  1. Apr 13, 2025 at 6:48 PM
    kbahus
    kbahus New Member
    MI
    2015 MGM Tundra Limited Crewmax
    Is this the model you have? Seems like it would be sketchy lifting a Tundra.
    koditten[QUOTED] likes this.
  2. Apr 13, 2025 at 6:49 PM
    00h2itr
    00h2itr New Member
    Carolina's
    21 Limited CM TRD-OR
    What's the diagnosis?
  3. Apr 13, 2025 at 7:00 PM
    koditten
    Kirk
    Midland of the Mitten
    You do need to think ahead.
    Once you figure out the balance point, they are solid. The same goes for a 2 post lift.
    Don't remove both rear tires or both front tires thinking the balance has not changed.
    Same goes for removing A-arm bolts with a hand ratchet and a cheater bar. You can upset the balance. Just give it a bit of thinking.
    Another advantage is you can lift the truck from the side once you know the balance points.
    Obviously, if you are removing engine/ transmission assemblies, these lifts have a disadvantage.
    Regardless, you need to be aware of balancing issues.
    4 post units are not an issue.
    kbahus[QUOTED] likes this.
  4. Apr 13, 2025 at 8:03 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Most likely smoked a ring or hole in piston 7
    HulkSmurf14 likes this.
  5. Apr 13, 2025 at 8:32 PM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    The deadening project FINALLY came to an end, well the hard and laborious part that is. Pressure washed the carpet today after soaking and going through them will the drill and brush disc. Used Superior Products Does it All solution, purchased from O’Reily Auto parts.
    Put everything back that would be under the carpet. Hopefully the next week will have decent temp so it can dry good.
    Had some left over materials and decided to use for the hood. Once the insulation pad goes back on, you cant even tell. Not sure if it would do anything. But oh well. I’m sure it does “something”.
    DFEB6B82-DA7F-40B8-A199-C81A4E6DA742.jpg E3C07F38-3C95-4BC8-8C5E-4A65A3B71C27.jpg IMG_4253.jpg IMG_4255.jpg IMG_4256.jpg
  6. Apr 13, 2025 at 8:33 PM
    dave-o
    dave-o New Member
    2010 silver SC LB 4x4 5.7; 2020 white CM 1794 4x4 5.7
    lift, ARB, sliders; Slee sliders
    What is that roll bar in the background?
    Florida AF and Sleeper16plat like this.
  7. Apr 13, 2025 at 9:32 PM
    Sleeper16plat
    Sleeper16plat New Member
    Near Vancouver
    2016 Silver Platinum
    TRD Rear Sway Bar Bilstein 6112/5160 Pop Lock, Kenwood MX 1057 XR, Pioneer amp/speakers/subs, Tech12Volt dual sub box
    Installed front camera and decided to plasti-dip the chrome logo in the grill while I was at it! After black door handles and mirror caps I now need new headlights without the chrome!
    Also, finished the slider project. Couple more coats of bed armour and finally got them mounted.
    I like it!
    quick poll question:
    debadge or blackout the chrome badge on the door??
  8. Apr 14, 2025 at 5:02 AM
    Tundra family
    Tundra family New Member
    Get that off of there.
  9. Apr 14, 2025 at 5:37 AM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    2020 SR5 Barcelona Red Tundra
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 Coachbuilder Shackles 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI
    PXL_20241020_212921494.NIGHT.jpgDe-badge but that's just me
    Jego, Wallygator, OHwendTrd and 8 others like this.
  10. Apr 14, 2025 at 5:39 AM
    Tundra family
    yours looks great!! 1st full color matched barcelona red ive seen. when everyone was doing the dechrome i went the other way and swapped black for chrome, seeing this makes me wish i had gone the other route
    HulkSmurf14 and BR73[QUOTED] like this.
  11. Apr 14, 2025 at 6:23 AM
    pyrite12
    pyrite12 New Member
    NY state
    2021 Silver Sky TRD DC
    That's probably the best color match I've seen on any grille surround (any color)! Looks great...love the Barcelona...
  12. Apr 14, 2025 at 6:30 AM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    PXL_20250413_223020104.jpgPainted the fog light bezels and fixed the wobble that was driving me crazy.
  13. Apr 14, 2025 at 7:33 AM
    Gainer
    Gainer New Member
    Columbus, OH
    2018 SR w/8' Bed
    Leveling kit, TRD wheels, remote start, Hellwig helper springs, TRD Rear sway bar. TRD Rear shocks, Dirty Deed 10" exhaust, S&B Cold Air intake
    Went to Menards and bought over 2400 lbs of pavers, sand and such
    The Hellwig helper springs appear to have done their job. The truck didn't squat that much.
    But it was a slow, creaky ride home....
  14. Apr 14, 2025 at 7:42 AM
    Tundra family
    2400 is wild!! im impressed!!!!
    Florida AF, woods and HulkSmurf14 like this.
  15. Apr 14, 2025 at 8:09 AM
    Gainer
    Gainer New Member
    Columbus, OH
    2018 SR w/8' Bed
    I'm glad someone is... my wife was a nervous wreck on the ride home. The thought of "I should've made two trips" was defiantly on my mind.
    Wallygator, woods and BR73 like this.
  16. Apr 14, 2025 at 8:13 AM
    Tundra family
    Half a ton more than my slide in, and that gets pretty sketchy. Have your knuckles gotten any color back to em yet? LOL
    BR73 and Gainer[QUOTED] like this.
  17. Apr 14, 2025 at 8:24 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Well I found a deal on 2 complete 3urfe’s engines one has less than 1k miles with upgraded fuel rails that was going to go into a race truck but the race organizers wouldn’t tag it for the class and the other is from his built tundra that had a blower and hurt motor.
    So we’ll stab the running one in and take mine out and build the backup and I’m going to give @snivilous the other for R&D for the community. Let’s see what the mad scientist comes up with
  18. Apr 14, 2025 at 8:46 AM
    Uhhhh....
    Uhhhh.... New Member
    Dave
    Virginia
    2016 Silver Limited DC
    7” BDS, 37s
    Never priced them before but I always assumed they were much more expensive than this. Good to know.
    HulkSmurf14[QUOTED] likes this.
  19. Apr 14, 2025 at 12:25 PM
    Boneskull420
    Boneskull420 New Member
    Tn
    2018 tundra crewmax magnetic gray trd offroad
    Ironman 4x4 foamcell pro 3.5in lift Complete custom stereo with 2 12's under rear seat S&B/stillen Frankenstein cold air intake True dual exhaust with Carven Tr mufflers Rough country hood bulge led strip Running board led's
    Got the cerwin vega vmaxx 12's in today, now it's time to break them in and put them to the test! 20250414_121014.jpg 20250414_121004.jpg 20250411_113258.jpg
  20. Apr 14, 2025 at 2:33 PM
    SAGE63
    San Diego County
    Ok, almost all back together from January rearender. My new C4 rear bumper replacement bumper goes on at the repair shop and will be calibrated by Toyota Escondido on Thursday.
    additionally "The Truck Shop" in Miramar is r/r my Baja Designs 30" S8 in my Front C4 bumper tomorrow.
    Shout out to Baja Designs for allowing an advance warentee replacement which will save a lot in the labor cost and down time for R/R vs take apart remove light put back together send light back to BD for testing then get repaired or replacement light and then reinstall in the bumper.
    While I was at BD facility in San Marcos one of the guys suggested I warentee my ditch lights for the faded Powder coat. Anyway, Thank you to Baja Designs for the assist on this. I will be back lighting up Tundras 2 Sedona night runs.
    Note: I will be putting the replaced 8 month old C4 bumper up on the market place soon at half current C4 list price with the disclaimer that it was in an accident and may potentially suffer from metal fatigue.
  21. Apr 14, 2025 at 2:35 PM
    00h2itr
    00h2itr New Member
    Carolina's
    Safe to assume as a result of boost?
  22. Apr 14, 2025 at 2:44 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Not necessarily- I think this engine had a tick etc before boost. And I’m very hard on my truck along with pushing over 700hp I’d guess. Plenty of boosted tundras with over 200k miles . This is an extreme use case example.
    BlueRibbon4x4, bflooks, BR73 and 2 others like this.
  23. Apr 14, 2025 at 3:39 PM
    Apohl17
    Apohl17 New Member
    AJ
    New shoe day!
    35 Pizza cutters for the win.
    Perfect match for the rig, IMO.
  24. Apr 14, 2025 at 3:52 PM
    WinterWarlock21
    WinterWarlock21 New Member
    South Jersey
    2016 Quicksand TRD Pro CrewMax
    https://gearproject.co/profile/SandShark21
    Same Wheels as me! Love the Rapids. Such a great looking wheel. Definitely going back to the Baja Boss's after my Ridge Grapplers wear out. Wish they made a skinny 37 lol.
    JMGmanAZ, Apohl17[QUOTED] and BR73 like this.
  25. Apr 14, 2025 at 4:23 PM
    caboj
    caboj New Member
    CA
    2018 Tundra CM TRD OR
    Are you talking about the Tacoma? Or something you see in the AE86? I have service scheduled this week, I can take some more detailed pics if needed.
  26. Apr 14, 2025 at 4:31 PM
    Apohl17
    Apohl17 New Member
    AJ
    Rock on. The Baja are so quiet! And work great here with our Wisconsin weather
  27. Apr 14, 2025 at 4:45 PM
    Dr3wski
    Dr3wski New Member
    2018 SR5 4x4
    What kind of lift are you running to fit?
    BR73 and Apohl17[QUOTED] like this.
  28. Apr 14, 2025 at 4:53 PM
    Apohl17
    Apohl17 New Member
    AJ
    The Falcon 2.25" Sport Tow/Haul Leveling kit. Settled to about 2" lift in front with OEM coils. Coachbuilder +2s in the rear. Plenty of clearance without rubbing so far.
  29. Apr 14, 2025 at 4:55 PM
    Dr3wski
    Dr3wski New Member
    2018 SR5 4x4
    Nice! Coming from a Tacoma it still impresses me that you can fit a 35 with only a 2" lift
  30. Apr 14, 2025 at 5:11 PM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    You can fit 35s with no lift with the right offset and no mud flaps.
