Wideband AFR gauge fuse.
Discussion in 'Performance and Tuning' started by Downytide, Apr 9, 2025.
  1. Apr 9, 2025 at 3:58 PM
    Downytide
    Downytide [OP] New Member
    GTA
    Lunar Rock that whines
    I was doing annual Spring cleaning and noticed a mess of wiring 3rd party shop left when installing my DLG1 gauge.
    Basically the instruction calls for:
    • On both the DLG-1 and LC-2, connect the RED wire to an isolated switched 12V source in your vehicle. A switched 12V source goes ON as soon as “key on” power is active. The circuit to which you will pull power from should be able to support a 6 amp draw (3 amps each from the DLG-1 and LC-2.) Make sure each connection is protected with a 5A fuse (not supplied.)
    But, the shop just jammed it between the fuse panel and a 10amp fuse (for the ECU :S) is there a good spot on the fuse panel for this?
  2. Apr 9, 2025 at 4:24 PM
    centex
    centex New Member
    I used a fuse tap and tapped into a switched fuse under the hood. I think it was called IGN or similar.
    HulkSmurf14 likes this.
  3. Apr 9, 2025 at 6:17 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    No 27 ignition fuse. Usually for intercooler and afr gauge etc.
    I also tap into no 21 rad no 1 fuse, audi/nav for ignition on stuff.
    If you don't have rear seat entertainment theres no 19 and no 20.
  4. Apr 10, 2025 at 7:46 AM
    Downytide
    GTA
    Is this the one by the foot brake pedal panel?
  5. Apr 10, 2025 at 7:57 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Engine bay.
    Cig lighter inside or seat heaters. There are a few others that are ign on.
    Downytide[QUOTED][OP] likes this.
