  1. Apr 10, 2025 at 9:51 AM
    Florida AF
    Logan
    North Florida
    Sounds almost like a snap ring, which I hate... but regardless, I will be watching to learn since I do not have a clue!
  2. Apr 10, 2025 at 9:53 AM
    Azblue
    The Dirty T ( ^_^)_且
    No idea, but I get all my trailer stuff like bearings and brakes from these guys. Maybe give them a call.
    https://www.southwestwheel.com/?srsltid=AfmBOorkRPg7AvhtPEuevTtTr-pVqoZ6_HlH6vI7zKbU3A-NuNmjSEti
  3. Apr 10, 2025 at 10:04 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    :D
    :militarypress:
    :nuclear:
  4. Apr 10, 2025 at 10:06 AM
    Tripleconpanna
    If only there was a way to create diversity amongst our Staff Members by hiring some 'challenged' personnel... :monocle:
    Oh wait....
    :nuclear:
  5. Apr 10, 2025 at 10:07 AM
    Tripleconpanna
    You too, huh??? :boink:
  6. Apr 10, 2025 at 10:08 AM
    Tripleconpanna
    Repack and go!!!
  7. Apr 10, 2025 at 10:13 AM
    IMXPLRN
    IMXPLRN New Member
    Rescue, CA
    2020 Tundra Limited on 35's
    Is the hub assy. still in good condition? If so just replace the bearings? Lets see some more pictures of the actual hub and go from there. I have lots of bearing usage and design experience from my previous job.
  8. Apr 10, 2025 at 10:33 AM
    Florida AF
    Logan
    North Florida
    I thought they already did....... :boink:
    LOL, only because it is you! :hearteyes:
  9. Apr 10, 2025 at 10:53 AM
    Florida AF
    Logan
    North Florida
    My favorite, we sent you this and you didnt respond so now you must xxxxx.... um no ma'am... it is your job to do your job right and then I handle the rest... "well you should have known."
  10. Apr 10, 2025 at 10:53 AM
    Tripleconpanna
    No you're just showing off you multi-quote skills :facepalm:
  11. Apr 10, 2025 at 10:56 AM
    Florida AF
    Logan
    North Florida
    But with heart filled eyes, so its ok!
  12. Apr 10, 2025 at 10:58 AM
    Tripleconpanna
    Blue Thunder, AZBaldy and T-Rex266 like this.
  13. Apr 10, 2025 at 11:41 AM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    Considered this. Never done it before and I was trying to cut corners with buying a complete ready to go packed hub.
    after closer inspection not even sure my bearings are bad but both seals on the back side of each hub assembly appear to be where I'm loosing my grease. I attached photos of the bearings, the seal and the hub assembly as well as the means that hold everything all together. Both wheels have play in them when jacked up. Also original bearings that came with the trailer when I bought it in 2012.
    I have grease all over each wheel as well.
  14. Apr 10, 2025 at 11:44 AM
    IMXPLRN
    IMXPLRN New Member
    Rescue, CA
    Those are tapered roller bearings and you should be able to get high quality replacements from Timken. You'll need to measure with some calipers the OD of the cup the ID of the cone and then the height with them placed together.
  15. Apr 10, 2025 at 11:56 AM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    Thanks for helping. Now I have an excuse to get a new tool.
  16. Apr 10, 2025 at 12:12 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Take a picture of the bearings and races with grease cleared off. If there is no sign of pitting or obvious wear on them I would just re-pack them and install new seals. The trick to having no play/wobble is to properly seat them and tighten appropriately. I spin the hub while tightening a few times to set them in and then just back the nut back slightly as to have no play. Not too tight, not too loose.
  17. Apr 10, 2025 at 12:15 PM
    IMXPLRN
    IMXPLRN New Member
    Rescue, CA
    You're welcome. They should have numbers engraved on them. If you can find those then you will know exactly what you have.
  18. Apr 10, 2025 at 12:28 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    I was hoping that they would, but all 4 bearings from both sides don't have those numbers engraved on them. I can faintly see something on one of them but nothing that helps me.
  19. Apr 10, 2025 at 12:31 PM
    NWPirate
    Zach
    WA
    This.
    Clean the bearings and you should see some numbers/letters.
    Unless it's a Temu bearing assembly..
    T-Rex266, Blue Thunder and AZBaldy like this.
  20. Apr 10, 2025 at 12:32 PM
    NWPirate
    Zach
    WA
    Snap a picture for some young eyes up in here.. :boink:
  21. Apr 10, 2025 at 12:32 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    All the races look clean with no markings. Same with the bearings. So would you just get new seals and repack them? At this point since I have everything apart I'm leaning towards getting new bearding and seals.
    I also watched a video on you tube that basically went through what you just explained on how to get everything snug when putting it back together. Tighten the nut until the wheel struggles to spin, then back the nut off a bit until the wheel start spinning freely again.
    T-Rex266 and AZBaldy like this.
  22. Apr 10, 2025 at 12:33 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    No numbers but stock Dexter hubs on a triton aluminum trailer.
  23. Apr 10, 2025 at 12:38 PM
    Blue Thunder
    Washington
    And I am glad I paid someone to repack my trailer bearings a few weeks ago.
  24. Apr 10, 2025 at 12:56 PM
    Florida AF
    Logan
    North Florida
    got to crawl under my desk in between customer over reactions today... finally have a standing desk again...
    edited- forgot to minimize my screens
  25. Apr 10, 2025 at 1:09 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
  26. Apr 10, 2025 at 1:19 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    FR.
  27. Apr 10, 2025 at 1:20 PM
    Blue Thunder
    Washington
    :101010:
  28. Apr 10, 2025 at 1:24 PM
    People are disgusting. The floors are what they looked like when I pulled off the carpeted mats
    I had to pull this car out, onto the driveway and open all of the doors to blow it out; 3x. The mats were worse for pet hair removal.
  29. Apr 10, 2025 at 1:31 PM
    Don’t you love it when a plan comes together.
  30. Apr 10, 2025 at 1:34 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Today, I reaffirmed to myself that selling on FB marketplace is a waste of time.
    It's simply nothing but scammers trying to get your info..:rolleyes:
