  1. Apr 9, 2025 at 7:54 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Do it. Save the other 35lb strut for later, when the other gets worn out.
    That's what I'm doing
  2. Apr 9, 2025 at 8:34 PM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    Shit I’m pissed I sold my canopy 4 year ago, I check marketplace everyday looking for another one.
  3. Apr 9, 2025 at 8:52 PM
    Bought2Pull
    Bought2Pull New Member
    Greg
    WV
    2006 Tundra 4 door
    I have the Valvomax Oil Drain Plug on three vehicles and it works fine. None of those vehicles have a skid plate. I think yours will be fine. :)
    Today I did my first oil change and filter on the new-to-me Tundra. Had to use a 15 inch breaker bar on the oil drain plug.....ugh....bought it used and I think the previous owner's "mechanic" was um, not the be at being a mechanic. LOL
  4. Apr 10, 2025 at 6:39 AM
    Tired of my antenna being 1ft taller than my roofline and scraping up my new garage doors. Was going to cut my stock antenna, but then I saw and ordered this, from Votex: https://votex-us.com/A461-TTY-15
    Will report back, supposed to be 23" tall versus the OEM which is 31" tall. Gives me that extra 8" needed.
  5. Apr 10, 2025 at 6:58 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Billy Mays needs to read that description... he did in my head :rofl:
    Or maybe even the ShamWow guy
    The Black Mamba likes this.
  6. Apr 10, 2025 at 7:02 AM
    Dakillacore
    Georgia
    RIP to the homie.
  7. Apr 10, 2025 at 7:07 AM
  8. Apr 10, 2025 at 8:15 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Well I let the JB Weld cure for 24hrs... It's a good thing I didn't try to drive her to the hill country last night.
  9. Apr 10, 2025 at 8:18 AM
    Damn dawg I can't believe you ain't Flexin' it yet.
  10. Apr 10, 2025 at 8:29 AM
    Dakillacore
    Georgia
    I fixed a large crack in my wheelbarrow with flex seal. I'm not sure how much weight it will hold up, but we will see now that it's yard work season.
    455h0le_dachshund likes this.
  11. Apr 10, 2025 at 8:48 AM
    Did you leave the radiator cap on while it was curing?
  12. Apr 10, 2025 at 8:59 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Yeah, why?
  13. Apr 10, 2025 at 9:00 AM
    Pressure
  14. Apr 10, 2025 at 9:19 AM
  15. Apr 10, 2025 at 9:29 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    You think I should've popped the cap?
    Maybe, never crossed my mind. But it was already a little low on coolant from the leak, because I hadn't (and still haven't) topped it off.
    I also read that JB Weld makes a formula specifically for radiators, but I just used the stuff I had on hand in the garage already. Either way, the new radiator should show up today, although I have my doubts. Apparently it's shipping from a Rock Auto warehouse in Houston. So like an hourish away from me. But FedEx has yet to receive the package. So maybe tomorrow.
    oscardog86 likes this.
  16. Apr 10, 2025 at 9:36 AM
    The Black Mamba
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Annual UCA bushing lubricating
  17. Apr 10, 2025 at 9:43 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Annual?
    https://m.youtube.com/watch?v=uvUL28Skt6E
    Edit: oh yours have zerks. Nice. I wish my SPCs did.
    When the day comes to re-geease my control arms, I think I'll add zerks to the Solos and SPCs. Or buy the greasable cam bolts and drill holes in my bushings.
  18. Apr 10, 2025 at 10:07 AM
    The Black Mamba
    DFW
    Imma keep it stock
    TC says to do it every like every 30k, but since the wheels were off and it’s not hard…. Besides, any excess comes out the bolt side anyway so it would be difficult to over fill them
  19. Apr 10, 2025 at 11:10 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    Anything I should look out for when checking out a replacement truck bed? I found one that is the same color as mine, but bedlined and dent free. It also is coming with a free tonneau cover. I'm planning to pick it up on Sunday or Monday along with two bucket seats and center console.
    shifty`, BroHon, RUSTYNUTS and 3 others like this.
  20. Apr 10, 2025 at 11:12 AM
    G_unit3000
    G_unit3000 New Member
    Gman
    North East
    2005 Tundra DC 4x4
    Nice find. What's wrong with your current bed? Rust?
  21. Apr 10, 2025 at 11:16 AM
    Dakillacore
    Georgia
    The spray-in bedliner will be tore up when you remove the bed. The companies typically spray over the bed bolts and it strips a hole around the bolts. It's only a cosmetic issue and you can just get a can of raptor liner to spray back over the bolts.
    Kimosabe[QUOTED] likes this.
  22. Apr 10, 2025 at 11:46 AM
    Did you loosen the thru bolt?
  23. Apr 10, 2025 at 11:57 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    It's got some dents around the taillights that cause the taillights to not mount correctly. And yes, a bit of rust in the bed from stuff stuck under the bedliner the previous owner had. The quote I got to fix mine started around $600. Then you add another $5-600 for bedliner. If this bed is in great shape then it will be quite a bit cheaper to just swap; especially if I can recoup a couple hundred bucks for my bed.
    Here are the dents on my bed. They are matching on both sides.
  24. Apr 10, 2025 at 11:58 AM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    What are bucket seats? Sounds like something out of a Nissan. It’s Captain’s chairs for us
    bed come with the tailgate? Those are always in demand
  25. Apr 10, 2025 at 12:03 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    I always thought they were buckets. I'm ditching my bench seat and getting a proper center console.
    Bed comes with tailgate and tonneau cover. Not sure on the brand but I might be listing it for sale once I make sure its in good condition.
  26. Apr 10, 2025 at 12:11 PM
    robabeatle
    robabeatle New Member
    AZ
    2002 Tundra 4x4 LTD AC
    Bilstein 6112 & 5160, Katskinz, audio upgrades
    New air filter. My records show 25k since last replaced but I think I may have missed an entry at some point.
    New vs old
  27. Apr 10, 2025 at 12:47 PM
    The Black Mamba
    DFW
    Imma keep it stock
    yes
  28. Apr 10, 2025 at 12:48 PM
    The Black Mamba
    DFW
    Imma keep it stock
    TRD exhaust tip
    khooiii, shifty`, KNABORES and 7 others like this.
  29. Apr 10, 2025 at 12:51 PM
    wrenchvelo
    wrenchvelo New Member
    2000 Tundra TRD 4wd
    Ivan Stewart 2002 SEMA show, leather interior. Hellwig Anti Sway bar.
    Just completed interior refresh, do it once every 25 years whether she needs it or not..
    Pulled the front seats and had the seat bases redone. Foam refreshed and reupholstered. The front seat backs and rear seat were still in good shape. Pulled the carpet while the seats were worked on and cleaned it since it wasn't worn, just stained with coffee spills and such. To keep the insulation attached to the bottom of the carpet in good shape, the carpet was placed on a clean garage floor, then used a scrub brush and a can of carpet cleaner. The carpet was only moist at this point and the bottom was still dry. Then it was Hung vertically and power washed. The dirty and soapy water flowing out was initially coffee colored. It was left hanging to drip dry. It was dry in less than 24 hours. It is now stain free. The insolation underlayment looked the same as when pulled, it never was saturated due to the rubber carpet base the underlayment is attached to.
    khooiii, mcharfauros, Lundy and 18 others like this.
  30. Apr 10, 2025 at 12:55 PM
    G_unit3000
    Gman
    North East
    2005 Tundra DC 4x4
    Hilarious.
    Your new seat bottoms look great. You had this done custom?
    wrenchvelo[QUOTED] likes this.
