Rear diff drain plug had something odd attached to it
Discussion in '1st Gen Tundras (2000-2006)' started by dm3021, Apr 13, 2025.
  1. Apr 13, 2025 at 8:55 PM
    dm3021
    dm3021 [OP] New Member
    2005 Tundra SR5
    Hello all,
    I recently purchased a 2005 Tundra (4.7L, 4x4). Today, I was draining the rear differential fluid and to my surprise, I saw a pretty large piece of metal attached to the magnet on the drain plug. This was not a metal fragment or shaving, it was a fully intact piece of metal that looks something like an allen key. I've attached pictures below. I should mention that the truck has the mechanical limited-slip differential. Also, the oil that drained out of it was pretty nasty but did not have a glittery look to it like it would if there were a bunch of metal shavings floating around in it, and the drain plug itself was pretty clean aside from the sizeable metal object attached to it. The object itself has very slight marring on one side. The truck drives fine. Any ideas what it could be?
  2. Apr 13, 2025 at 9:03 PM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Looks like a tip for a snap ring plier
    hagrid, Ericsopa, tvpierce and 5 others like this.
  3. Apr 14, 2025 at 5:14 AM
    Mr Badwrench
    Mr Badwrench New Member
    It looks like the magnet saved the gears and internals. The piece doesn't look chewed up at all. So that's good.
    G_unit3000 and dt325ic like this.
  4. Apr 14, 2025 at 5:54 AM
    dm3021
    2005 Tundra SR5
    Thanks guys! Just wanted to make sure it wasn't a retaining clip or some part of the diff
    G_unit3000 likes this.
  5. Apr 14, 2025 at 5:58 AM
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    Like a Dr. performing surgery and leaving instruments inside the patient!
    Glad the magnet did it's job and kept your diff intact.
  6. Apr 14, 2025 at 7:20 AM
    Meanwhile, somewhere a mechanic is cussing about “where the hell did it go …?!”
    dm3021[OP] likes this.
  7. Apr 14, 2025 at 8:10 AM
    dm3021
    2005 Tundra SR5
    Ah, Shifty, a legend in the tundra forum - thanks to you I have ordered a set of OEM lower ball joints + bolts and a timing belt kit!
    Bought2Pull likes this.
