Front Camera Issue
Discussion in '3rd Gen Tundras (2022+)' started by RDW, Apr 12, 2025.
  1. Apr 12, 2025 at 5:28 AM
    RDW
    RDW [OP] New Member
    Rob
    NJ
    2025 Tundra Platinum TRD Off-road
    Heritage Grille w/ TRD Marker Lights, Diode Dynamics Light Bar and OEM TRD Dash Switch, Rigid Yellow Fogs, Diode Dynamics C1 Hitch Pod Light, AMP Powersteps Smart Series, Aftermarket Power Bed Step, Bedbug XLT, Rough Country Neoprene Rear Seat Cover
    Hoping someone here can help before I pull everything apart....I installed the Heritage Grille, Marker Lights, and a Diode Dynamics light bar on my 25 Platinum and everything was working wonderfully. All cameras and sensors were fine, but yesterday I noticed I am not getting an image from the front facing camera, it just shows black as you can see here. I disconnected the battery, restarted the head unit, checked the plugs to make sure everything was seated correctly, but nothing. I am likely going to take the front valance off to triple check the camera harness is seated (it is impossible to take the harness out without removing the entire front end...
    Has anyone ever seen this? Think the dealership is going to blame me and not fix it under warranty because of the grille swap? Should I order a new camera (anyone have the part number for the 25 Platinum with TRD OR Package)?
    Thanks all!
  2. Apr 12, 2025 at 6:45 AM
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    I think the front camera is in front of the rearview mirror, not in the grille.
    When my front camera failed, it disabled the radar cruise and front collision detection. Do those features work for you?
  3. Apr 12, 2025 at 7:41 AM
    DRP
    DRP Old Member
    Dave
    I was going to reply with the same thing that the "front" camera was in the windshield. Then I got curious and looked in the manual and Toyota calls both of them front cameras. Different sections of the manual written by different groups and left hand not talking to right?
  4. Apr 12, 2025 at 7:58 AM
    RDW
    RDW [OP] New Member
    Rob
    NJ
    Based off this entry in the manual, it looks like the camera for the panoramic view is def the one in the grille as suspected.
    sudobash likes this.
  5. Apr 12, 2025 at 8:55 AM
    DRP
    DRP Old Member
    Dave
    Seems to be the case. Odd that they can't give them different names...
  6. Apr 12, 2025 at 11:02 AM
    RDW
    RDW [OP] New Member
    Rob
    NJ
    Took the whole thing apart, everything looks fine. Going to try my luck at the dealer
  7. Apr 12, 2025 at 11:20 AM
    Matt2015Tundra
    2023 1794 CrewMax
    So, based on the manual, our trucks have 6 cameras? Wow. Talk about needless tech overkill.
  8. Apr 12, 2025 at 11:26 AM
    DRP
    DRP Old Member
    Dave
    And none can be used as a recording dash cam. Lame.....
    Gonefishingdave likes this.
  9. Apr 12, 2025 at 11:49 AM
    RDW
    RDW [OP] New Member
    Rob
    NJ
    Seriously. Major oversight
  10. Apr 15, 2025 at 3:58 PM
    RDW
    RDW [OP] New Member
    Rob
    NJ
    Looks like the front camera failed so my dealership is replacing it under warranty...no questions asked about the grille swap- not that a grille swap could have caused a camera failure anyway.. they gave me a brand new Tacoma to drive while they take a day or two to get the part and swap it out.. win/win
    astrength22 likes this.
  11. Apr 15, 2025 at 4:15 PM
    obgod3
    obgod3 New Member
    NC
    2023 Tundra Limited
    Which front camera?
  12. Apr 15, 2025 at 4:18 PM
    RDW
    RDW [OP] New Member
    Rob
    NJ
    They’re replacing the one in the grille
    obgod3[QUOTED] likes this.
