TPMS light stays on
Discussion in 'Wheels & Tires' started by single10, Oct 21, 2020.
  1. Oct 21, 2020 at 10:48 AM
    single10
    single10 [OP] New Member
    Atlanta GA
    2007 Tundra XSP Extended Cab 5.7L
    Toyota/ BBS Texas Port mods before delivery. BBS 305/50R20 wheels
    2007 Toyota Tundra. Purchased used 8 years ago with BBS wheels and 305/50/R20 tires on it. No problems. TPMS light came on this year. Owner's Manual instructions do not work. Replaced bad TPMS sensor in driver front wheel with aftermarket. No joy. Replaced all 4 TPMS sensors with Toyota OEM # 42607-0C070. Discount Tire said all 4 new sensors work but the sensor light still stays on. I've tried resetting the system using the instructions in the owner's manual and the button under the dash. The instructions state turn it from Off or ACC to On, and then hold the button until the TPMS light blinks slowly 3 times, and then wait 7 minutes before turning it to the Off position. As soon as I turn the ignition On the TPMS light starts blinking and then turns solid after 1 minute. It does not blink slowly 3 times so it never goes into the calibrate mode for 7 minutes. Any insight?
    Update: Since posting this I did more research and found there is a TPMS Monitor 89769-0C022 located in the passenger side kick panel by the glove box, and a TPMS Receiver [antenna] 89760-0C010 located in the overhead liner by the center back window. I replaced the TPMS Receiver antenna 89760-0C010 and the TPMS system works now. I followed the owner's manual instructions and it worked. The TPMS light is out. Finally!
    This video helped me alot:
    https://youtu.be/AOdRYofJMIE
    Thumper_6119 likes this.
  2. Oct 24, 2020 at 8:47 AM
    rar49
    rar49 New Member
    Bob
    2021 tundra sr5
    Had the same problem on a Tacoma that I owned. I took it to tire shop with computer to train the new sensors to the trucks computer. Tire shop charged me $40 to do it and Toyota wanted over $100.
  3. Mar 1, 2025 at 6:02 PM
    Toy4X4slate
    Toy4X4slate New Member
    Hector
    2008 Toyota Tundra 4x4
  4. Mar 1, 2025 at 6:04 PM
    Toy4X4slate
    Hector
    Hello I have the same problem where did you get the TPMS receiver antenna please let me know thanks
  5. Mar 28, 2025 at 12:04 PM
    single10
    Atlanta GA
    Hey I purchased the TPMS receiver off eBay. $65 I think. I forgot about this thread. All 4 of my Toyota BBS TPMS senser batteries are dead. I've been looking for the correct Toyota BBS TPMS sensors for a while now. Toyota parts doesn't know and BBS is non-responsive. And here they are in a topic I created 5 years ago. Thanks Dude for helping me find the correct part number! Now I gotta find aftermarket because $300 is ducking crazy!
  6. Apr 13, 2025 at 5:33 PM
    Scottyfoz
    Scottyfoz New Member
    Scott
    2019 TRD Tundra
  7. Apr 13, 2025 at 5:35 PM
    Scottyfoz
    Scott
    2019 TRD Tundra
    If this thread is still relevant I have a 2019 Tundra that after changing from winter tires and rims to the summer ones the TPMS light wont go out. Discount Tire has tried twice to reset it and I have tried the reset button near the bottom of the dash. I would like to hear if this is still an issue. TIA
  8. Apr 19, 2025 at 1:58 PM
    bradleydavidgood
    bradleydavidgood New Member
    Hey,
    Has anyone else replaced this antenna and had success?
    Thanks!
  9. Apr 21, 2025 at 3:47 PM
    single10
    Atlanta GA
    After Big Dan's Car Wash ripped the factory antenna off my truck I replaced it with an American made Amazon short rubber antenna and have not had a problem since.
    Votex Black Short Rubber 6 3/4 Inch Universal Antenna Kit - Car Wash Proof
    https://www.amazon.com/dp/B07VWS9V5S
  10. Apr 21, 2025 at 4:06 PM
    single10
    Atlanta GA
    This month, April 2025, I replaced all 4 of my TPMS sensors with stems myself. The batteries were dead in all 4. After replacing, I drove my truck to a local tire shop where they programmed my truck to recognize the new sensors. Within a mile the dash light went out. First time it's been out in 3 or 4 years. I previously replaced the TPMS receiver in the overhead back center as shown above 5 years ago. With my limited knowledge of the TMPS system after hours of research, it sounds like a sensor is not transmitting or the truck needs to be reprogrammed to recognize the TPMS sensors again. I recommend that you have a tire shop (not Discount Tire) verify all 4 TPMS sensors are still transmitting. If one battery is dead and not transmitting you will get a dash light. If all 4 are good then have the truck relearn the TPMS sensors using one of their overpriced TPMS handhelds.
    Here is the sensors I used. The Dude reprogrammed them for me for free because it took him 4 minutes total and I did all the work.
    https://www.amazon.com/dp/B08K3YTPY6?ref=ppx_yo2ov_dt_b_fed_asin_title
  11. Apr 22, 2025 at 5:19 AM
    bradleydavidgood
    Thank you for that info! I have all new wheels, tires, and TPMS sensors from Tire Rack. I am not sure that the shop that installed the wheels (that were already assembled from Tire Rack) did any reprogramming of the TPMS system. So I guess I would start there, and seeing if they could diagnose it if that doesn't work. Like are the sensors transmitting. After that maybe replace that antenna/receiver overhead back center.
