DIRTY SEVEN CLUB
Discussion in '2.5 Gen Tundras (2014-2021)' started by matictundra, Feb 18, 2019.
  1. Mar 20, 2025 at 1:18 PM
    #3721
    Uhhhh....
    Uhhhh.... New Member
    Dave
    Virginia
    2016 Silver Limited DC
    7” BDS, 37s
    Point them to this forum lol
  2. Mar 20, 2025 at 4:50 PM
    #3722
    eccracer104
    eccracer104 Dirty Paws Off-Road
    San Diego, CA
    2011 Tundra 5.7 4x4 CM
    Honestly I can't say I blame them because "they fit" but they don't "fit". Chances are they've had people complain about rubbing and the typical lift manufacturer doesn't recommend larger than 35" so they're playing it safe.
    Now with your 125 pages worth of reading and knowledge you can determine your path based on examples of 37" with various levels of lift, wheels and modifications.
    My last Tundra had 1.8" of lift in the front and no lift in the rear on Icon Billet UCAs and I "fit" 37" tires. But they fit after cutting and modification to fit. Regardless of the amount of lift when the suspension compresses the truck essentially doesn't have a lift, so if you plan to use your truck plan to accommodate for the tire size and run with wheels that will give you the best opportunity not to rub (ie: ~+25mm offset).
    Mfanatic22[QUOTED] and BreyTundy like this.
  3. Mar 20, 2025 at 6:23 PM
    #3723
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
    So many people miss this concept, it's insane. Major props for spreading the good word of true clearance
    eccracer104[QUOTED] likes this.
  4. Mar 20, 2025 at 6:35 PM
    #3724
    eccracer104
    San Diego, CA
    :fistbump:
    BreyTundy[QUOTED] likes this.
  5. Mar 20, 2025 at 9:19 PM
    #3725
    Mfanatic22
    Mfanatic22 New Member
    2019 CM White SR5 Sport 4x4
    Thank you for the info. The shop did mention that they had lots of “comebacks” with people complaining about rubbing so they didn’t want to deal with it. Like you mentioned, the juice is not worth the squeeze for them installing 37s.
    Yes I’ve read this thread multiple times and decided to go with +35 offset for better fitment.
    Thanks y’all for the reassurance!
  6. Mar 20, 2025 at 10:46 PM
    #3726
    rcsbguy
    rcsbguy New Member
    Go to Sibi Built
  7. Mar 20, 2025 at 11:31 PM
    #3727
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Go with long travel lol
  8. Mar 21, 2025 at 5:22 AM
    #3728
    benredfox
    benredfox New Member
    Good choice!
    I had originally wanted to go with the 39s, but backed off from that plan after hearing from people having drivetrain components breaking on them due to them being larger and heavier.
    Interestingly enough, I found that the 39x12.5r17 tires at least cost more than the 39x13.5r17 on the many different brands across the board and decided to pull the trigger on 13.5s instead, saving a little over $200. I don't know if this is such the case with the 35s vs 37s? I guess demand and supply would dictate their prices?
    Most recently, I finally had my Katzkin leather seats cover with heater installed, purchased them since last year never ever being able to find time. And with some new LED AlphaRex MK2 Nova and Baja fog lamps installed to match.
    Next on my list would be the front suspension, getting this truck ready for Nevada where I would finally reside optimistically. California has gotten to expensive for me and the state's politics have become banana, it's enough for me.
    I am in the North Cal if you ever need any assistance and you're more than welcome to give me a buzz? Everything done my on truck was done in house by the shop I own and run, except for the leather seat installed.
    Next on my chopping block is that white 2020 TRD Pro you see next to my truck on my previous post, it's getting the same treatment. The owner of this truck has been contemplating on putting a Magnum TVS2650 supercharger too, he has some deep pockets. And down the list is a 2024 Platinum come the next few months.
  9. Mar 21, 2025 at 1:45 PM
    #3729
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    Yes! Because everything bolts right up, yeah?
  10. Mar 22, 2025 at 2:24 AM
    #3730
    Tundra2Yak
    Tundra2Yak New Member
    2016 1794 4x4 CM
    Pro Comp 6" Lift Fuel Renegade d263 Nitto Ridge Grappler 35 x 12.5 x 20 Borla cat-back exhaust Volant intake Bakflip MX4
    Need some help selecting UCAs.
    Truck has a 6 or 7 inch Pro Comp lift on 20x10, -19 wheels. I'll be swapping the spacers for Rough Country Vertex coilovers. I was planning to do SPC UCAs but my installer has concerns due to recent quality issues.
    What other UCA options should I be looking at? JBAs seem like the next obvious choice.
    Once these are upgraded it's time for BMC and 37s!
  11. Mar 22, 2025 at 6:18 AM
    #3731
    Uhhhh....
    Dave
    Virginia
    7” BDS, 37s
    I have a BDS 7” & though that particular lift worked fine with OEM UCA’s, I eventually swapped them out for BDS‘s UCA’s & they’ve been fine.
    Tundra2Yak likes this.
  12. Mar 26, 2025 at 4:02 PM
    #3732
    Tundra2Yak
    2016 1794 4x4 CM
    I'm going to go the JBA route based on feedback.
    Next question: anyone running Mickey Thompson baja legend EXPs in 37"? 69 lbs per tire sounds too good to be true.
  13. Mar 28, 2025 at 4:31 AM
    #3733
    ericmunns
    ericmunns New Member
    Eric
    Seattle
    2019 white 1794/TRD
    2019 1794 TRD 4x4
    -Ironman foam cell pro 3.5” (heavy)
    -Method - MR 701 18x9 +25mm
    -Toyo Open Country R/T Trail- 37x12.5
    BMC and bumper trim. After a proper alignment we have no rubbing around town and out for some medium off road driving.
  14. Mar 28, 2025 at 6:03 AM
    #3734
    COTundra23
    COTundra23 New Member
    just right :bowdown:
  15. Apr 5, 2025 at 5:53 AM
    #3735
    Sfri
    Sfri New Member
    2011 CM Platinum
  16. Apr 5, 2025 at 7:10 AM
    #3736
    2014 Black tundra
    2014 Black tundra New Member
    2014 tundra sr5
    Nice! :thumbsup: But, it would be nicer if it was black. :D JMO buddy. :D
  17. Apr 7, 2025 at 10:08 AM
    #3737
    Sfri
    Sfri New Member
    2011 CM Platinum
  18. Apr 7, 2025 at 10:14 AM
    #3738
    Dave8699
    Dave8699 Trackrat
    NJ
    04 Tundra AC, 2014 Tundra 1794 Crew Max
    Whole truck Raptor liner in olive green, leer camper cap, 5100 with OME, Wheelers AAL and Firestone Air bags.
    Just ordered DRT relocation and Icon Vector wheels. Now I have to decide what tires to run. What's the present tire guys are using? Pretty much a pavement warrior just like the look of aggressive tires. Minimum noise good in rain and snow. Yes lot to ask lol
  19. Apr 11, 2025 at 6:04 AM
    #3739
    Sfri
    Sfri New Member
    2011 CM Platinum
  20. Apr 11, 2025 at 6:48 AM
    #3740
    SAGE63
    San Diego County
    You gotta do that water crossing
    caboj, COTundra23 and Uhhhh.... like this.
  21. Apr 11, 2025 at 6:58 AM
    #3741
    Sfri
    Sfri New Member
    2011 CM Platinum
    @SAGE63 Maybe if I had a snorkel...
    SAGE63 likes this.
  22. Apr 11, 2025 at 7:11 AM
    #3742
    WinterWarlock21
    WinterWarlock21 New Member
    South Jersey
    2016 Quicksand TRD Pro CrewMax
    https://gearproject.co/profile/SandShark21
    I went with nitto ridge grapplers which I don't mind. I liked my mickey Thompson Baja boss a/t's more since they had more sipes since it was A/T and not hybrid. If I bought new tires today I'd go Toyo Open Country A/T III since I'm mostly highway now or falken wild peaks a/t4w (I had the a/t3w when they first came out and loved those) . It's a toss up lol everyone has a different opinion. i.e. some say Ridge Grapplers are great in snow and others say awful.
    The DRT relocation kit is awesome, you'll be glad you got it.
  23. Apr 11, 2025 at 9:56 AM
    #3743
    Dave8699
    Dave8699 Trackrat
    NJ
    So im leaning towards the MT Baja AT seems like nobody really has negative comments about them. I run Peaks at3 on my highlander and some reason they are pretty loud. Not sure if it's because of the wear on them or what, but they are amazing in the rain and snow.
  24. Apr 11, 2025 at 10:31 AM
    #3744
    WinterWarlock21
    South Jersey
    Honestly really liked my Baja Boss A/T. I had a hard time balancing 2 out of 4 of them but MT made it easy to warranty them out (at 80% because I did put a few thousand miles on them). But the 2 new ones were perfect. No complaints about them. They are on the heavier side but they’re my favorite tire I’ve ever ran on all my vehicles. Great looking tire too. I just always switch it up because I like trying something different but if you told me I could only run 1 tire rest of my life on my truck, it would be the Baja Boss A/Ts. Got me through a huge blizzard driving home from Vermont to NJ at 2 am. Can’t go wrong with them.
  25. Apr 11, 2025 at 11:03 AM
    #3745
    Dave8699
    Dave8699 Trackrat
    NJ
    Guess the baja it is.
  26. Apr 11, 2025 at 6:32 PM
    #3746
    cwmoneymaker
    cwmoneymaker New Member
    Nice! No cutting to fit those?
  27. Apr 12, 2025 at 6:09 AM
    #3747
    Corndog123
    Corndog123 New Member
    Sam
    Tennessee
    2014 SR5 Tundra Crewmax 4wheel drive 5.7
    Rough Country suspension, 305s, ARB bumper, light bar, Smittybuilt 10k winch. XD Buck 25 rims
    So you're in Western Ore. ? I lived 6 miles east of Newport. Toledo was my home for about a year and a half. Loved Oregon.
  28. Apr 12, 2025 at 6:21 AM
    #3748
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
    Need a build thread or more pictures of this. Badass build!
  29. Apr 12, 2025 at 3:23 PM
    #3749
    Chad D.
    Chad D. New Member
    Western Oregon
    I know the area well. Newport is my most visited port, by far.
  30. Apr 16, 2025 at 2:47 PM
    #3750
    Dave8699
    Dave8699 Trackrat
    NJ
