  1. Apr 12, 2025 at 4:56 AM
    It’s worse to wake up and see your own TITS than someone else’s.
  2. Apr 12, 2025 at 5:16 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
  3. Apr 12, 2025 at 8:42 AM
    We got a dusting here too.
    (We're in the Dolomites. I think it might be the most scenic place I've ever been)
    10/10.
    bmf4069, jpink, BroHon and 5 others like this.
  4. Apr 12, 2025 at 10:50 AM
    Sirfive
    Sirfive Master Procrastinator
    ‘02 Limited AC TRD
    Bassani cat-back
    Anyone know if i can use a cheap HF dc-dc charger between a lead acid & lithium battery? Both ways?
  5. Apr 12, 2025 at 11:45 AM
    I wouldn’t. Different chemistry, charge curves and conditions for a “full” battery I suppose.
    tpope likes this.
  6. Apr 12, 2025 at 2:11 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Circling back to here finally... my little fluke 115 does do capacitance, and I learned a new thing! Yay!
    All three of my capacitors aren't reading correctly. One is DOA (pink arrow. Being used as a jumper) Previous "repair" by the PO added in that other capacitor (red egg) spec'd at 55 +- 10% reading 38 microfarads. Out of spec, but still putting out the correct voltage. (370 VAC)
    The motor run (blue circle) is reading way off what it should be. Spec'd at 5 microfarads, and reading 1 microfarads. NG
    A new one correct capacitor is about $20 or so dollars. 60/5 microfarads. 370 VAC
    @FrenchToasty
    @bmf4069
    I watched this YT video, and dude clearly changes a 45/5 for a 35/5. Whats the deal there? Does the microfarads matter a lot? It doesn't matter to me, I'm simply trying to learn another new thing here.
    Time stamps in video:
    Original capacitor 4:45
    Replacement capacitor 7:23
    Dakillacore, NUDRAT[OP] and Sirfive like this.
  7. Apr 12, 2025 at 2:16 PM
    Capacitance depend upon the circuit and what it’s trying to do that matters. If you’re converting AC to DC for example, the capacitance determines the ripple content size.
    If you can find a multimeter with inductance in addition to capacitance, hold onto that sucker as they’re hard to come by nowadays.
    I purposely bought an LCR meter to do both capacitance and inductance over a wide range of sizes.
    BroHon likes this.
  8. Apr 12, 2025 at 2:19 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Ripple current? :confused:
    I found the 60/5 by searching for manufacturers part number online, and then back tracking to nordyne (ours unit is a miller, made by nordyne.)
  9. Apr 12, 2025 at 2:33 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    I think the energy spike uses what it uses, and more farads just doesnt drain it as deep. Right? Until you get big enough to start melting wires?
  10. Apr 12, 2025 at 3:05 PM
    Ripple voltage. That’s how much the voltage will cycle about the average DC voltage. Typically less than 5% or 1% if you need a solid DC signal.
    For motors, they’re needed for instant current to keep the voltage stable at startup.
    BroHon likes this.
  11. Apr 12, 2025 at 3:12 PM
    The capacitor is co-located with the compressor so you can supply the current required during a spike. That same current is hindered by the wires that supply it from the outlet due to the inductance in the wire, so it can’t react as fast to provide the current required. Lack of the necessary current would cause the voltage to dip, so that’s how the capacitor keeps the voltage stable.
    bmf4069 and BroHon like this.
  12. Apr 12, 2025 at 3:28 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    electricity has always been, and will always be magic.
  13. Apr 12, 2025 at 3:32 PM
    To help make sense of it just remember two concepts:
    1. Current doesn’t move instantaneously through an inductor.
    2. Voltage doesn’t change instantaneously across a capacitor.
    bmf4069 and tpope like this.
  14. Apr 12, 2025 at 3:51 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    So, the magic doesnt comepletly twist, and its not packed tight. Awesome.
    bmf4069 and Jack McCarthy like this.
  15. Apr 12, 2025 at 3:57 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    That’s what they said about FM….F’n Magic
  16. Apr 12, 2025 at 9:43 PM
    Have you checked to make sure your system actually has refrigerant? I threw a bunch money in parts and time trying to diagnose mine last year, only to find out I had multiple leaks and no refrigerant left. I ended up having to replace my entire system.
    NUDRAT[OP] and Tundra2[QUOTED] like this.
  17. Apr 12, 2025 at 11:41 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I did read about that when you went through that. I have not yet, but that's a very good idea. Simple things first, thank you Erik
    NUDRAT[OP] likes this.
  18. Apr 12, 2025 at 11:54 PM
    No problem. I hope that you don't run into the same issue as me. It cost me around $9,000 to replace a system that was only 8 years old. New HVAC equipment is a lot more efficient than the stuff from 20+ years ago, but it doesn't last as long. Seems like we're lucky to get 10 years out of them now.
    BroHon likes this.
  19. Apr 13, 2025 at 4:18 AM
    NUDRAT
    NUDRAT [OP] 6 lug life
    SW CT
    Between 'Ridgelines'
    Greetings from the abyss. I seem to have been away for 497 pages. I miss anything?
  20. Apr 13, 2025 at 5:35 AM
    Gonna show up them Texas boys. Just wait. Other 3 should be here any minute.
  21. Apr 13, 2025 at 5:37 AM
    Naked pics of @bmf4069, @FirstGenVol’s movie debut cementing his film career as an action hero, and @des2mtn officially launched his campaign for governor of CA. Where the hell you been?!
  22. Apr 13, 2025 at 5:43 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    I’d mail a vote in for that.
    455h0le_dachshund and Tundra2 like this.
  23. Apr 13, 2025 at 5:59 AM
    Ouch. That’s why my sister sold her 10 year old Honda Pilot instead of getting it fixed.
  24. Apr 13, 2025 at 6:18 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Yeah, We are running an 80% efficient furnace circa 1993. I've done the blower motor and Cap, and the main board, and of course cleaning the thermocouple when she gets finicky. But I think they are way simpler, less things to go wrong.
    We just run 2 carbon monoxide detectors, one upstairs and one down. She's had a good run so far, but I know the plenum is close to cashing in.
  25. Apr 13, 2025 at 7:03 AM
    jpink
    jpink Aspiring Shade Tree Mechanic
    Knoxville
    05 Black Tundra DC SR5
    Dude, you’re wrong. That’s not true at all.
    He’s 9.
  26. Apr 13, 2025 at 9:18 AM
    I didn't get pics, but it snowed here last weekend. Then it was 92 or so yesterday. The weather needs to make up its damn mind.
  27. Apr 13, 2025 at 9:30 AM
    ELI the ICE man.
    A lot of substations will have massive capacitor banks in them to equalize the power factor of the largely inductive loads inherent in the load side.
  28. Apr 13, 2025 at 9:40 AM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    Is that a hwy tire?!
  29. Apr 13, 2025 at 9:59 AM
    It’s a tire on the highway. Does that make it a highway tire?
    Dakillacore and Tundra2 like this.
  30. Apr 13, 2025 at 10:02 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    FirstGenVol[QUOTED] and KNABORES like this.
