 2025 at 12:34 AM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    You can leave the one oem bump stop, the longer one will stop the LCA’s; you don’t technically have to change both. If you really wanted to, you could space the shorter oem one with a washer (my 6112’s came with washers to space them down 1/8” or so)
    equin likes this.
  6. Apr 14, 2025 at 1:33 AM
    smokint
    Thanks, I didn’t know that. I was suprised that there was another one!
  7. Apr 14, 2025 at 6:24 AM
    RobertD
    Robert
    DFW, Texas
    Most off road companies tell you to replace the rear most front bumper stop but to leave the forward most as the stock. Since they are drastically different materials and function differently, leaving the front one as stock is a safety net if shit goes wrong either the aftermarket one.
    joseph_womack and smokint[OP] like this.
  8. Apr 14, 2025 at 6:27 AM
    n0rth
    n0rth New Member
    J.W.
    2019 Tundra Crewmax
    Step 5: Install the DuroBumps at the rear of the lower control arm, using a 14mm deep socket. Tighten the bolt until snug. Do not over tighten. The OEM bump stop that is located at the front of the lower control arm will remain in place.
    From the Durobump installation instructions.
    equin and smokint[OP] like this.
  9. Apr 14, 2025 at 7:47 AM
    smokint
    Great info, thanks so much
    I’ve learned a lot from this forum, really appreciate it
    n0rth[QUOTED] likes this.
  10. Apr 14, 2025 at 7:47 AM
    smokint
    Makes sense, I am learning something new every day, thank you
    RobertD[QUOTED] likes this.
  11. Apr 14, 2025 at 7:56 AM
    RobertD
    Robert
    DFW, Texas
    Its all good, I asked the same when I replaced mine.
  12. Apr 14, 2025 at 8:05 AM
    n0rth
    n0rth New Member
    J.W.
    2019 Tundra Crewmax
    No problem, I had just downloaded the instructions as my Durobumps are showing up Tuesday and I had the same question when I realized there are 2 bumps on my Tundra.
    RobertD likes this.
