2st Gen Tundra Differential
Discussion in '1st Gen Tundras (2000-2006)' started by TomCat51, Apr 10, 2025.
  1. Apr 10, 2025 at 10:31 AM
    TomCat51
    TomCat51 [OP] New Member
    Tom
    2004 Toyota Tundra SR5
    I have a 2004 Tundra, SR5, 2wd with a crew cab. It has the 4.7L 2UZ-FE engine. I don't know if it has the LSD differential or not. There's a sticked beside the fill plug, but it faded put. When I took the plug out, I couldn't see any gears, but it just looked like a flat piece of gray metal.
    After 113,000 miles, the fluid looked extremely clean.
    My questions are:
    1. Do I have a Limited Slip Differential?
    2. If so, should I change the fluid, even though it appears very clean?
    3. What is the correct fluid to use?
    (Weight, synthetic, additive, etc)
    Any help is appreciated.
    FYI - This truck has not had a tough life. Barely used until last 2 years. One owner.
  2. Apr 10, 2025 at 10:46 AM
    chunk
    chunk New Member
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    It has to be documented somewhere if it was an option that year. Maybe take the vin to your dealer and see if that will shed some light on it. If it's standard for that year, that should be easy to find out I would think. Make sure what you have before you change the oil, LSD takes specific oil.
  3. Apr 10, 2025 at 10:51 AM
    Picture of your rear differential cover please
  4. Apr 10, 2025 at 12:57 PM
    TomCat51
    Tom
    Pictures of my Diff.
  5. Apr 10, 2025 at 1:03 PM
    badass03taco
    badass03taco New Member
    2005 Limited Double Cab 4wd
    That looks like standard diff. the LSD sticker is vertical and above the fill plug
    It do be lookin like dis
  6. Apr 10, 2025 at 1:14 PM
    TomCat51
    Tom
    Thanks. I really need something a little more definite. I thought it might be defined in my VIN, but haven't found anything that defines it.
  7. Apr 10, 2025 at 1:57 PM
    badass03taco
    You can use the Toyota website and use your vin and see how the vehicle was equipped but rarely does that tell you if it had the LSD or no. You'd probably have to get the dealer to look it up on their stuff.
    toyota.com/owners/vehicle-specification/
  8. Apr 10, 2025 at 2:06 PM
    TomCat51
    Tom
    Thanks. I've been to the website. Didn't really help me, much. I may check with my local dealer. The folks in the psrts department know me fairly well.
  9. Apr 13, 2025 at 8:49 AM
    bfunke
    bfunke Tundra Curmudgeon
    Put a jack under the diff and see if your tires spin opposite directions. If so, it's an open diff.
    Dakillacore likes this.
  10. Apr 13, 2025 at 9:06 AM
    Dakillacore
    Dakillacore Brake now, you Mickey Mouse-piece of shit!
    Georgia
    I can pull it up in the Toyota system to see.
    Shoot me the VIN and I'll look it up on Monday if you remind me.
    chunk likes this.
