Third Brake Light Not Working
Discussion in 'General Tundra Discussion' started by FSJ_Tundra, Sep 23, 2019.
  1. Sep 23, 2019 at 10:17 AM
    FSJ_Tundra
    FSJ_Tundra [OP] New Member
    Hello, My third Brake Light on Mt 2007 Tundra CrewMax stopped working. I have the Electrical diagram for trouble shooting. However I dont know where the conectors are located and how the Wire runs to the Light int the headliner. Any Help would be appreciated to where to start testing?
  2. Sep 23, 2019 at 10:39 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    New bulb(s) not working?
    Voltage at light when brakes pressed?
    Fuses checked?
    Rakkasan likes this.
  3. Sep 23, 2019 at 1:37 PM
    FSJ_Tundra
    Yes Checked Bulbs, The two Lower back Lights Work. No Voltage at third Brake Light when brake Pressed. The Wiring Diagram Show a common Point Connector to look at, I Just Don't know where the Connectors are Located. I need the Diagram that shows the Connector Locations on the Truck.
  4. Sep 23, 2019 at 1:58 PM
    Trooper2
    JR
    Sorry can't help.
    I would think it would just be from the brake pedal switch. Maybe the switch has some worn out contacts. Something to try if not too expensive.
    Hopefully someone else can chime in.
  5. Sep 23, 2019 at 2:10 PM
    Welcome from NY.
    Did you check the light socket itself, the wire could have come off or corrosion from water?
    Good luck, let us know the outcome.
  6. Sep 23, 2019 at 2:36 PM
    Jrharvey02
    Jrharvey02 New Member
    There is a switch next to your steering wheel that turns it on/off...I’d check that first...
    NewImprovedRon likes this.
  7. Sep 23, 2019 at 5:38 PM
    FSJ_Tundra
    Checked the switch under the Steering Wheel. As i do have Brake Light. Just No high mount Brake Light.
  8. Sep 23, 2019 at 7:33 PM
    FSJ_Tundra
    Thank You, the Wiring Diagram will help. How do the Body connections cross reference to the Stop Light Electrical Diagram: A40(A),A41(B) Junction Connector and AP2 going to High Mount Stop Light?
  9. Sep 26, 2019 at 8:47 AM
    FSJ_Tundra
    Update: found connector I was looking for under Drivers Left Kick Panel. Wire to third brake light was in wrong Pin. Moved to correct location on Plug all good now.
    Rakkasan and Jim LE 1301 like this.
  10. Sep 26, 2019 at 9:22 AM
    Trooper2
    JR
    Good to hear. Any idea why it was in wrong pin? Have any work done?
  11. Sep 26, 2019 at 9:51 AM
    FSJ_Tundra
    The Wire was in the Wrong Position as I had a Dealer do some Trouble shooting for me, I was blowing the Stop Fuse during Hard Braking. All Brake Lights would go out and loose the ability to shift out of Park until I changed the fuse. Turned out to be My Brake Controller was shorting to Ground and leaking through the wire insulation at higher Currents. I guess the Tech during trouble shooting removed the wire to check for short to third brake light. But put the wire back in the wrong pin position. The Dealer was helpful in telling me where the connector was and then i figured it out. The hard part was trying to figure out how to remove the pin and move it.
  12. Oct 22, 2019 at 5:20 PM
    Twinky
    Twinky Keep the shinny side up!
    Kemah, Texas chillin on my ChrisCraft 480
    07 double cab work horse
    Stereo upgrades: -HU, Pioneer Mvh bs501 -Tweeters, Peerless(vifa) XT25SC90-04 1" Dual Ring Radiator s in custom pods. -Mids, Silver Flute W17RC38-04 6.5" Wool Cone Woofer. -Subwoofer, American Bass XR12. 2.3^3ft tuned @33-34 hz. -Tw Amp, Old School 2ch Sony. -Mids Amp, Old School Autotek Sx275. -Sub Amp, Old School Memphis 16-pr1.1000 -Zero gauge big 3. 0 and 4 gauge copper runs to amps.
    Any chance you could describe which harness and its position in it?
    Im having issues with mine to. Lower brake lights work. The cargo lights that are next to it work.
    I pulled the entire light cover Assembly and put my dmm to the wires directly and there's no voltage when petal is pressed.
    Sadly I'm not even sure how long its been broken.
    Anyone know if the OEM trailer brake is tied into the high mount brake light? Trying to diagnose my trailer is how I noticed the light was dead.
  13. Oct 23, 2019 at 7:57 AM
    FSJ_Tundra
    The connector is located on the Driver side kick panel 2007 Tundra. It is at the very bottom near the floor - AP2 . The male part of the plug comes off and you can check for voltage before going up to the third brake light.
    Twinky likes this.
  14. Oct 23, 2019 at 12:10 PM
    Twinky
    Thank you very much!
    Now all I need is a little free time!
  15. Feb 2, 2022 at 8:59 PM
    nate.mann42
    nate.mann42 New Member
    nate
    so I have the same problem but I'm getting no power up to the cargo/third brake light. I know there is a switch in the cab, tried that, changed all the bulbs, and the fuse (7.5 #40 interior fuse box) but I'm still getting nothing. Is there are any inline fuses or connections that could have caused this. I used a multimeter to test for continuity, OL, the voltage also zero? does anyone get any insight or solutions?
  16. Apr 10, 2024 at 4:10 PM
    GhettoRacer151
    GhettoRacer151 New Member
    Ever solve this?
    I have same issue
    Tks
  17. Apr 10, 2025 at 2:51 PM
    tophermm
    tophermm New Member
    2014 Toyota Tundra 5.7 TRD FF
    Having the same issue as well. Neither cargo light & no 3rd brake light.
  18. Apr 10, 2025 at 4:01 PM
    This is the harness....it's about 12 inches long if that.
  19. Apr 10, 2025 at 4:08 PM
    tophermm
    tophermm New Member
    Thank you so much for your reply. To be clear, you're saying I should remove the housing from outside, and I'll be able to remove and replace that harness then right? , Thanks again.
  20. Apr 10, 2025 at 4:14 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Sounds like a ground issue.
    Have you tested the bulb sockets for brake and cargo light power with a multimeter?
    Possible the roof connector came loose but doubtful unless you'd had it apart at some time.
    You'll be able to remove the lens for bulb replacement from the outside.
    The light housing itself mounts from the inside I think.
    Doesn't it @Tundra234 ?
  21. Apr 10, 2025 at 4:19 PM
    Yes, the housing mounts to the cab with 2 nuts under the headliner.
    1lowlife[QUOTED] likes this.
  22. Apr 10, 2025 at 4:24 PM
  23. Apr 10, 2025 at 7:36 PM
    tophermm
    tophermm New Member
    Thanks ya'll I appreciate it. I've ordered the harness. I'll let ya know if it resolves the issue once it arrives and I get a little time to put it on.
